Old May 02, 2012, 06:59 PM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Peter.. those are very nice wheels but pricey here are some other ones that I found they have nylon or alum. hubs neither are scale but I will just cast some hubs and glue them on the tire is foam inside and rubber tread and side walls very light and the price is right also. OH yea there 1 3/4" width these are close to scale.
http://www3.towerhobbies.com/cgi-bin...&I=LXFV60&P=SM
splinterz25 is offline Find More Posts by splinterz25
Old May 02, 2012, 07:21 PM
joneswag is offline
Find More Posts by joneswag
Joined Apr 2012
Have had the laser cut parts for about 18 months now, when I saw your build details, I though I would get into it.
joneswag is offline Find More Posts by joneswag
Old May 02, 2012, 07:24 PM
joneswag is offline
Joined Apr 2012
Tried to put photos up but they didnt appear?
Old May 02, 2012, 07:29 PM
Baltimore MD USA
Joined Jan 2011
Great I've been waiting for some one else to post there build of a mossie there are very few of these planes being built and even less being posted! So please post your build and if you don't want to start your own thread then post your progress here. May be we can get the other guys out there to start building there's also and they can also post there progress here if they want also.
Old May 03, 2012, 01:27 AM
PeterF is offline
Find More Posts by PeterF
PeterF's Avatar
United Kingdom, England, North York
Joined Nov 2004
Yes, those are the ones I have used on my Mossie, Sullivan SkyLite, but they are not the lightest I have found and you ill probably need the extra spring with these.
PeterF is offline Find More Posts by PeterF
Old May 03, 2012, 09:03 AM
Baltimore MD USA
Joined Jan 2011
Yes peter I think I will try the SkyLite wheels from Sullivan anything lighter than that I would think may not hold up to many landings and most of the weight will be from the steal used in making the landing gear.
that's when it's good to have those 95's to handle the extra weight!
Old May 03, 2012, 04:16 PM
joneswag is offline
Joined Apr 2012
Hopefully his time I can get he pictures up
Old May 03, 2012, 09:44 PM
Baltimore MD USA
Joined Jan 2011
Alright ...joneswag looks like you have made a good start make sure your parts are right on the print so it will match the second half ..mine were off a bit so I had to make adjustments but this type of building can be tricky. With the FUSE you will do the same thing...BUT if I had to do it over I would build the second half directly on the first checking every thing w/ a straight edge and a square.
Bruce
Old May 03, 2012, 11:05 PM
joneswag is offline
Joined Apr 2012
Funny you should mention, parts not lining up. I had to move 2 of the spars. Going to build mine in he same sequence as you. This is my first big build, biggest up until now is a 36", so happy to be coached.
Old May 03, 2012, 11:45 PM
Baltimore MD USA
Joined Jan 2011
joneswag check report #16 to see the extra gussets that I added and where the hinge blocks go I added them after the two haves were glued together and used one thick piece of hard balsa.... much better for mounting your hinges and you don't have to drill through dry (hard) glue. just a small tip
ps I see your a kiwi Cool always wanted to go down there, I don't know if your last name is Jones but that's mine.
Bruce
Old May 04, 2012, 12:22 AM
Baltimore MD USA
Joined Jan 2011
I did some more on the mounting brackets and just about finished 8 of them and ground another swivel mount and rough out to blocks for the shafts so they can hook to the pin that goes through the mounting bracket.
Old May 04, 2012, 01:31 AM
PeterF is offline
PeterF's Avatar
Joined Nov 2004
Hi, I sort of follow this build because it is showing me how I should have done some things (aileron drive system etc.) on my build which is now flying. Have a look at my build log on RC Scale Builder - you will need to register to view but that is free.
http://www.rcscalebuilder.com/forum/...TID=14905&PN=1
The plane is a great build and flies well and you will enjoy it I am sure. You can always PM me with any questions.
Old May 04, 2012, 05:59 AM
Baltimore MD USA
Joined Jan 2011
joneswag.... Do you plan to build your wing in two pieces also?
Old May 04, 2012, 03:28 PM
motrio is offline
Find More Posts by motrio
Jersey, St Peter
Joined Feb 2012
Gonna stay with this blog Bruce.Looked at Petes.The amount of effort for a scratch build is great.For someone who has this amount of patience to create the parts you have made is enlightening.That is coming from a qualified engineer who worked on Rolls Royce Merlins!
motrio is offline Find More Posts by motrio
Old May 04, 2012, 03:38 PM
Baltimore MD USA
Joined Jan 2011
Not sure what your telling me motrio???
Sold For the Scale Builder: A Set of Brian Taylor Plans Vultee BT-13 W/Cowl & Canopy stevster Aircraft - Fuel - Airplanes (FS/W) 1 Apr 07, 2011 02:27 PM
Question Contact for Brian Taylor Plans pgleesonuk The Builders Workshop 4 Sep 13, 2006 09:48 AM
Brian Taylor Mosquito plans CraigO Scale Kit/Scratch Built 11 Nov 05, 2003 04:43 PM
Brian Taylor Mosquito FB Vl electrified TasMike Scale Kit/Scratch Built 0 Nov 05, 2003 05:32 AM
FS: 69" P-51 Brian Taylor plans and Parts Ken Lapointe Aircraft - Electric - Airplanes (FS/W) 1 Feb 05, 2003 06:57 PM
