Old Apr 27, 2012, 03:33 AM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Originally Posted by Willsonman View Post
Here, gentlemen, we see the true form the the term "scratch build." Way more ambitious than I would ever undertake and its a pleasure to see it progress. I want to drive down to the city to see this when its all done.
Willsonman ...You may have a bit of a wait befor I finish this bird
but more than welcome when ever you want to make the trip. still have a lot of details to add and several custom parts to make and I'm in no rush..
splinterz25 is offline Find More Posts by splinterz25
Old Apr 29, 2012, 07:27 PM
rupert the bear is offline
Find More Posts by rupert the bear
Joined Jun 2007
I wish i had your patience! what will operate the retracts ?
rupert the bear is offline Find More Posts by rupert the bear
Old Apr 29, 2012, 08:50 PM
Baltimore MD USA
Joined Jan 2011
rupert the bear... I want to use a retract servo from HiTec if I can, and there will be springs involved if you look close at the drawings you can see the spring. they are only showing it on one side this may need to be two springs one on each side but won't know this till I finish building one and running a mock up test.
Old Apr 30, 2012, 01:40 AM
PeterF is offline
Find More Posts by PeterF
PeterF's Avatar
United Kingdom, England, North York
Joined Nov 2004
Looking good - the original plane had very light weight wheels, I have the Unitracts set and they originally sold wheels weighing 3oz each and had one spring on each retract. They no longer sell such light weight wheels and I ended up with 2 springs per retract as the wheels I ended up with were around 5oz each.
PeterF is offline Find More Posts by PeterF
Old Apr 30, 2012, 06:35 PM
xfly-er is offline
Find More Posts by xfly-er
SOCAL
Joined Jul 2006
Wheels
Check the Kavan wheels from Sig.
http://www.sigmfg.com/cgi-bin/dpsmar...mb_02Wheels_01
5" are under 70gm (3 oz). If you do not have the adapter for a standard bicycle type pump you can get one at a bike shop for the small stems used on road bikes. Fits the Kavan threaded inflator.
Excellent work you are doing with regular tools. I am inspired!
xfly-er is offline Find More Posts by xfly-er
Old May 01, 2012, 10:35 AM
Baltimore MD USA
Joined Jan 2011
Thanks for the link.. xfly-er I was hoping to get diamond pattern for the wheels if I can find some light enough. So I made some more parts yesterday, but couldn't post because Comcast mistakenly unhooked my cable and I just got my service back. still have a ways to go but check out the progress.
Old May 01, 2012, 02:06 PM
Ken Lapointe is offline
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
You are doing the landing gear all wrong
You should be making at least 10 sets of everything so you can sell to the rest of us that dont have your talents
Every time I think about building this plane I change my mind because of the landing gear.
Your doing a fantastic job, well done
Ken Lapointe is offline Find More Posts by Ken Lapointe
Old May 01, 2012, 02:34 PM
PeterF is offline
PeterF's Avatar
Joined Nov 2004
xfly-er,
Thanks for the information, these will fit into the Mosquito I already have built - I used Sullivan SkyLite wheels at 5.4oz each, the Kavan ones are less than this for two wheels (2.6oz each) so I could swap out and save a few ounces, which will be welcome. The only thing is they are harder to find in the UK.
Peter.
Old May 01, 2012, 03:04 PM
Baltimore MD USA
Joined Jan 2011
Originally Posted by peterf View Post
xfly-er,
thanks for the information, these will fit into the mosquito i already have built - i used sullivan skylite wheels at 5.4oz each, the kavan ones are less than this for two wheels (2.6oz each) so i could swap out and save a few ounces, which will be welcome. The only thing is they are harder to find in the uk.
peter.
do either of you guys or anybody know what tread they ran on these birds? I have seen it w/ all kinds and the tail wheel is very strange also. Maybe it was what ever they had on hand? OH YEA IF SOME ONE HAD A C&C MILL THEY COULD DO THE PARTS FOR THIS VERY EASY AND SELL THEM AS A KIT. YOU WOULD NOT WANT TO PAY WHAT I WOULD ASK FOR THESE PARTS.
Old May 01, 2012, 04:32 PM
PeterF is offline
PeterF's Avatar
Joined Nov 2004
The tail wheel was very odd, it was self castering (not steerable) and the pattern was to prevent the wheel from shimmying, it had a sort of inverted V shape. A lot of the early photos show a square block tread, but I also have diamond block tread and circumferential grooves. I even have a photo of a museum exhibit with diamond treead on one wheel and grooved on the other.
Old May 01, 2012, 08:24 PM
Baltimore MD USA
Joined Jan 2011
FOR THOSE OF YOU THAT ARE WORRIED ABOUT WEIGHT I FOUND THESE WHEELS. click on tec notes for specs.
http://www3.towerhobbies.com/cgi-bin...18486&Q=1#tech
there less$$$ but solid foam..... I like the ones w/ air but want diamond or the square tread also cant seem to find any with both options.....Guess I will have to make the treads my self?
Old May 01, 2012, 09:19 PM
Willsonman is offline
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
I think a nice file will cut rubber ones nicely. You have made everything else so well I see this as a minor setback.
Willsonman is offline Find More Posts by Willsonman
Old May 02, 2012, 12:37 PM
Baltimore MD USA
Joined Jan 2011
axacto blade and the file for the diamond pattern but the square pattern would be much harder to dup.
Old May 02, 2012, 02:34 PM
PeterF is offline
PeterF's Avatar
Joined Nov 2004
The best wheels can be found at Glennis but very expensive and heavy I am led to believe but ultra scale and they do all the different tread patterns. These are wider than most, possibly would not fit into the Unitracts retracts but would probably fit into home made ones per the plan as the lower legs are not as thick as the Unitracts ones.
http://www.glennis.com/britishwarbirdgallery.htm then click on the detail gallery for the Mosquito.
Sold For the Scale Builder: A Set of Brian Taylor Plans Vultee BT-13 W/Cowl & Canopy stevster Aircraft - Fuel - Airplanes (FS/W) 1 Apr 07, 2011 02:27 PM
Question Contact for Brian Taylor Plans pgleesonuk The Builders Workshop 4 Sep 13, 2006 09:48 AM
Brian Taylor Mosquito plans CraigO Scale Kit/Scratch Built 11 Nov 05, 2003 04:43 PM
Brian Taylor Mosquito FB Vl electrified TasMike Scale Kit/Scratch Built 0 Nov 05, 2003 05:32 AM
FS: 69" P-51 Brian Taylor plans and Parts Ken Lapointe Aircraft - Electric - Airplanes (FS/W) 1 Feb 05, 2003 06:57 PM
