Old Apr 20, 2012, 08:08 AM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
thanks ...Ilkka I changed the bend in the wire and made sure that the bend was at the hinge line and it seams to work now but I think I still want a thicker music wire so there is no fludder.
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Apr 21, 2012, 05:37 PM
Baltimore MD USA
Joined Jan 2011
Alright it seams that the changes that I made to the music wire will work still may change the thickness so that means ordering some thicker wire the next time I place an order. I have plenty of stuff to work on now so I started to move on to bending the wire for the the FLAPS this is a much heaver wire and as I got started bending I broke my vice it wasn't very heavy duty so off to the store I went to get a new and better vice didn't want a big vice wanted to be able to do my work in the living room like always so found one after three stores but it had no jaws. So I striped the ones off of the old vice and mounted them on the new one. Needless to say the day was shot by the time I got that finished. I was able to work on the mount for the servo and finished drilling the holes in the first one and started to finish the second, maybe tomorrow I can get something accomplished.
Old Apr 21, 2012, 09:50 PM
Baltimore MD USA
Joined Jan 2011
Well I went ahead and remounted the AILERON servo bracket and bent the first wire for the FLAPS the wire is so hard and thick I had to heat each bend w/ a torch till RED HOT to achieve the bend now just need to cut the ends to length then make the brass swivel point & mounting tabs.
Old Apr 24, 2012, 05:53 PM
Baltimore MD USA
Joined Jan 2011
Well even though it looks like I got the bend to match the drawing well that's WRONG the drawing is not very clear the side profile is very hard to see and understand but by looking at another build I can see what I need to achieve. the wire I have been trying to use is a bit on the heavy side so I will order some more suitable wire. So I shifted over to the landing gear to see what I could get accomplished went and bought a small grinder to help make these parts and got started on the locking parts and was making good head way but when I tried to drill the hole for 2-56 bolt I broke about 6 drill bits so far I must have hardened the steal when grinding, so I will go look for some better drill bits maybe carbide if I can find some,so there's not too much to show but look at what I have so far.
Old Apr 24, 2012, 08:53 PM
Baltimore MD USA
Joined Jan 2011
Where did all of the people that were flowing this thread go ?
Old Apr 24, 2012, 09:15 PM
lgarber is offline
Find More Posts by lgarber
castle rock, colorado
Joined Jun 2010
Still here Bruce. Just awe struck by your skills! Being a red-neck, my vocabulary is rather limited. I don't have words for what I observe you doing. keep going, we're watching.
Linn
lgarber is offline Find More Posts by lgarber
Old Apr 24, 2012, 09:53 PM
Willsonman is online now
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
Still watching
Willsonman is online now Find More Posts by Willsonman
Old Apr 25, 2012, 12:41 AM
rupert the bear is offline
Find More Posts by rupert the bear
Joined Jun 2007
Rest assured we are still here sorry for the lack of recent feedback
Keep up the good work
rupert the bear is offline Find More Posts by rupert the bear
Old Apr 25, 2012, 01:19 PM
Baltimore MD USA
Joined Jan 2011
Thanks guys ...I haven't been making great strides on this build like I had wanted to this is the most involved build I have done as of yet Brian's methods are very involved but thanks for every bodies support.
Old Apr 25, 2012, 01:31 PM
motrio is offline
Find More Posts by motrio
Jersey, St Peter
Joined Feb 2012
Still watching and learning.Getting ready to start my build!
motrio is offline Find More Posts by motrio
Old Apr 25, 2012, 10:44 PM
RobMason is offline
Find More Posts by RobMason
Plane Nuts
RobMason's Avatar
United States, NC, Etowah
Joined Oct 2009
Still here. waiting to see what you are going to do with the gear and then mabye trying to convince you to make me a set Just kidding. Switched jobs and have been busy training but keeping up with the thread. Looka great so far.
RobMason is offline Find More Posts by RobMason
Old Apr 26, 2012, 02:31 AM
Design75 is offline
Find More Posts by Design75
What goes up, must come down
Design75's Avatar
The Netherlands, UT, Amersfoort
Joined Mar 2012
I joined this forum a short while ago, but am watching your builds carefully and with much appreciation. I just restarted my Brian Taylor 69" Spitfire XIV, after my cat destroyed the first attempt with her claws 6 years ago
Design75 is offline Find More Posts by Design75
Old Apr 26, 2012, 12:29 PM
Won2Race is offline
Find More Posts by Won2Race
Won2Race's Avatar
United States, MA, Boston
Joined Jun 2006
is that music wire?
Won2Race is offline Find More Posts by Won2Race
Old Apr 26, 2012, 04:44 PM
Baltimore MD USA
Joined Jan 2011
Thanks to every body that responded I thought I had lost every bodies interest but glad you all are still there. Yes umdpru that is music wire and it's very hard, what I had to do to drill through it was aneal the part I needed to drill through, this means to heat the steal red hot and NOT cool of quickly let it air cool this softens the metal enough to be able to drill through but it's still very hard. So I was able to get some more parts cut out and ground to shape, and a set screw and two bolts added. it's slow going but it can be done so here's what I have so far.
Old Apr 26, 2012, 08:10 PM
No Hangar Queens!
Maryland
Joined May 2009
Here, gentlemen, we see the true form the the term "scratch build." Way more ambitious than I would ever undertake and its a pleasure to see it progress. I want to drive down to the city to see this when its all done.
Sold For the Scale Builder: A Set of Brian Taylor Plans Vultee BT-13 W/Cowl & Canopy stevster Aircraft - Fuel - Airplanes (FS/W) 1 Apr 07, 2011 02:27 PM
Question Contact for Brian Taylor Plans pgleesonuk The Builders Workshop 4 Sep 13, 2006 09:48 AM
Brian Taylor Mosquito plans CraigO Scale Kit/Scratch Built 11 Nov 05, 2003 04:43 PM
Brian Taylor Mosquito FB Vl electrified TasMike Scale Kit/Scratch Built 0 Nov 05, 2003 05:32 AM
FS: 69" P-51 Brian Taylor plans and Parts Ken Lapointe Aircraft - Electric - Airplanes (FS/W) 1 Feb 05, 2003 06:57 PM
