Old Dec 16, 2011, 11:17 PM
Busted_wing is offline
Find More Posts by Busted_wing
United States, MN, St Paul
Joined Dec 2011
Tilt rotor fixed wing (Osprey)
Does anyone make anything remotely similar to an osprey or am I looking at building one? If it needs to be built, is there a way to use a quadcopter board? Can it be turned off for foreward flight?
Busted_wing is offline Find More Posts by Busted_wing
Old Dec 17, 2011, 04:01 AM
SLATYE is offline
Find More Posts by SLATYE
Joined May 2010
There's this. The price probably isn't too bad for the amount of work that has gone into it, but it's very expensive compared to similarly-sized helicopters.
SLATYE is offline Find More Posts by SLATYE
Old Dec 17, 2011, 09:32 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it Ň>
leadfeather's Avatar
Joined May 2006
This one may be "remotely" similar. http://www.yellow-bl.de/flightsystems.html
[/URL]
YELLOW-BL VTOL RC Tiltrotor TILT 607 (1 min 6 sec)
leadfeather is offline Find More Posts by leadfeather
Old Dec 17, 2011, 11:40 AM
v22chap is offline
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
Busted wing
The rotormast V-22 has the onboard controller already with it ...along with 6 carbon fiber rotor blades .. scale 3 bladed heads and the modified conversion servos .
Yes it is expensive (not any more than the trex tandem when it first came out ) where else are you going to get a true scale V-22 that does the full airplane conversion and does it as if you were just flying a normal helicopter from hover to fast forward flight mode .... the controller does all the mixing and changing servos and gyros around for you so all you do is fly it like a single rotor helicopter !!!!
This bird is engineered by Tom Mast who is not only a modeller at heart ,,but also a Bell Textron engineer ... believe you me it is not only true to scale from company CAD files but also licensed by Bell Beoing and a true engineering marvel .
Go to his website and take a look around . rotormast.com
v22chap is offline Find More Posts by v22chap
Old Dec 18, 2011, 03:05 AM
Joined Dec 2011
Wow, that rotomast is extremely cool, now ifonly I had that kind of change. Its on my wish list now
Old Dec 18, 2011, 08:46 AM
v22chap is offline
v22chap's Avatar
Joined Jan 2003
Yes it is really awsome ,, and to me it is really cheap ... once you consider how much money and time I put out in the last 28 yrs that I have been trying to build one and never got all the way to airplane conversion ... even leads foam birds cost a pretty good amount .VTOL's are not cheap .
Old Dec 21, 2011, 04:12 AM
BleskCZ is offline
Find More Posts by BleskCZ
Česká republika, Zlínský, Vsetín
Joined Aug 2011
Hi, this is my solution:
http://www.rcgroups.com/forums/showthread.php?t=1496110
I continues to develop and over time I also work out a lot of valuable V-22. : Cool:
BleskCZ is offline Find More Posts by BleskCZ
Old Dec 24, 2011, 04:08 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
The Twins fuse
http://www.rcgroups.com/forums/showthread.php?t=1124466
and later a Tri Twins fuse
http://www.rcgroups.com/forums/showthread.php?t=1438491
This full fuse foamy Cargo plane can be adapted to look like an Osprey easily.
What controller are you planning to use ?
I am currently flying a KK board from Korea. as a Quad and it seems to be OK.
It also has a SW config for Osprey type controls.
I'll keep watching.
Bob
birdofplay is offline Find More Posts by birdofplay
Old Jan 31, 2012, 12:15 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Does a foamy Osprey interest anyone ?
It's my next project
I'm planning on using the Minsoo kim Blue Board or the Blackboard , whatever.
I have a blackboard working very nicely on an X Quad.
Quad X-Copter flight at School yard (4 min 28 sec)
Osprey Nacelles will only be +&- 45 deg due to servo travel unless I can coax a bit more out of them with TX settings.
Rather than mess with intricate and delicate swivels and mechanisms,
I am going to mount large servos on the ends of the wing and mount the servo DIRECTLY to large circular output arms.
Part of my K.I.S.S. philosophy.
In about a week or so I'll have enough parts to test everything.
The prop adapters from HK were BOTH Eccentric and unusable ! :>(
What did I expect for $2 ?
But how can they screw up even simple lathe work ???
More l8r
Bob
Old Jan 31, 2012, 05:26 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Interesting project.
Because the lathe they used cost 2$ also.
RCvertt is offline Find More Posts by RCvertt
Old Jan 31, 2012, 06:57 AM
v22chap is offline
v22chap's Avatar
Joined Jan 2003
good one RC
bird of prey ... you might have something there !!!!
Old Jan 31, 2012, 08:25 AM
Winging it Ň>
Joined May 2006
http://vimeo.com/35895595
More l8r
Bob
Nice project.
A servo stretcher might help get the tilt you need.
Old Jan 31, 2012, 10:08 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
wow ... you guys are over here too !
Dont I mostly see you in Scratchbuiltfoamys ?
Regardless, Good one on the stretcher !
I'm going to try to see how far I can get with the TX throw adjustments.
If no joy I will give the SC stretcher a try.
I'd be happy with 130 deg total.
I ordered som Prop adapters from Innov8tive
BUT I might try to straighten out those $2 wonders on m y Lathe !
More l8r
Bob
Old Jan 31, 2012, 11:49 AM
v22chap is offline
v22chap's Avatar
Joined Jan 2003
Bob
you can also remove the servos pot and remotely connect it to the tilting nacelles with a mechanical advantage ( servo wheel on the pot and rod connected lower than attachment point to the big tilt arm ) and this will get a full 90 degree throw really easy from any servo .
Old Jan 31, 2012, 01:48 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Oh that sounds like way too much work !
Elegant and all but messy mechanisms again :-(
I'm only doing a Foamy so I figure I have some latitude
B'sides my quad, with a Little tilt flys forward PLENTY fast enough, ya know ? ! :-)
SO I am thinking that the Osprey will do fine if only +&- 45.
But I will still try to get more.
One TX allows +&=140% so it'l be close E NUF !
Bob
Question k kuk board,osprey,tilt motors 90° nadine Multirotor Talk 4 Nov 12, 2011 07:55 AM
Gallery Tandem/Tilt-Wing 4 Rotor Heli Tuner Coaxial Helicopters 44 Jan 23, 2011 08:24 PM
Discussion Help! Building Giant Tilt Wing/Rotor gyrodyne21 Giant Electric Planes 3 Nov 18, 2010 02:33 PM
Discussion Quadra-Plane "4 Rotor Tandem-Tilt-Wing" Tuner VTOLs 5 Jan 10, 2006 03:57 PM
Tandem/Tilt-Wing 4 Rotor UAV Tuner UAV - Unmanned Aerial Vehicles 1 Nov 03, 2005 06:19 PM
