Old Dec 23, 2011, 07:18 PM
Stumblebee is offline
Find More Posts by Stumblebee
Stumblebee's Avatar
Port Coquitlam, BC CANADA
Joined Jun 2009
I just got the email today from FMA on the MPA. Looks like I'm buying one as soon as the web site confirms that they are on the shelf. It will sure clear up a lot of clutter on my bench when I charge my lipos. The 1S connectors were a nice touch.
Stumblebee is offline Find More Posts by Stumblebee
Old Dec 23, 2011, 10:28 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Hi:
You must have missed the first one that went out on 12/16/11 then?
http://www.revolectrix.com/new_appli...t12.16.11.html
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Jan 03, 2012, 04:30 PM
chainlink is offline
Find More Posts by chainlink
Free State of Lavaca
Joined Nov 2006
just curious - can you 1s off of a deans w/o a balance connection? Not all 1s are micro...
I guess I am just trying to figure out what adapter would be needed. I know assumptions are dangerous. I don't know if the 1s pack can be charged as a "balanced" pack without connecting to the balanced lead (or if it would have to be charged as an unbalanced pack with an amp limit). Likewise, if I had to have a balanced lead, I don't know if I could make an adapter and grab either the first 2 of the jst pins or the outer two and cheat.
chainlink is offline Find More Posts by chainlink
Old Jan 03, 2012, 06:02 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Tim can verify but I expect the answer is yes.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jan 03, 2012, 07:44 PM
Tim Marks's Avatar
Joined Mar 2008
Hi:
Yes, the preferred method would be to connect to one of the Deans. The Deans are not related to the balance ports in any way. You'd need to use an unbalanced preset if using a Revolectrix charger/battery workstation.
Tim Marks
Old Jan 11, 2012, 02:07 PM
HansAuf is offline
Find More Posts by HansAuf
Pass me some zip-ties!
HansAuf's Avatar
United States, FL, Gainesville
Joined Nov 2006
Any idea when these will start shipping? My order still says "Pending Fulfillment".
HansAuf is offline Find More Posts by HansAuf
Old Jan 11, 2012, 02:10 PM
Stumblebee's Avatar
Joined Jun 2009
I got an email yesterday stating that my order has been shipped. Just waiting for the post office.
Old Jan 11, 2012, 05:56 PM
Jamie Marks is offline
Find More Posts by Jamie Marks
Joined Jan 2002
Hi,
Send an e-mail to jamie@fmadirect.com with your name and SO number. I will give you the best estimate I can as to when your order will ship based on where it sits in the queue.
Regards,
Jamie Marks
FMA Direct/REVO USA
Jamie Marks is offline Find More Posts by Jamie Marks
Old Jan 11, 2012, 07:30 PM
HansAuf is offline
HansAuf's Avatar
Joined Nov 2006
Thanks Jamie. Email sent.
Old Jan 12, 2012, 10:43 AM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
Count me as another Power Pole user that would like bare wires that I can just crimp the PP's on to before ever firing it up. I don't want to make 6 Deans to PP jumpers either.
aerosheldon is offline Find More Posts by aerosheldon
Old Jan 12, 2012, 11:20 AM
wjbender is offline
Find More Posts by wjbender
Learnin mo ever day
United States, NJ, Tinton Falls
Joined Jul 2007
Looks like converters are the only option now. that is what I am doing anyway. A bare wire option would be good.
wjbender is offline Find More Posts by wjbender
Old Jan 16, 2012, 05:11 PM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Is there a limit in voltage difference using same cell count packs that can be connected? i.e if one 4s battery has 20% and a 2nd has 80% and both are connected to the board.
topgearuk is offline Find More Posts by topgearuk
Old Jan 16, 2012, 05:37 PM
Tim Marks's Avatar
Joined Mar 2008
Hello:
As far as the MPA goes, it won't be possible to cause any damage to the unit, the wiring, or the charger to which it is connected by intereconnecting batteries of vastly different charge states.
However, as far as the batteries go, it's a good idea for the packs to be of similar states of charge. There are a ton of threads in RCG and other forums that discuss this topic. Our observations have shown that no matter what the state of charge, the initial surge currents which flow from a "full" battery to a "dead" battery are not as large as one might think, and the duration of high-current, un-regulated "charging" generally fairly short; e.g., even at 80% and 20% states, you're likely looking at 10-20A for a few seconds, followed by 5A-10A for 1-3 minutes. Whether that's enough to damage your batteries depends on too many factors to discuss here. It seems obvious that a 10C-charge-capable LiPo could withstand it better than a 1C capable LiPo.
Most would agree that if the individual cells are within 0.1V, it's a good rule of thumb and safe for pretty much any LiPo battery, although that value could be a bit overly contstraining, in my opinion.
Hope this helps!
Tim Marks
Old Jan 16, 2012, 05:47 PM
topgearuk's Avatar
Joined Dec 2003
Thanks for your reply, It does help a bit, I understand about cell voltage being very close when not using you MPA.. This is what I do now.. And I always make sure my batteries are normally with-in 0.1v..
But the impression I got was if using your MPA it would limit the max cross flow between batteries to 1A anyway?? or have I got that wrong?
Old Jan 16, 2012, 05:56 PM
Tim Marks's Avatar
Joined Mar 2008
Hi:
Good question. The MPA will limit the flow of current on the balance wires to 1A, but as soon as you connect the main pack leads together, the current flow is only limited by the internal resistance of the batteries (which is very low, and varies from chemistry-to-chemistry). There is no other protection, thermal fuse or otherwise on your main pack leads. Current always chooses the path of least resistance.
So this is why the MPA will protect all of the balance wires, and your main pack wires will always be able to handle many times the current surge while the paralleled packs equalize. So the only remaining question is, how well can your LiPos tolerate, e.g., 5C or 10C charge for 1-3 minutes. I think most good quality LiPo these days won't break a sweat on it. So it's likely peoples' concern over this topic is over-stated, IMO.
Tim Marks
Sold FMA/Revolectrix CellPro Multi 4 Charger, with Extras ***New Price*** Woody_99 Aircraft - Electric - Batteries & Chargers (FS/W) 7 Aug 30, 2011 04:20 PM
Discussion Parkzone Announces New SE-5a Dale1957 Electric Plane Talk 4 May 27, 2011 02:18 PM
Discussion FMA/Revolectrix Announces U.S. Warehouse Jamie Marks FMA Direct 6 Apr 25, 2011 06:21 AM
For Sale New Cellpro Revolectrix Lipo Battery Pack 3300 Broken Wings Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 16, 2010 09:00 PM
Sold New Cellpro Revolectrix 11.1v 2200mah 25c lipo cryhavoc38 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 03, 2008 12:29 PM
