Old Dec 19, 2011, 12:21 PM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
I have a parallel board (different brand) with male deans connectors on it. I'm pretty careful, and leave the caps on the unused connectors, but still managed to short out a deans with my wedding ring one time. What happened was I unplugged the first pack, and then placed my hand over the board to hold it down while I removed the other packs; thats when it shorted.
Luckily I didnt' get hurt and it just made a couple burrs on my ring. (wife wasn't too happy. )
teookie is offline Find More Posts by teookie
Old Dec 19, 2011, 12:57 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Fortunately the MPA has fuses on the charge leads that will trip.
Gregor99 is offline Find More Posts by Gregor99
Old Dec 19, 2011, 08:59 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Originally Posted by Gregor99 View Post
Does it come with T-plug/Deans protectors?
I always thought the ParaBoards and parallel cables with exposed, and hot male Deans were a risky idea.
Gregor:
Yes, MPA will ship with Deans boots.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Dec 20, 2011, 02:15 PM
ggroyal1117 is offline
Find More Posts by ggroyal1117
ggroyal1117's Avatar
Norcross, GA
Joined Dec 2005
I preordered one yesterday for my powerlab 6.
ggroyal1117 is offline Find More Posts by ggroyal1117
Old Dec 20, 2011, 02:58 PM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Tim,
Can you tell us more about the poly fuses? Are they wired between the cell and gnd? Also what is the amp rating? I suspect very little since the charger doesn't balance at more than an amp or two.
Schu
akschu is offline Find More Posts by akschu
Old Dec 20, 2011, 03:02 PM
Tim Marks's Avatar
Joined Mar 2008
Originally Posted by akschu View Post
Tim,
Schu
Hi:
In series with each cell in the pack. Rated around 1A.
Tim Marks
Old Dec 21, 2011, 12:06 AM
Gregor99 is offline
Seattle
Joined Sep 2007
Looks good Tim, but my batteries are thunder power. You have a TP version in the works?
For those that want a TP version, here is another option. JST-XH to TP adapters, $3.79 for 5. This is for 6s. There are others for 3s, as well as for PQ/Hyperion
http://www.hobbyking.com/hobbyking/s...idProduct=9919
Old Dec 21, 2011, 01:07 AM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Yea, I know, I have some of those now, but they are really ugly and a pain to deal with. If you leave them connected then you have 42 of the little buggers hanging off the board.
Another problem with the TP batteries is that they use the same connector for 2-3 4-5 and split connectors for 6-8.
Perhaps I'll just quit buying them and switch to gens ace/billowy power since they are also good batteries, a bit cheaper and don't have stupid balance taps.
Another option would be to convert my batteries to XH, but that's a pain too.
Old Dec 21, 2011, 01:43 AM
Gregor99 is offline
Seattle
Joined Sep 2007
Just bought my first set of Thunder Power packs. Some 6s 4400 65c for my 700e. Nice packs, but those connectors are a pain. Node wires are hard PVC and very short. I wanted to replace the connectors, but I've been frustrated with larger (6s) JST-XH connectors. They use a friction connection and there's not easy way to get them apart without tugging on the wires. Also thier headers are designed for board mount and don't work well just soldering wires directly too them.
I finally settled on the Hyperion/PQ connectors as they use clip to secure the connection. The headers (female ends) are designed to work with wires, instead of soldered to a board. Connection and disconnection is easy. Pin spacing is compatible with the CellLog. The raw connectors are $3 for 4 of them. I bought a crimper a RS and have been going to town.
http://www.allerc.com/hyperion-eos-l...de-p-4316.html
Old Dec 21, 2011, 02:15 AM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Screw it, I'm going to convert my TP batteries to XH connectors. The pins and housings are dirt cheap and I can order a die for my crimp tool that will make nice crimps with minimal effort. I'm sick of dealing with adapters and and multiple balance boards. Besides, the TP balance connectors are completely stupid, and XH is the clear standard.
The deans doesn't bother me since I use deans for 4s and smaller, and for my larger packs I use EC5, but I don't mind having adapters for those since there is only 6 ports.
Old Dec 21, 2011, 02:31 AM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Gregor99, you posted before I did.
I agree that the HYP/PQ connectors are the nicest but getting balance boards and pigtails for them is a pain. They just aren't anywhere near as popular as the XH or even the TP.
Personally I don't mind tugging on the wires a little bit in this application since a well crimped connector will stand up to a ton of abuse, but your right, I shouldn't do that.
Pick your poison I guess.
Oh, before I forget, check out these batteries:
http://hicountryhobbies.com/index.ph...roducts_id=134
I run two 4s packs in my 600e and they are stupid powerful. I'm running the scorpion 4025/890 on a 15t pinion and my setup hits 3800 watts for a split second on the data logger with fast pitch pumps.
Old Dec 21, 2011, 07:29 AM
teookie is offline
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
You guys seen these?
http://epbuddy.com/index.php?main_pa...roducts_id=228
Never pull on wires again.
Old Dec 21, 2011, 07:38 AM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
As was pointed out elsewhere, just proof that an inappropriate/inadequate connector is being used.
SteveM732 is offline Find More Posts by SteveM732
Old Dec 21, 2011, 11:08 AM
Gregor99 is offline
Seattle
Joined Sep 2007
More power to you! I'm using the Radio Shack crimp tool for $10 and it works. Not great, but it works. After I got the hang of it, I wondered what took me so long to do this.
Old Dec 21, 2011, 01:48 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Yea, I already have a proskit crimp tool for doing PIDG connectors and coax, so it wasn't a big deal to pick up an additional die. I got the one for power poles as well as the RJ45 die, so I can pretty much crimp anything I deal with, with a single tool.
schu
Sold FMA/Revolectrix CellPro Multi 4 Charger, with Extras ***New Price*** Woody_99 Aircraft - Electric - Batteries & Chargers (FS/W) 7 Aug 30, 2011 04:20 PM
Discussion Parkzone Announces New SE-5a Dale1957 Electric Plane Talk 4 May 27, 2011 02:18 PM
Discussion FMA/Revolectrix Announces U.S. Warehouse Jamie Marks FMA Direct 6 Apr 25, 2011 06:21 AM
For Sale New Cellpro Revolectrix Lipo Battery Pack 3300 Broken Wings Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 16, 2010 09:00 PM
Sold New Cellpro Revolectrix 11.1v 2200mah 25c lipo cryhavoc38 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 03, 2008 12:29 PM
