Old Jan 29, 2013, 05:40 PM
Jamie Marks is offline
Find More Posts by Jamie Marks
Joined Jan 2002
Hi Grimbeaver,
I can confirm what Jim says. The REVO BAG doesn't accomodate the PL6 or PL8 with an MPA. We do, however, sell a larger bag, PN: REVOBag-Trans. This bag is designed to carry a transmitter, but it will accommdate the PL6 or PL8 with an MPA nicely, with a some room to spare for additional adapters or a lipo or two. I hadn't actually thought of the transmitter bag for this use until I read your post and I checked it out. I think we will modify the product text on the site to specify this. Here is a link on the REVO USA site to the REVOBag-Trans, http://www.usastore.revolectrix.com/...nsmitter-Bag_2
As for the bare wire MPA, we have stock at the REVO USA site. If you are looking at the REVO Singapore site, it is out of stock and more inventory is scheduled to be available next week.
Jamie Marks
REVO USA
Jamie Marks is offline Find More Posts by Jamie Marks
Old Jan 29, 2013, 09:36 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Thanks maybe I'll give that a try. I was looking at Singapore because I needed a few lipos. But if it's available in the US I'll have to check if it makes more sense shipping wise to order from there.
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 30, 2013, 03:52 AM
traxx de maxx is offline
Find More Posts by traxx de maxx
traxx de maxx's Avatar
uk
Joined Nov 2010
Originally Posted by Jamie Marks View Post
Hi Grimbeaver,
Sweet
traxx de maxx is offline Find More Posts by traxx de maxx
Old Feb 04, 2013, 01:42 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Is there any advantage/disadvantage to using the MPA over the daisy chain parallel boards? I am undecided which way to go when I order my PL6.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Feb 04, 2013, 02:36 PM
Snowflake6515 is offline
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
I own two PL-8 units, each with its own MPA board.
I prefer the MPA board because of the individual fusing (power side is fused, balance side has re-settable fuse-links).
I run mostly 4S - 6S 5000mah batteries and two at a time as I run 8S - 12S birds.
I feel very comfortable with all the protection built-in the MPA boards.
Just my $0.02.
Michael
Snowflake6515 is offline Find More Posts by Snowflake6515
Old Feb 04, 2013, 06:44 PM
BVH is offline
BVH
Find More Posts by BVH
BVH
BVH's Avatar
United States, CA, Pismo Beach
Joined Dec 2006
The MPA is such a clean and neat solution. If you're an organized person who likes neatness, you'll want the MPA over the individual boards.
BVH is offline Find More Posts by BVH
Old Feb 04, 2013, 07:35 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
If you buy six daisy chained boards you will spend more than the cost of an MPA.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Feb 04, 2013, 11:14 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
.......and you haven't even started buying the fused main leads yet......
Gregor99 is offline Find More Posts by Gregor99
Old Feb 05, 2013, 01:41 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I think it really depends on how many packs you plan to parallel charge at once.
Ohmic is offline Find More Posts by Ohmic
Old May 09, 2013, 03:05 PM
bearclaw is offline
Find More Posts by bearclaw
Heli Pilot
bearclaw's Avatar
Joined Dec 2012
Tim,
I am trying to get the mpa board connected to a hyperion 1420 and have a couple of questions.
As I will never be charging more than a 6 cell pack, I wired the balance interconnect to use only the A balance connect on the Hyperion Charger. I wired the pins starting with negative on both sides 1-8. However when testing everything out using a 3 cell pack, I am getting a little over 2 volts on cell 1, nothing on cell 2, and 4.2 volts on cell three. Once I plug the mains in, I don't get any reading on any cells.
What am I doing wrong?
MPA Balance end: Wires 1-8 from negative side like this (---87654321)
Hyperion Balance end: Wires 1-8 like this (87654321)
I can post a pic if that would help.
bearclaw is offline Find More Posts by bearclaw
Old May 09, 2013, 03:10 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Please do. That would make it much easier. HiRes pic of both ends of your cable, please.
Old May 09, 2013, 03:27 PM
bearclaw is offline
Heli Pilot
bearclaw's Avatar
Joined Dec 2012
Description:
Description:
Old May 09, 2013, 03:51 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Your pin connections at the connectors look good to me. Next step I would take is use an ohm meter and check for continuity pin by pin from one connector to the other (pin 1 to pin1, then pin 2 to pin2, and so on). Verify all pins have connectivity and there are no wires that are swapped.
Old May 09, 2013, 04:01 PM
bearclaw is offline
Heli Pilot
bearclaw's Avatar
Joined Dec 2012
On it. Wow, had a friend solder the wires, and one was bad. Resoldering now, and will update when done.
Thanks Gregor, sometimes its the little things you take for granted.
Old May 09, 2013, 04:11 PM
bearclaw is offline
Heli Pilot
bearclaw's Avatar
Joined Dec 2012
That was it! The wire for pin 2 had a bad solder joint! Gave me all sorts of problems. Fixed it and everything works well, all the way up to 6 cells.
The next thing to tackle is adding the wires to the FMA balance adaptor to hook up bank B on the Hyperion to charge up to 8 cells.
Sold FMA/Revolectrix CellPro Multi 4 Charger, with Extras ***New Price*** Woody_99 Aircraft - Electric - Batteries & Chargers (FS/W) 7 Aug 30, 2011 04:20 PM
Discussion Parkzone Announces New SE-5a Dale1957 Electric Plane Talk 4 May 27, 2011 02:18 PM
Discussion FMA/Revolectrix Announces U.S. Warehouse Jamie Marks FMA Direct 6 Apr 25, 2011 06:21 AM
For Sale New Cellpro Revolectrix Lipo Battery Pack 3300 Broken Wings Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 16, 2010 09:00 PM
Sold New Cellpro Revolectrix 11.1v 2200mah 25c lipo cryhavoc38 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 03, 2008 12:29 PM
