Old May 14, 2012, 07:43 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Originally Posted by BVH View Post
If I remember correctly, my PL8 begins limiting output when it reaches 325 - 350 Watts or so when using my Iota 12V, 55 Amp supply. Low voltage is the problem, not the Iota's Amp capacity. The Iota is working at 14.4V or so when maxed out.
How long ago was that ? Back when the PowerLab 8s first became available and a buch of users were rying different power supplies with it there were many power supplies which had issues. It was found that many had very poor regulation with the PL8 due to the way that it changes the load very fast and often. Some added large Caps. to smooth out the ripples,some went to other power supplies and FMA modified the firmware to help out. Those of us using server power supplies did not have any power supply issues that I am aware of.
On line power calc.
http://www.revolectrix.com/Calculators_main.htm
Charles
Old May 16, 2012, 08:57 PM
Geffect is offline
Find More Posts by Geffect
Joined May 2010
MPA board
Ive just purchased a MPA board with the fly leads and have soldered EC5 connectors onto the leads..
When using the MPA board to charge my 6S lipos the IR reading is really high (e.g. 24ohms with 4packs)... There is nothing wrong with the packs as i get a correct reading if i charge them using my old parallel charge/balance leads or charge the pack on its own..
Should I be worried about this high reading on the MPA board? Could this cause issues if its giving false high readings on cell 6?
Geffect is offline Find More Posts by Geffect
Old May 16, 2012, 09:21 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
What charger are you using?
Gregor99 is offline Find More Posts by Gregor99
Old May 17, 2012, 06:52 AM
Geffect is offline
Joined May 2010
Originally Posted by gregor99 View Post
what charger are you using?
pl8.
Old May 17, 2012, 11:08 AM
Gregor99 is offline
Seattle
Joined Sep 2007
pl8.
If you are not already on firmware 3.31, upgade and report your results.
Old May 18, 2012, 02:02 PM
falcon7a is online now
Find More Posts by falcon7a
I came, I saw, I went away
falcon7a's Avatar
United States, IL, Lombard
Joined Dec 2006
When parallel charging with the MPA, I noticed that the PL6 doesn't give an error if the number of batteries connected to the MPA does not match the number of batteries I select in the PL6. For example, I can connect 2 batteries to the MPA and the charge will charge them even if I select No to parallel charging. Is this a safety issue? I'm new to parallel charging so am trying to understand the dos and don'ts with the MPA. Thanks.
falcon7a is online now Find More Posts by falcon7a
Old May 18, 2012, 02:09 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Well, it could be a safety issue if you erred on the high side, but as you are entering "no," you are erring on the low side, so it is fine.
When you enter the number of batteries, the charger simply accounts for that number in fixing amperage.
So, if you enter "no," it will treat the entire board as "one" battery.
Now, here is where you could get into trouble: fitting only one battery, answering with a high multiplier, like 6, which I suppose would cause the current to get too high-just a guess.
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old May 18, 2012, 02:34 PM
falcon7a's Avatar
Joined Dec 2006
I would have assumed that too for all charges except Cellpros. I'm assuming that there is some safety feature built into Cellpro chargers that would detect any anomalies caused by a very high charge rate and would therefore adjust automatically. I have no plans to misuse the charger to check this but I'm simply curious to the effects of what would happen if the wrong multiplier is used.
Old May 18, 2012, 02:44 PM
Greenland
Joined Mar 2012
We'll have to wait for Tim or Charles to answer that query!
Old May 18, 2012, 03:27 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
There's no way for the PL 6 or 8 to know that you "lied" to it about the number of batteries.
When charging in parallel, six 1000mAH cells in parallel behave like a single 6000mAHr cell.
Alan Hahn is offline Find More Posts by Alan Hahn
Old May 18, 2012, 03:35 PM
Greenland
Joined Mar 2012
Agreed, but that does not (1) feed the bulldog, nor (2) answer this guy's question.
Old May 18, 2012, 04:02 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Hi:
If you tell the PL you are charing multiple packs in parallel, but you only have one pack connected, there is no way for the PL to determine that there is only one pack connected. It will charge the pack at, e.g., n * Preset charge rate, where n = the number of P you entered prior to starting the charge. There is no way for the PL to tell the difference between 1P and 2P or 6P if you do not enter the number correctly. It's really not that different from the fact that the PL can not distinguish between chemistries. That's why we have the VERIFY CHEMISTRY screen pop up before the charge process begins. Guess we could also offer a verify "P" count, but pretty soon it's going to take 20 button presses to start a charge which is not a good thing.
Only way around this would be to specify 1P always and select one of the AUTO charge rates.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old May 18, 2012, 04:15 PM
falcon7a's Avatar
Joined Dec 2006
Makes sense, thank you. I will be careful and will ensure that I select the right P.
If I don't want to use the Auto charge rate, should I simply manually set the maximum charge that the smallest battery connected to the MPA can take? So if I like to charge at 3C and I have 2 2,000mah and 2 5,000mah connected (same cell count), I should select a manual charge rate of 6amps (3C x 2,000mah)?
Old May 18, 2012, 04:20 PM
Greenland
Joined Mar 2012
Hm.
Old May 18, 2012, 06:47 PM
Gregor99 is offline
Seattle
Joined Sep 2007
If you have two 2000 and two 5000 packs all connected in parallel, you effectively have a 14000 pack. To charge this combination at 1c would 14 amps, to charge at 3c would be 42 amps. As to how the current would be divided between packs is dependant on the IR and condition of the pack. In general larger packs have lower IR and will experience current proportional to thier size, and relative to the other packs in parallel. For instance the 5000 packs should experience a little more than twice the current that the 2000 packs are experiencing.
As there is no intelligent control over the current distribution of packs in parallel, the actual results may vary depending the specific packs connected. This one of the reasons for the guide line to parallel charge packs of similar size. Though not a requirement it can produce better results. When in doubt use a high quality cell checker to check the packs after the charge. As soon as the charge cycle has completed, disconnect the packs from the MPA and check thier voltage. If all packs are within acceptable norms, you are fine.
Sold FMA/Revolectrix CellPro Multi 4 Charger, with Extras ***New Price*** Woody_99 Aircraft - Electric - Batteries & Chargers (FS/W) 7 Aug 30, 2011 05:20 PM
Discussion Parkzone Announces New SE-5a Dale1957 Electric Plane Talk 4 May 27, 2011 03:18 PM
Discussion FMA/Revolectrix Announces U.S. Warehouse Jamie Marks FMA Direct 6 Apr 25, 2011 07:21 AM
For Sale New Cellpro Revolectrix Lipo Battery Pack 3300 Broken Wings Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 16, 2010 10:00 PM
Sold New Cellpro Revolectrix 11.1v 2200mah 25c lipo cryhavoc38 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 03, 2008 01:29 PM
