Espritmodel.com Heli Air
This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Oct 23, 2012, 03:12 PM
Pascal06's Avatar
France, PACA, Peille
Joined Sep 2011
Originally Posted by Joespeeder View Post
Hi,
mine just ordered from YTInternational...at discount price !
Thank you guys !
Pascal06 is offline Find More Posts by Pascal06
Old Oct 25, 2012, 05:49 PM
Joined Jul 2010
The komet (Jetpower 2012) some posts above is build from Peter Maissinger.
He lives in czech and owns a flying field. And he builds fine models, Focke Wulf Flitzer, Heinkel Salamander and the Komet.
http://www.modelcity.cz
I like flying komets, they are fantastic flying models.
Here is a short and bad coloured video of the 2nd flight of my komet.
The wingspan is about 52inch.
Me-163 Kraftei mit 12s1p.wmv (4 min 37 sec)
regards,
Oliver
AK47PELLA is offline Find More Posts by AK47PELLA
Old Oct 27, 2012, 10:11 AM
Pascal06's Avatar
Joined Sep 2011
Originally Posted by Herb View Post
... gave the Me-163 a clearcoat of acryl matt.
Hi,
I received it yesterday afternoon...really nice !
@Herb : did you need to sand or do something else before painting on the wings covering ?
Old Nov 04, 2012, 05:33 AM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hi all, very nice
Pascal, no just a very thorough cleaning of everything (fuse, polyester film on wings) with alcohol to take off any grease, fingeprints, dust etc.
I did not try anything stronger (like acetone) as I suspect it will ruin the finish. And no, no sanding of any type.
Do note one thing: I did not remove the original markings on the wing !! I just painted the stripes/camo around them, and later added a clearcoat on top.
I suspect pulling the original markings of the wing is probably not a great idea ...
Herb is offline Find More Posts by Herb
Latest blog entry: BAe Hawk 90mm EDF
Old Nov 05, 2012, 12:01 PM
Pascal06's Avatar
Joined Sep 2011
Hi Herb,
thank you for the "How to"
I will do the same for the original marking on the wings...I removed the one on the tail and a mark is still remaining !
No matter, I will paint the fuse with a different scheme
Old Dec 04, 2012, 09:49 PM
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, OH, Columbus
Joined Jul 2010
Wow guys thanks for the info I now know what I want from Christmas.
SpeedsterDEN
Can you please give us a run down of what equipment your running.
Motor, Lipo, ESC, and servos.
Thanks Mike
mikes68charger is offline Find More Posts by mikes68charger
Old Dec 05, 2012, 08:38 AM
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
SpeedsterDEN
Thanks Mike
Hi
Motor:
http://www.hobbyking.com/hobbyking/s...andrive_3659_1...
100 Amp ESC, (150 Amp burst in 10 sek)
http://www.hobbyking.com/hobbyking/s...idProduct=9328
4000 or 5000 Mha 4 cell 40 c battery.
Sometime I use 2x 4000 Mha in paralel for real long flights.
Not much different in flying because of the extra weight.
and 8x8 prop.
Tryed 6 cell and 6,5x6,5 and 7x7, but then it sound like it go berserk.
So 4 cell and 8x8 is my normal set up.
Thats it.
Regards
S
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Dec 05, 2012, 12:15 PM
Joined Jul 2010
Do you know your RPM/Amps
Thanks mike
Old Dec 05, 2012, 12:57 PM
Pascal06's Avatar
Joined Sep 2011
Hi SpeedsterDEN,
is it fast or very fast with your setup ?
Because I bought this motor for my Komet
http://www.hobbyking.com/hobbyking/s...dProduct=22035
...but the problem is that I don't really want to put a big prop on the nose I want to hear it screaming !!!!
Do you have a video of your Komet ?
Thanks !
Pascal
Old Dec 05, 2012, 03:31 PM
Joined May 2010
Originally Posted by Pascal06 View Post
Hi SpeedsterDEN,
Thanks !
Pascal
Hi Pascal
Its pretty fast. :, my motor is going 3x the rpm as yours.
Kv is the rpm Pr volt. 580 yours and 1900.for mine.
on 6 cell
ME 163. Fandrive 36-56 1900 motor (0 min 56 sec)
on 4 cell
Me 163 gear Test (1 min 15 sec)
ME 163 Komet, onboard cam. (1 min 43 sec)
Regards
S
Old Dec 06, 2012, 02:23 AM
Pascal06's Avatar
Joined Sep 2011
WOW !
It's incredible ! I love it !
Do you use the original landing gear ?
And what kind of motor mount do you use ?
Old Dec 06, 2012, 01:12 PM
Joined May 2010
WOW !
Home made aluminium motor mount and gear.
Gear
ME163 gear. (1 min 14 sec)
Modelflyver Motor test. (0 min 35 sec)
Old Dec 06, 2012, 01:56 PM
Pascal06's Avatar
Joined Sep 2011
Thanks a lot for your advise !
Old Dec 07, 2012, 03:37 PM
Joined Jul 2010
Love the motor test
I know why we want amps and watts but dosnt rpm with pich tell us approximate plane speed
Old Dec 30, 2012, 03:51 PM
stanordave's Avatar
Joined Jan 2006
Yes! Maidened!
Got one for Christmas. Was a little nervous that it would be twitchy but after TO and the initial trim, went back to high rates (+/- 1" on ailerons, 3/4 up/dn elevator) and it was still tame. Had CG at the 6.25" mark and needed a bit of up after TO but seemed good in fight so might increase the reflex another 1/16th.
Used a 5045-500 on 6s and seemed OK but not overly fast. Will try different props next outing and a lighter battery then maybe put in the SK3 1900kv I have sitting around to speed things up a bit.
Looked great inflight although it was solid overcast and 46º so didn't spend much time admiring it.
Anyway, good to be part of the "club"
cheers,
stanordave is offline Find More Posts by stanordave
Discussion Me-163 Komet Alfredo Rubio Mexico 4 Sep 19, 2011 10:11 AM
Discussion 40" me-163 komet hoppy Foamies (Scratchbuilt) 25 Jun 30, 2011 11:46 AM
For Sale komet me 163 daw steeg Aircraft - Sailplanes (FS/W) 2 May 29, 2011 05:22 PM
For Sale ME 163 Komet wingspan100 Aircraft - Electric - Airplanes (FS/W) 8 Mar 05, 2011 07:39 PM
Sold RARE ME 163 Komet or Comet wingspan100 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 05, 2011 06:25 PM
