This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Sep 28, 2012, 12:54 PM
Pascal06 is offline
Find More Posts by Pascal06
Pascal06's Avatar
France, PACA, Peille
Joined Sep 2011
Originally Posted by Herb View Post
Hi, you might want to check the links on the first page of this thread ?
It's done !
Some links doesn't work anymore, some are american and they don't send it outside USA
I found only one in Europe ( switzerland ) but no more stock...
Pascal06 is offline Find More Posts by Pascal06
Old Sep 28, 2012, 01:41 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hmm and I thought Spain was in Europe
Also, sometimes e-mailing the manufacturer (at the e-mail address listed on the first page) for a list of
European distributors could work.
Herb is offline Find More Posts by Herb
Old Sep 28, 2012, 02:25 PM
Joespeeder is offline
Find More Posts by Joespeeder
Joespeeder's Avatar
Davison, MI
Joined Sep 2007
How about here...
http://www.ytinternational.co.uk/me_163/me163.htm
Joe
Joespeeder is offline Find More Posts by Joespeeder
Old Sep 29, 2012, 02:31 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
One thing that I found useful in searching for Me-163 distributors was to enter on google, besides obviously Me-163, the wingspan which is listed at 1540mm ...
I need a second garage
Old Sep 29, 2012, 03:45 PM
SpeedsterDEN is offline
Find More Posts by SpeedsterDEN
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Something like this could be real cool on the Me 163.
RC, Rocket glider. (0 min 58 sec)
Regards
S
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Sep 30, 2012, 11:00 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Crazy
Old Sep 30, 2012, 12:51 PM
Pascal06 is offline
Pascal06's Avatar
Joined Sep 2011
Sorry Herb...you're right !
Christmas is coming....
Old Oct 02, 2012, 07:38 PM
ZRX212 is offline
Find More Posts by ZRX212
ZRX212's Avatar
United States, FL, Christmas
Joined May 2010
Landing gear fix!!
Aprox. 4 weeks ago the red Komet hit a bump in my club grass field when
starting takeoff, plane came of the gear rather abruptly, plane on belly with
broken prop, upon further inspection found one of the fwd holes had
some small cracks, I decided on reinforcing the gear mount area.
I plugged the two fwd holes with epoxied wood dowels, the aft hole was
filled with a mixture of epoxy and microballooms filler, I made and alum.
plate out T3/.040 sheet and shaped/bent into U channel shape, I glued
on fuselage with slow setting epoxy after scuffing area and removing all
the paint, to get good bond on bare glass fuselage. I drilled 2 holes into
the alum. plate(fwd/aft), this were enlarged to accept 3/16 brass tubing,
I epoxied the brass tubing sections, I the filled the tubing flat even with the
alum. plate, the dowels and brass tubing extend into and are also glued
to the plywood nutplate mount.
I used two of my original 6/32 sliding bolts into the brass tubing sections,
a lot stronger than the original holes in the fiberglass and gear slides/drops
of easier IMO, the pics will show details.
I will do same on green komet.
BTW 65 flights on green Komet in two seasons, maybe time for new battery this winter, red K has only 11 flights. I will try to get video on red at next fly-in.
Later, Allen (ZRX212)
ZRX212 is offline Find More Posts by ZRX212
Old Oct 03, 2012, 05:17 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Nice Allen !
So is this a gravity drop, or do you use an internal servo to drop the dolly?
Old Oct 03, 2012, 07:20 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Nice Allen !
It's still gravity drop like before, just a stronger setup, I'm working on ideas
for servo controlled drop, WKYP.
Old Oct 09, 2012, 07:26 PM
syrup is offline
Find More Posts by syrup
Joined Jul 2009
Hi Mr. Herb
Me-163 is very cool, how fast did it fly?
also saw you where using turnigy sk3 3659-1900kv with midi fan on your cmp t-45. I was wondering if you had opinion on that fan motor vs the hobby king lander dps 90mm unit. http://www.hobbyking.com/hobbyking/s...dproduct=17223
Since i'm not edf dynamic balance expert, the latter seemed like a reasonable prebalanced option.
Btw w/ fixed gear no flap servos and 4000mah 6cell nano's my cmp t-45total weight is still around 6.75lbs!
thanks a lot
Henry
syrup is offline Find More Posts by syrup
Old Oct 11, 2012, 04:40 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hi,
I think my Me-163 will go 120mph, maybe more ... I am worried about the wings flying off or cracking though, so I power off in a dive
Re the T-45 fans the SK3-Wemo combination is very light and efficient, that is why I picked it. Some of the HK fans are heavy as lead , very bad for an edf jet where you have to very careful about any added weight (unless you do internet flying). There are other options of course, but keep an eye on the weight. Balancing a fan (like the CS-5bl) is not difficult with eg. the HK magnetic balancer.
Old Oct 16, 2012, 12:25 PM
syrup is offline
Joined Jul 2009
Hi,
Wow, that's fast. i guess having the propeller outside really helps.
Was this the 5 blade fan you where refering too? http://www.hobbyking.com/hobbyking/s...dproduct=11261
this was the wemo fan i thought you liked. http://www.espritmodel.com/edf-wemot...i-pro-fan.aspx
I agree light and fast
thanks
Old Oct 21, 2012, 05:16 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Yes I think either one will work ...
Old Oct 21, 2012, 05:34 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Technik Museum in Berlin only has an originel Me-163 Walther engine, but it does have a complete He-162 Salamander.
This appears to be a new addition to the museum. One can clearly see that part of the constuction (eg wings) are made out of wood.
Discussion 40" me-163 komet hoppy Foamies (Scratchbuilt) 30 Dec 27, 2015 08:13 PM
Discussion Me-163 Komet Alfredo Rubio Mexico 4 Sep 19, 2011 10:11 AM
For Sale komet me 163 daw steeg Aircraft - Sailplanes (FS/W) 2 May 29, 2011 05:22 PM
For Sale ME 163 Komet wingspan100 Aircraft - Electric - Airplanes (FS/W) 8 Mar 05, 2011 07:39 PM
Sold RARE ME 163 Komet or Comet wingspan100 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 05, 2011 06:25 PM
