This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Jul 07, 2012, 01:26 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by Greg Beshouri View Post
... I am still thinking about getting one to toss off a very windy hill.....there is lots of room for ballast! Landing could be tough though! Did I see that someone cut in flaps?
Looks like a big one for handlaunching One mistake and the wing is done. I would consider a foam sheeted wing type instead.
When it's windy at the field I can hardly hold mine, always afraid it might just fly in my face. It's a big wing.
Herb is offline Find More Posts by Herb
Old Aug 01, 2012, 05:37 AM
ZRX212 is offline
Find More Posts by ZRX212
ZRX212's Avatar
United States, FL, Christmas
Joined May 2010
Red Komet #2
Progress has been slow due to my hot garage and other obligations,
fuselage is completely done, all gear installed, on this one the canopy
latch or windows did not come installed, I cheated a little and used the
canopy from red#1(slight color diff.), held on with single magnet at
top and alignment blocks on aft bottom, set up the same as red#1,
exception being I made the internal rudder linkage stronger and have
more rudder throw for knife edge flight. All"s left is wing elevon and
servo install, should be done soon.
WKYP, Allen
ZRX212 is offline Find More Posts by ZRX212
Old Aug 02, 2012, 03:27 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Red Komet #2
Well it's done, got last 2 days off and worked late nights on it
to stay out the heat, you can see my dead grass and all the glare
from hot sun, mayden this weekend!!
Old Aug 02, 2012, 08:06 PM
Joespeeder is offline
Find More Posts by Joespeeder
Joespeeder's Avatar
Davison, MI
Joined Sep 2007
Hey Guys,
All the Komets in this thread look spectacular !!!
I'm not being smart, just curious..... Why isn't anyone using a spinner on their 163's?
I even thought about using a folding prop on one of those spinners to make it look clean when the motor is off.
Looking forward to flight reports and video ZRX212.
Joe
Joespeeder is offline Find More Posts by Joespeeder
Old Aug 02, 2012, 09:04 PM
demeeks is offline
Find More Posts by demeeks
United States, CA, Salinas
Joined Oct 2006
Originally Posted by Joespeeder View Post
Hey Guys,
Joe
Joe,
I think most of us are using the open area behind the prop for additional
cooling as well as opening up extra cooling on the bottom of the cowl.
a couple of us have discussed using folding props but not sure if any of us have
as yet. The new 163 is really RED !
demeeks is offline Find More Posts by demeeks
Old Aug 02, 2012, 09:09 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Hey Guys,
Joe
For me, 2 reasons for not using a spinner, 1st it allows direct cooling to
motor and forces cooling air thru the holes in the firewall to cool esc,etc.
2nd the real one did not have a traditional spinner, more like a hub for the
air driven generator.
Red#2 has a prop nut/hub wich was made from a Highley nut wich had
the wrench flats removed in a lathe.
You really don't need a spinner for looks on this plane, performance will
kick looks , everytime.
Allen(ZRX212)
Old Aug 02, 2012, 10:47 PM
Joespeeder's Avatar
Davison, MI
Joined Sep 2007
Hey Guys,
Fair enough... I was just wondering.
You guys are running more power than I am so forced air is good,
I cut a hole for cooling, fit screen over it, and painted it so it's hard to see.
Early in this thread one of us did use a folding prop. Hadn't noticed til now. Cool. I may convert mine.
Keep up the great work and be sure to post lot of pics!!
Joe
Old Aug 04, 2012, 05:22 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Well no maiden this w-end, still to dam hot!! and have to work tomm
found another problem, I used Dave Brown liteflite foam wheels, no good,
they had a significant flat spot, just sitting on gear for a few minutes!!.
I use Sullivan 4" Skylite on my other one, no problems, they cost twice
as much, ordered some for red#2 today, sometimes cheap cost more!!.
I tried the gear off my green one, maybe get a chance for late test flight
tomm., no go, sliding pins don't align .
I took my spinner nut, washer and collet drive to work, had them turned
down on lathe to smaller diameter, I think it looks better.
WKYP on maiden, Allen(ZRX212)
Old Aug 07, 2012, 12:00 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
That looks very nice !!
Yes the real one had no real spinner ... a spinner changes the looks a bit.
I would not use a magnet of the canopy, magnets work well for parkfliers.
Old Aug 07, 2012, 05:10 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Yes, I have been wondering about the single magnet, I'm working on
better attachment ideas, too bad the spring latch was not installed
like the other ones, did not want to butcher the fuselage installing it.
WKYP, Allen
Old Aug 07, 2012, 05:24 PM
demeeks is offline
Joined Oct 2006
Hey Herb,
Just wanted to tell you, I flew my Hobby King 163 yesterday.
That thing is a rocket even bone stock with a 3s 2200 25-50 c battery
I think it's close to 100 mph and it just flat screams, sounds like a EDF.
The think really flys great.
Don
Old Aug 08, 2012, 01:34 AM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Well after aprox 1.5 hrs of measuring, etc and having a extra canopy
frame(no plastic), I was able to install the latch , I used a pencil
tip grinder on my dremel and was able to cut a perfect slot on fuse, I
ued 5 min. epoxy sparingly to glue on, to keep latch operating free, it
works great, was not totally sold on magnet idea.
Ordered German flag decals for tail from Callie, $4 TMD,
the wheels arrive thurs, test flt this wend
Allen(ZRX212)
Old Aug 08, 2012, 01:49 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Nice !
Hi Don, you are dangerous
Old Aug 09, 2012, 07:40 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Well after a while looking on the net finally found good pic of plane
I'm trying to replicate, even has similar spinner like mine .
Also found some sites and videos of one of the last surviving pilots!!
http://media.aerosociety.com/aerospa...nterview/3589/
Dr Reinhard Opitz - Me163 pilot (32 min 37 sec)
Enjoy, Allen(ZRX212)
Old Aug 09, 2012, 08:24 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hi Nice
The modern PK-QL Me-163 is actually a replica of Spaete's original "red" Me-163
http://www.rcgroups.com/forums/showp...&postcount=165
http://www.modellversium.de/galerie/...et-dragon.html
So you have a replica of a replica ...
Discussion 40" me-163 komet hoppy Foamies (Scratchbuilt) 30 Dec 27, 2015 08:13 PM
Discussion Me-163 Komet Alfredo Rubio Mexico 4 Sep 19, 2011 10:11 AM
For Sale komet me 163 daw steeg Aircraft - Sailplanes (FS/W) 2 May 29, 2011 05:22 PM
For Sale ME 163 Komet wingspan100 Aircraft - Electric - Airplanes (FS/W) 8 Mar 05, 2011 07:39 PM
Sold RARE ME 163 Komet or Comet wingspan100 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 05, 2011 06:25 PM
