This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Jun 07, 2012, 11:41 AM
demeeks is offline
Find More Posts by demeeks
United States, CA, Salinas
Joined Oct 2006
Good Morning Herb,
The red one looks really great ! I'm thinking of doing one as a glider and installing
a tow release and also a single wheel, wing tip skids like in the picture, maybe look at
doing the control surfaces like the real one and one more important thing, the washout.
Well, we'll see where it goes from here. Oh! and of course Calligraphics.
demeeks is offline Find More Posts by demeeks
Old Jun 08, 2012, 04:40 PM
Greg Beshouri is offline
Find More Posts by Greg Beshouri
Cant fly enough
Greg Beshouri's Avatar
USA, CA, Berkeley
Joined Dec 2003
Originally Posted by demeeks View Post
Good Morning Herb,
I'm thinking of doing one as a glider...
I was thinking the same, but making it a sloper.
Greg Beshouri is offline Find More Posts by Greg Beshouri
Old Jun 08, 2012, 05:50 PM
demeeks is offline
Joined Oct 2006
Greg,
I'm sure the 163 would make a great slope ship and not one
you would see often. Do you fly scale sailplanes? if so do you go down
to Visalia for the aero tow events and the monthly aero tows?
Old Jun 08, 2012, 09:28 PM
Cant fly enough
USA, CA, Berkeley
Joined Dec 2003
Greg,
...Do you fly scale sailplanes?....
I got bit by scale sailplanes at Los Banos Aerotow two years ago and went again this year. I now have a small Fauvel and 2.74m Fox which I have added to my slope colleciton. I agree the Komet would make an interesting subject!
Old Jun 08, 2012, 10:22 PM
ZRX212 is offline
Find More Posts by ZRX212
ZRX212's Avatar
United States, FL, Christmas
Joined May 2010
Red is Ready to Fly!!!
Got decasl from Callie, great quality and fast shipping!, just $18
shipped, got all gear installed today, balanced at 6 3/8 in from L/E,
my other komet is balanced at 6.5 , but I think this is good for 1st
flight, final weight exactly 8 lbs.
Power System:
E-flite Power 52(590kv)
ESC Hobby Wing F/F HV 80 amp
Batt. Sky Lipo 6s/40c/4400
Prop, APC 12X8
My Power reading, Battery 15 min. off the charger, 65A/1650W.
good for 200W/lbs.
Love how It came out, test flight sunday, WKYP, Allen
ZRX212 is offline Find More Posts by ZRX212
Old Jun 09, 2012, 02:05 AM
demeeks is offline
Joined Oct 2006
Wow ! Allen that's excellent and the Callie graphics really set it off.
Guess I'll have to do a red one. One of my sailplane friends said why not tow it up
off the grass and then fly it around on electric power, sounds like an adventure and
could be done without much of a problem.
Great job! Don
Old Jun 09, 2012, 01:11 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Allen, stunning !
Can you tell us what urethane red was used (paint brand), I understand you had it match the Ultracote. So you really mean they custom mixed the paint?
Good luck with the maiden, you should not have any visibility problems
Herb is offline Find More Posts by Herb
Old Jun 09, 2012, 02:21 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Great job! Don
Yes, very possible, if you noticed the full scale glider replica goes up that
way, you could go with a lightweight power system with folding prop just to
climb and find thermals, the glider also has a single centerline wheel.
Originally Posted by Herb View Post
Allen, stunning !
Yes is a custom match to a sample of the covering, the paint is Nason
paints/ful-thane/2k urethane, this paint must be mixed with compatible
hardener and reducer(I had both from previous project), it a cheaper
line of paints by Dupont(yeah right ), cost $36 for a pint ,
reds are usually more expensive thou, only used aprox. 6oz out of can.
After all the sanding, etc, it was sprayed a very light coat of pale grey
primer (Nason 1k/spray can) for even base, then the painter sprayed a
flash coat and very light coat of red, wet sanded, followed by a final coat
of red, no clear coat.
This is a lot of work, but is one step topcoat, wich is lighter IMO.
Did a little more testing on power system in warmer weather today,
it's going to be FAST!!!
WKYP, Allen
Old Jun 09, 2012, 09:07 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
2 Komets!!!
Old Jun 10, 2012, 06:24 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Down to One Komet , Red komet went down , shorthly
after takeoff it became uncontrollable, rocking wings violently at aprox
30 deg. climb, 75-100 ft up, I applied full power to gain altitude and saw
the prop come off , at that point plane stalled, I tried leveling
before impact but it hit hard, of course it hit in a section of farmers field
that was bare dirt, not grass to soften blow, significant structural
damage, wings buckled, cracks on fuselage.
I believe it was in a stall due to the wings rocking, but the lost of prop
sealed is faith!!, when I arrived at crash noticed prop collet gone!!.
I used the same collet on my other Komet with no problems.
Well I don't cry much over spilled milk, life is to short, I just seen
Texas R/C has then back in stock, I wonder if they have a red one
like it was rumored??.
Thanks, Allen
Old Jun 11, 2012, 11:00 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Ouch sorry to see that
I wonder why it became uncontrollable ... maybe not enough reflex ?
Old Jun 11, 2012, 02:25 PM
Joespeeder is offline
Find More Posts by Joespeeder
Joespeeder's Avatar
Davison, MI
Joined Sep 2007
Hi ZRX212,
Oh man..... Sorry to see that....
That was a beautiful Komet. Unique and very well done.
Hope we'll see another red one down the line somewhere.
Joe
Joespeeder is offline Find More Posts by Joespeeder
Old Jun 11, 2012, 02:41 PM
demeeks is offline
Joined Oct 2006
Allen,
Sorry to see that happen with all the great job you did.
I'm sure we'll see another from you. I've not noticed any bad habits with mine
and I've flown it quite slow but, that was up high. I tend to agree with Herb on the reflex.
I've heard from others that the Komet takes a bit of room to recover once they do stall.
Don
Old Jun 11, 2012, 02:55 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Originally Posted by Joespeeder;21867474
Plane was set exactly the same as my 1st one, right now I'm not sure
of all that happened, even re-checked balance before flying, maybe receiver problems??, next time I will used a bolt on prop adapter!!:(
Hi ZRX212,
Joe
Well yes you will, I just got of the phone with Texas R/C planes, he was
very helpfull, I asked for details for the red version as they don't have any
pics on their site, he went and opened a new kit to look, he said " Very
bright red and descibed the markings, etc. ", 2 minutes later the order
was placed .
Yes I'm weak , Allen
Old Jun 11, 2012, 03:03 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
" I've heard from others that the Komet takes a bit of room to recover once they do stall. "
Yes they do, I tried some high altitude stalls with my 1st Komet, very
violent inverted snap, took some 100 ft to recover, but it must be very
slow to stall, It doesn't like high banking turns when slow either, same
results. Allen
Discussion 40" me-163 komet hoppy Foamies (Scratchbuilt) 30 Dec 27, 2015 08:13 PM
Discussion Me-163 Komet Alfredo Rubio Mexico 4 Sep 19, 2011 10:11 AM
For Sale komet me 163 daw steeg Aircraft - Sailplanes (FS/W) 2 May 29, 2011 05:22 PM
For Sale ME 163 Komet wingspan100 Aircraft - Electric - Airplanes (FS/W) 8 Mar 05, 2011 07:39 PM
Sold RARE ME 163 Komet or Comet wingspan100 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 05, 2011 06:25 PM
