This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old May 24, 2012, 05:22 PM
Greg Beshouri is offline
Find More Posts by Greg Beshouri
Cant fly enough
Greg Beshouri's Avatar
USA, CA, Berkeley
Joined Dec 2003
Originally Posted by Herb View Post
Me-163 formation flying .... Spectacular !!
Wow!
Greg Beshouri is offline Find More Posts by Greg Beshouri
Old May 26, 2012, 02:06 PM
ZRX212 is offline
Find More Posts by ZRX212
ZRX212's Avatar
United States, FL, Christmas
Joined May 2010
... continued form post #136.
Did some more testing yesterday, seems that my Sky lipo 5s/40c/5000mah
is getting better/stronger, 10 cycles now, tested with What's Up meter and
got 93 amps@1650 watts (batt just off charger) , motor limit is 140amps
and 1800 watts, so in still good!!, ran at 1/2 power for 1 minute, tested again
86A/1470W, so letting the battery rest for a while of the charger will be good
for 100 amp/esc, that 93 amp pull was scary while holding plane.
The thing I noticed after the run was that my esc was getting fairly hot,
my battery and motor where barely warm!!, of course this is a cheap esc,
I know it will be better in flight, not wanting to take any risk, I decided on
installing a heatshink, actually installed 2(Radio Shack # 276-1368) with
a thermal adhesive pad(R/S), tested today, much better, even after 4 min
at 1/2 power it was noticeable cooler.
BTW the thermal pad won't hold the heatshink on when hot, you must
glue around the edge, I zip tied mine in place.
Planning to do a lot of flying on th ME tomm, Later, Allen
PIc of my setup, Yes there's a rudder gyro in there, only used for takeoff's
in gain mode, off in flight, works great!!.
ZRX212 is offline Find More Posts by ZRX212
Old May 27, 2012, 12:47 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Yes heatsinks work miracles ...
But mine tracks straight as an arrow on takeoff, it could be because I have a smaller prop (11x10).
Herb is offline Find More Posts by Herb
Old May 27, 2012, 08:47 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Flew Me 3 times no issues with esc, lot's of power, I'm flying mine on
12x8, I estimate top speed aprox. 120 mph, the reason I went with the
gyro is that I'm using servo saver springs on rudder pushrod, this makes
steering a little sluggish to react to input, I also fly off a grass field, wich is
bumpy in some areas, the springs keep the servo from stripping/breaking
gears on the belly landings, as sometimes the plane slides sideways a
little, making the tail wheel vulnerable to side loads, I use a metal gear
high speed/torque digital servo, but still there is a lot abuse on it on the
landings,IMO.
With the gyro, I taxi out, line up with center of runway and stop, then I
arm the gyro in gain mode, hold up full up elevator, apply power slowly
and the plane goes straight untill it breaks ground with little or no rudder
input, the gyro is switched off and all rate switches go to low, landings
are on high rate with gyro off.
I might try a 11x10 later if I feel the need for more speed
Allen
Old May 29, 2012, 06:15 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Well it's all RED!!
Picked up fuselage from painter, I did a lot of the prep work, sanded most
of the original paint and primed grey, he did the final sanding and fixed any
pinholes, etc, followed by light primer coat and single stage urethane red,
I had color matched to my Ultracote covered parts, vert good match IMO!!.
I weighted the empty airframe (wing joiner, canopy, cowling), the battery
tray and all gear monting provisions were done prior to paint. There is no
electronics, motor, servos, pushrods, etc. I think I can make my target
weight of 8 lbs(128 oz).
Scale showed 4.25 lbs(68 oz), that leaves 3.75 lbs(60 oz) for gear
I think I'm good. I'll post details on final setup later.
BTW, very RED!!!
Old May 29, 2012, 08:20 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Killer !! Very nice
Graphics by Callie ?
Old May 30, 2012, 03:27 AM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Killer !! Very nice
I'll be doing my own graphics, we have the equipment at work!!
Old May 30, 2012, 06:57 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Very cool vid Herb!
Bring something out saturday that my F-4 can chase (now that I got it flying semi-decently)
Your Komets too fast!
bmiller is offline Find More Posts by bmiller
Old May 30, 2012, 07:01 PM
demeeks is offline
Find More Posts by demeeks
United States, CA, Salinas
Joined Oct 2006
Here ! Here ! Komets Rule !!
demeeks is offline Find More Posts by demeeks
Old May 31, 2012, 07:40 AM
Joespeeder is offline
Find More Posts by Joespeeder
Joespeeder's Avatar
Davison, MI
Joined Sep 2007
Hi ZRX212,
Very cool red scheme !! Looks really great !
Joe
Joespeeder is offline Find More Posts by Joespeeder
Old Jun 01, 2012, 03:04 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by bmiller View Post
... Bring something out saturday that my F-4 can chase ...
Ok Bruce I'll bring something really slow (if I can find it in my hanger ) ...
Allen, eagerly waiting for more pictures with decals
Old Jun 01, 2012, 05:37 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Originally Posted by Joespeeder View Post
Hi ZRX212,
Joe
Thanks Joe, BTW is Ultracote True Red on wings and Rudder.
Allen, eagerly waiting for more pictures with decals [/QUOTE]
Will try to cut decals tomm, slow otherwise, got side windows
and rudder hinges installed, WKYP, Allen
Old Jun 04, 2012, 07:03 PM
ZRX212 is offline
ZRX212's Avatar
Joined May 2010
Red komet
Well the graphics cutter at work has software problems ,
so a few email's to callie and they are on the way
The plane is almost ready, checked weight right at 7 lbs/14 oz ,RTF,
I don't think graphics will weigh much, so I'll be good. My other komet
is at 7.5 lbs on 5s/93 amps/1650 watts, the red one will be 8 lbs on
6s/65 amps/1650 watts, should get similar speed and flght times.
WKYP, Allen
Old Jun 04, 2012, 09:10 PM
demeeks is offline
Joined Oct 2006
Allen,
Can't wait to see the graphics on the red one, should be great !
Don
Old Jun 07, 2012, 11:27 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Spaete (pilot or Red Me-163) with Galland.
http://www.juniorgeneral.org/JClick.php?UID=2801
Note the wing twist (washout).
Discussion 40" me-163 komet hoppy Foamies (Scratchbuilt) 30 Dec 27, 2015 08:13 PM
Discussion Me-163 Komet Alfredo Rubio Mexico 4 Sep 19, 2011 10:11 AM
For Sale komet me 163 daw steeg Aircraft - Sailplanes (FS/W) 2 May 29, 2011 05:22 PM
For Sale ME 163 Komet wingspan100 Aircraft - Electric - Airplanes (FS/W) 8 Mar 05, 2011 07:39 PM
Sold RARE ME 163 Komet or Comet wingspan100 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 05, 2011 06:25 PM
