This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Dec 16, 2011, 05:15 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Build Log
Messerschmitt Me-163B-1a Komet (Kraft-Ei)
My new little project, a Messerschmitt Me-163 Komet, 61'' wingspan. It will be FAST
This thread in German
Some basic info on the Me-163 Komet rocket interceptor can be found here : http://en.wikipedia.org/wiki/Messerschmitt_Me_163
The original Me-163B had a wingspan of 9.33m, which makes the model roughly 1:6.1 scale.
Most likely the paint scheme will be "yellow 15" kept at Raf Cosford.
The model itself is the so-called "Flyboy Models" or "BH Models" 0.60-size Me-163, 1540 mm (61'') wingspan,
and is made by CY Model : http://www.cymodel.com
http://www.cymodel.com/Cn/pro_view.asp?id=26
http://www.jfchobby.com/en/html/Prod...106&SortID=192
http://www.texasrcplanes.com/me163.html
http://www.bphobbies.com/view.asp?id...0&pid=E3715233
http://www.topd.ch/RC-Modellbau/JFC/...-von-000481253
http://www.aeromodelismoserpa.com/me...tf-p-9840.html
http://www.hebu-shop.ch/product_info...6e75280af25d03
http://www.austars-model.com/dispdet...12061052272283
Edit : Me-163 short video March 2012:
Me-163 Komet 60-inch RC (FlyBoys) (2 min 5 sec)
Herb is offline Find More Posts by Herb
Old Dec 16, 2011, 05:36 PM
realtimerecon is online now
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
Turbine ?
realtimerecon is online now Find More Posts by realtimerecon
Old Dec 17, 2011, 05:15 PM
soundcheque is offline
Find More Posts by soundcheque
Bring It On !!!!!
soundcheque's Avatar
Newmarket, England.
Joined Aug 2006
Cool pics
I just got this one too:
http://www.cloudmodels.com/komet.html
Going to use the HET 2700 kv inrunner with a 4.7 x 4.7 prop on 3s then if all goes to plan a 4s.
Good link here for you of the HET ME 262
222mph ME163 with two motors comes apart in the air. (8 min 15 sec)
Enjoy
soundcheque is offline Find More Posts by soundcheque
Old Dec 20, 2011, 07:09 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Me-163 model actually looks quite a bit better than I expected
This is the Flyboys Me-163 which I got from texasrcplanes at a very reasonable price (four day ups delivery).
Here are some pictures, the kit looks pretty awesome for the price!!
The glasswork (polyester resin as usual) is very good and light, given the size of the fuse; the wings are ultralight.
The paint matches perfectly between fuse and wings. The decals are quite nice and not cheesy at all.
The canopy seems good quality, pre-painted with frame and latch pre-installed.
Will post more pics as I get along with the build. For now, I am pretty enthusiastic.
Old Dec 20, 2011, 10:10 PM
Bring It On !!!!!
Newmarket, England.
Joined Aug 2006
http://www.rcuniverse.com/forum/m_7134453/tm.htm
http://www.rcgroups.com/forums/showthread.php?t=1089760
Found a couple of links which may be helpful for all of us. Looks like a good kit Herb
Old Dec 20, 2011, 10:13 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
That's pretty neat Herb. Looks like it uses wheels instead of the skid?
I bought a semi kit a few months ago for a 163 but it's going to take quite a lot of work to get it looking like this.
Steve C is offline Find More Posts by Steve C
Old Dec 21, 2011, 01:34 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hi Steve,
Yes it is a neat kit, better than I expected. You would like it !!! How big is yours, pics ?
And yes I'd seen a few threads on RCU and RCG but it seems very few ended up actually flying ... and when they did it was with some sort of massive oversized pattern prop
Mine most likely will have a droppable scale (or semi-scale) two-wheel dolly. I am over the bungee thing for good
There are some really nice threads on the Me-163 (rather unusual subject) over in the German forum, it took me a while to find them because they call it the Kraft-Ei. Mostly they are turbine and BIG
http://www.rc-network.de/forum/showt...sbauer-Richter
http://www.rc-network.de/forum/showt...t-Kraftei-quot
http://www.rc-network.de/forum/showt...n-AS-Composite
Me 163 B1a M 1:5 Sunshine Modellbau (5 min 41 sec)
ME163-Flugtag Harsewinkel 2011 (7 min 4 sec)
Old Dec 21, 2011, 01:47 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I have been looking at the airframe trying to estimate the maximum speed it can take without the wing disintegrating (the wings are quite light, built up balsa with a hefty spar).
Since it's not a composite wing I'd say the max speed for this airframe is conservatively in the 130-140mph range.
If I use 140mph as a guide then I think I need a pitch speed that's slightly higher than that, how does 150mph sound?
http://www.ecalc.ch/motorcalc.htm
In the example below I focus on an 8S 4000 setup with a 12x12 prop at 12k rpm giving ca. 2.2kW.
Old Dec 21, 2011, 04:42 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I weighted the empty airframe (with wing joiner, canopy etc.) with no linkages or electronics.
It's 64.3 oz = 4.02 lbs = 1.826 kg which is pretty light.
The specs are
wingspan = 154 cm = 60.6 ''
length = 102 cm = 40.1 ''
wing area = 47.5 dm2 = 736.4 in2
The original had a wingspan of 9.33m and a length of 5.92 m with a wing area of 18.50 m2.
http://de.wikipedia.org/wiki/Messerschmitt_Me_163
So the gives as a scale for this Me-163 Komet about 6.06 : 1 which is very close to my AW Me-262 (6.2:1 scale).
Old Dec 21, 2011, 04:46 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The hardware package contains a number of useful items, and some that are a bit less useful ...
The kit suggests a fixed gear setup, where they widened the stance a bit for stability reasons.
The wheels are pretty big and should be usable. The landing gear itself looks a bit odd from a semi-scale perspective but I'm sure it's pretty functional.
The green plastic spinner looks a bit hideous, but at least they made an effort to include something.
Old Dec 21, 2011, 06:19 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Here's an electric one :
Gummiseilstart Modell ME 163 RC Model (1 min 8 sec)
Old Dec 26, 2011, 06:12 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
I have this plane and have flown it several times. Mines running a 500kv motor on 5s 5000 with a 13x10 apc prop. I did droppable dolly as well since the real plane did that.
First thing....it requires a lot of thrust to break ground, but once it does, it'll shoot up quite quick like.
Also....Id recommend putting up reflex on the elevons. About 5mm above the neutral point of the trailing edge of the wing. You will need it.
I also put an estes C size rocket motor in the tail with the arming function powered by a battle switch run off a 9v battery.
kahloq is offline Find More Posts by kahloq
Old Dec 27, 2011, 01:01 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Very nice, and a cool picture too !
Yes these flying wings need reflex, otherwise the fly strange. The CG seems well established though at ca. 6.25 '' = 156mm.
I agree that an Me-163 flying with those wheels hanging down seems silly
Old Jan 01, 2012, 02:41 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I test-fitted the (fixed) landing gear, it works ok looks pretty solid, and has quite a wide stance.
I will have to modify the whole thing so that it can be dropped off after takeoff.
Old Jan 01, 2012, 02:44 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The rudder setup on the other hand is very straightforward. The rear access hatch makes everything very easy.
Nevertheless the rudder pushrod, which is made out of some cheap wood, looks a bit thin and will be replaced by something stiffer.
Discussion 40" me-163 komet hoppy Foamies (Scratchbuilt) 30 Dec 27, 2015 08:13 PM
Discussion Me-163 Komet Alfredo Rubio Mexico 4 Sep 19, 2011 10:11 AM
For Sale komet me 163 daw steeg Aircraft - Sailplanes (FS/W) 2 May 29, 2011 05:22 PM
For Sale ME 163 Komet wingspan100 Aircraft - Electric - Airplanes (FS/W) 8 Mar 05, 2011 07:39 PM
Sold RARE ME 163 Komet or Comet wingspan100 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 05, 2011 06:25 PM
