Old Nov 15, 2012, 04:29 PM
rhampton is offline
Find More Posts by rhampton
USA, FL, Clearwater
Joined Dec 2007
Originally Posted by FRIDAY_2008 View Post
Servo tray and blind nuts glued in place
Firewall also glued and motor installed. I used a turnigy outrunner, but seemed that cables were rubbing on motor case. I drilled 2 holes on the fuselage and put through a steel pin holding the cables away
uuuu,,,, i want your plane Friday_2008 since it's already built and trimmed...how much and i live in Fl so you have to Ship...LOL....wow,,i really want this Glider...saving money as we speak... but i really need to make it Electric...i dont do Slopes and Winches....lol..
rhampton is offline Find More Posts by rhampton
Old Nov 15, 2012, 11:21 PM
FRIDAY_2008 is offline
Find More Posts by FRIDAY_2008
Bouras Slope Flyers
FRIDAY_2008's Avatar
Athens, Greece
Joined Mar 2008
Don't fear of a little built. Its nothing major, and we are here to help.
Just a teaser...
FRIDAY_2008 is offline Find More Posts by FRIDAY_2008
Old Nov 16, 2012, 12:54 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
...My 2,4m is 1,64kg it could be done a tad lighter than that.
Friday
Hmmm... a bit of heavy side... if my 3m ARF BoT ended under 2kg, with 300 grams lead in nose that will disappear soon, by changing some layout
renatoa is online now Find More Posts by renatoa
Old Nov 16, 2012, 01:48 AM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
I think the lightest I can get is no less than 1,57kg the most, by changing wing servos to 13gr servod, while now I have park servos (20gr).
As it appeared from the beginning, I needed lead in front, but decided to go with a heavier battery 3s 3000mah as far fwd as possible and moved servo tray fwd too.
I ll do the mod with the servo and check back.
Last flight though at 12kn winds I was blown back and only with reflex I could penetrate upwind. Maybe I needed ballast that day.
Old Nov 16, 2012, 05:55 AM
rhampton is offline
USA, FL, Clearwater
Joined Dec 2007
Just a teaser...
oh you would have to Torture me with that Photo...lol...how often do you Fly yours and is it really enjoyable and relaxing?
Old Nov 16, 2012, 06:21 AM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
Two times per week. That is roughly 3 hours/week
Relaxing... No bloody not... How can it be when you flying a dot moving on sky...
Otherwise, you can combine lounge music too.
Cmon you want to be teased man
Old Mar 14, 2013, 03:48 PM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
Some new findings...
I have further tested placing the cg back and see for the results.
Ended way back from the manuals recommendations, to 95mm.
Model really performs at this cg, showing everything going up there and riding thermals from down low.
It turns tight and lands really slow. No bad tendencies.
I am about to change colours now, for the up coming season.
Old Mar 21, 2013, 01:38 PM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
Transformation completed...
Old Apr 21, 2013, 09:11 AM
IronEagle38 is offline
Find More Posts by IronEagle38
Joined Feb 2013
How long did it take you to build it?
Is it easy to build?
How smooth was the test glides?
IronEagle38 is offline Find More Posts by IronEagle38
Old Apr 22, 2013, 01:57 AM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
You mean the re-covering or from box to flying?
Old Jul 21, 2014, 02:33 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
I am going to resurrect this old thread as there is not much on the forum on this Albatros 2.4. This is the largest discussion thread.
You guys still flying yours? Any comments?
Would you recommend it for ALES?
I try to provide suggestions to the members of our club based on what I read on the forums. So, what are you thoughts?
Anyone put one of these up recently?
Inquiring minds want to know.
aeajr is offline Find More Posts by aeajr
Discussion Stiletto Pylon Racer from esprit model Steka High Performance 6 Dec 13, 2011 01:03 PM
Question ECOTOP 100" WS de Havilland Canada DHC-2 Beaver sold by ESPRIT MODEL kydawg1 Scale Kit/Scratch Built 2 Sep 30, 2011 10:58 AM
Sold E-Flite Power 110, 2 18X10 props and 2 Turnigy 4S 5000MAH 30C-40C packs all like New mechengineer03 Aircraft - Electric - Power Systems (FS/W) 2 Sep 01, 2011 10:25 AM
Diablo 3D from Esprit Model $129.00 this weekend for E-zoners!!!!! modest-master Sport Planes 11 Oct 18, 2010 07:55 PM
Discussion Need help with Pulsar 2.5E (ARF) set up from Esprit Model SoarinJohn Electric Sailplanes 2 May 15, 2008 08:27 PM
