Old Jan 29, 2012, 12:24 PM
Joe Pierson is online now
Find More Posts by Joe Pierson
Joe Pierson's Avatar
USA, CA,
Joined May 2001
ZB,
What is the hold up on the Albatros 2.4S/E from Esprit Model?
Joe Pierson is online now Find More Posts by Joe Pierson
Old Apr 10, 2012, 01:27 PM
FRIDAY_2008 is offline
Find More Posts by FRIDAY_2008
Bouras Slope Flyers
FRIDAY_2008's Avatar
Athens, Greece
Joined Mar 2008
Any news on that bird...?
I am about to get one of these. I downloaded the manual, and boy... its very dense and not for a novice builder.
FRIDAY_2008 is offline Find More Posts by FRIDAY_2008
Old Apr 28, 2012, 04:07 PM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
So, here it is...!
Great quality, very light (693gr) empty.
Old May 01, 2012, 12:05 PM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
So...! Lets get down to work.
Cut out covering, test fitted blocks and servos (watch for orientation before finalizing). I marked them with a pen, sand them a little for better grab and glue them.
Old May 01, 2012, 04:22 PM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
Plywood part to be next, where the wing will bolt on, on the rear side. Test fit and measure where exactly it should be. Then glue.
Old May 06, 2012, 01:44 AM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
Servo tray and blind nuts glued in place
Firewall also glued and motor installed. I used a turnigy outrunner, but seemed that cables were rubbing on motor case. I drilled 2 holes on the fuselage and put through a steel pin holding the cables away
Old Jun 07, 2012, 03:48 PM
SoarT is offline
Find More Posts by SoarT
SoarT's Avatar
Maitland, FL
Joined Jun 2009
Progress on you Albatros?
I just started work on my Albatros 2.4 and wondered how you were doing.
How do you plan to keep the wing servos in place?
Will you make some vent holes in the fuselage for cooling air flow?
I have not decided on a motor yet - maybe an Axi or the MVVS, but definitely not an Eflite 25 because that draws too much current in my converted Gemini (11x7 prop).
SoarT is offline Find More Posts by SoarT
Old Jun 07, 2012, 04:52 PM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
I have already flown the plane a couple of times now and flies really good. I had an.experienced pilot trim it and now I enjoy it.
I wraped the servos with electrical tape, fit them snug into the epoxy holders that were included, and glued the down with cyano. By this, you can cut out the tape and easily take out the servo.
No, I didn't cut the fuse, even if the power system gets heat up a bit, a 30second run won't hurt that much. It will cool down up there.
I had a problem with the right aileron, where, when it was straight to the flap actually it was not in its neutral position, as it had a gap on the outer wing. When got it straight to the outer wing it tracked down perfectly.
Good luck on your build, and I ll be here to answer your questions.
Old Nov 08, 2012, 08:45 PM
rhampton is offline
Find More Posts by rhampton
USA, FL, Clearwater
Joined Dec 2007
i would like to get one of these and make it electric. Can anyone tell me where i can get one in the US? does Esprit has any? i cant seem to get any responses.
rhampton is offline Find More Posts by rhampton
Old Nov 09, 2012, 07:28 AM
WallsRoofing71 is offline
Find More Posts by WallsRoofing71
United States, NC, Raleigh
Joined May 2010
This is it Esprit should have them
http://www.espritmodel.com/albatros-2-4s-e-arf.aspx
WallsRoofing71 is offline Find More Posts by WallsRoofing71
Old Nov 09, 2012, 07:36 AM
rhampton is offline
USA, FL, Clearwater
Joined Dec 2007
Thanks wallsroofing71..Do you think this is easy to convert to Electric. I'm not so great of a builder. i bought a large 96" Foamy Glider from nitro planes but it's RTF.....here's a video clip but now i want to get out of the foamy and get into more material like what Esprit has. Something light too. Under 70ounces RTF Weight.
i like my Large Foamy but i cant imagine how that Albatros 2.4 will Fly compared to mine...what do you think..is it a night and day difference in Flying experience?
ArtTech Diamond 2500 Glider (2 min 31 sec)
Old Nov 09, 2012, 10:38 AM
Joined May 2010
http://www.youtube.com/watch?v=_rg1WxvhMjY
I think you will be very happy with any of the Topmodels in the Albatros line of gliders. Esprit can cut the nose off and mount a motor mount in the nose for you for $25.00. If I were to buy one I would spend the money and let them put the motor mount in for me. Yes it is a night and day when you go to something like an Albatros you will be very happy.
Old Nov 11, 2012, 07:33 PM
Esprit Model is online now
Find More Posts by Esprit Model
espritmodel.com
Joined May 2010
We finally made nice video, this thing flies like a dream.
Zb/Esprit Model
MVVS 4.6/840 motor
Jeti pro 40 SB
TP2700 3S battery
Aeronaut 16x8 prop
Esprit Model Albatros 2.75E (2 min 27 sec)
Esprit Model is online now Find More Posts by Esprit Model
Site Sponsor
Old Nov 12, 2012, 01:00 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
I don't care what anyone sais; transparent blue and white are very visible. Even in a partly cloudy sky.
Pretty bird, you had any luck thermaling it yet? That is after all what it was designd for
Fly Wheel is offline Find More Posts by Fly Wheel
Old Nov 15, 2012, 04:20 PM
Bouras Slope Flyers
Athens, Greece
Joined Mar 2008
A jig to cut the nose is included at the 2,4version, so it would be easy to cut it. The firewall then, only needs some epoxy and will stick forever. I think you should try it, on the other hand 25$ isn't that big of a deal for a prof work.
+1 on that.
As soon as you trim it right, it will thermal great. My record is 1:18:00 thermalling. You have to built it light though. My 2,4m is 1,64kg it could be done a tad lighter than that.
I ll be installing a vario soon, to see its true potentials. As I am sure I am missing some thermals
Friday
Discussion Stiletto Pylon Racer from esprit model Steka High Performance 6 Dec 13, 2011 01:03 PM
Question ECOTOP 100" WS de Havilland Canada DHC-2 Beaver sold by ESPRIT MODEL kydawg1 Scale Kit/Scratch Built 2 Sep 30, 2011 10:58 AM
Sold E-Flite Power 110, 2 18X10 props and 2 Turnigy 4S 5000MAH 30C-40C packs all like New mechengineer03 Aircraft - Electric - Power Systems (FS/W) 2 Sep 01, 2011 10:25 AM
Diablo 3D from Esprit Model $129.00 this weekend for E-zoners!!!!! modest-master Sport Planes 11 Oct 18, 2010 07:55 PM
Discussion Need help with Pulsar 2.5E (ARF) set up from Esprit Model SoarinJohn Electric Sailplanes 2 May 15, 2008 08:27 PM
