Espritmodel.com Heli Air
Old Dec 16, 2011, 06:48 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
JPower 50mm EDF data ...
Power thrust data for JPower T45 50mm EDF
Thought people would like to see following figures recorded on my vertical thrust rig and Wattmeter readings :
Model : T45 50mm EDF Skyangel ARF from Hobby King
Motor : Stock as supplied fitted 4200Kv
DF : 50mm 5 plain blade fan as fitted stock
ESC : 20A as stock
The model is stated to use a 850mAh 3S 20C LiPo and nearest and others have been used in tests ...
Batt ID.... mAh.... ... ..C rating.... Amps.... Watts.... Thrust grams
001 ....... 800.... 3S .. 20C....... 16A ..... 170W .... 255 gr
002 ....... 800.... 3S .. 20C....... 15A ..... 160W .... 245 gr
003 .......1300... 3S .. 25C....... 18A ..... 220W .... 330 gr
004 .......1300... 3S .. 25C....... 16A ..... 170W .... 275 gr
--D .......1800... 3S .. 25C....... 18A ..... 210W .... 340 gr
--G .......1800... 3S .. 25C....... 18A ..... 220W .... 345 gr
Battery D was used for flight tests and Doppler speed checks on video gives 85km/hr straight level and over 90km/hr in shallow dive.
I did connect a 2100mAh 3S 35C pack out of interest to see if C rating could improve performance ... as the Wattmeter went over 21A, 240W - I cut the power before ESC or Motor suffered. There was obviously more power available from the stock set-up.
Tests will be made later with 4S 20C pack as I believe keeping amps in the sub 20A band is advised. But having extra V on tap ... we should see an increase in thrust and consequently more speed. The intention is to push the model to break the 100km/hr mark but with stock as far as possible, apart from LiPo and possibly changing fan to 6 blade .. but shroud, model, motor, ESC will remain.
Anybody else experimented similarly ? Any results to pass on ?
I'm interested in grouping up with other 50mm EDF owners to maximise the adrenaline on these machines !
(copy / paste from another thread on this forum I made)
Note - My T45 needed no balancing or work on EDF at all ... all was good out of box !
I have now also fitted Stinger 64 landing gear from Hobby King (~$6 incl. nose wheel servo) ... tips it fwd on CoG but reducing battery to 1300 3S puts her back again ... AUW is about 500grams now ...
solentlife is offline Find More Posts by solentlife
Sold 4 50mm JPOWER EDF Units Roly72 Aircraft - Electric - Jets (FS/W) 3 Sep 25, 2011 06:49 AM
Sold New 50mm EDF Unit and Motor from JPower EDF $15Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 0 Jan 15, 2011 11:37 AM
Sold 50mm EDF fan units from Jpower micro EDF ARFS The Don Aircraft - Electric - Jets (FS/W) 2 Mar 30, 2010 07:06 PM
