Old Dec 15, 2011, 10:34 PM
timnilson is offline
Find More Posts by timnilson
timnilson's Avatar
United States, FL, Sarasota
Joined Nov 2010
New GoPro lens protection product by fpvmanuals
FPV Manuals Introduces "LayerLens" -- Exposed GoPro Lens Protection
The case that comes with the GoPro camera is beautiful, sturdy, and water tight, but it weighs about 100g and the included mounts make the camera stick up over 1″ with the overall surface area growing by a good amount. As a result, many FPV and aerial videographer pilots mount their GoPro without the protective case to save weight and provide a smaller overall footprint. The most significant issue with this “naked” mounting method is that the camera’s lens is directly in harm’s way. Any crash has a high likelihood of damaging the camera’s lens -- I personally destroyed 2 GoPro cameras already. Once the original lens is damaged, replacement of the lens is an expensive option costing close to $100 USD — 1/3 of the price of a new GoPro2 camera and almost half of a GoPro Hero HD. Some replace a scrached lens with a sunex lens, which is a bit more affordable, but changes the wide angle picture, which is partially what makes the GoPro such a special camera.
For this reason, FPVManuals has developed LayerLens. LayerLens brings the most important part of the original GoPro case back: the protective lens; without adding much weight or size. LayerLens weighs only 9.6g — less than 10% of the weight of the GoPro case. LayerLens is a precision laser cut frame that holds the protective glass lens and is pushed onto the GoPro’s built in lens. It sits tightly in place and does not come off easily. It is further secured with a small rubber band. In case of a crash that scratches LayerLens’ glass lens, you can easily swap out the scratched protective lens and replace it with one of the lenses that are readily available by GoPro as part of their “Lens Replacement Kit” (which includes 2 lenses for $14 to $20 USD).
The pictures below show the first proto-type of LayerLens. The production version will be sold with 2 glass lenses for only slightly above the price of the GoPro Lens Replacement Kit — currently we’re targeting a retail price of $24.99 (subject to change).
LayerLens will soon become available in the GetFPV store.
Please let me know what you think about the product idea, the execution, and the targeted price point. Your feedback will absolutely be factored into the design and pricing process.
timnilson is offline Find More Posts by timnilson
Site Sponsor
Discussion New product. GoPro HD HERO2. Sad Sack FPV Talk 3 Oct 25, 2011 07:19 AM
Found Wanted, GoPro Hero HD Lens (actual camera lens, not case) KeithLuneau FPV Equipment (FS/W) 4 Aug 01, 2011 11:24 AM
Discussion Lens protection? rcbif Aerial Photography 15 Dec 07, 2009 02:47 PM
Discussion GoPro Sports Camera Standard Lens RvMan56 Aerial Photography 0 May 21, 2009 06:14 PM
Nikon 3700 lens protection and shade rcpilot901 Aerial Photography 5 May 21, 2005 01:33 PM
