Old Jan 19, 2013, 09:50 PM
Neko is offline
Find More Posts by Neko
United States, IL, Chicago
Joined Nov 2007
I posted a couple of weeks ago about a problem in which the image oscillates from being fine to being pixelated and highly colored, with an alternation period of exactly 1 second. After fussing a little more, I found that this occurs only when I play the videos in QuickTime 10.0 on my Mac (OS 10.7). In Window Media Player, or in the DivX players on the Mac, or the older QuickTime Player Pro (version 7.6) the videos look fine. Odd.
Neko is offline Find More Posts by Neko
Old Jan 20, 2013, 04:51 AM
galleon1 is offline
Find More Posts by galleon1
Joined Jan 2013
I am sorry if this have been asked before, but I did not find any info in the manuals. Will motion detection work with v1, or only v2 of this camera?
galleon1 is offline Find More Posts by galleon1
Old Jan 20, 2013, 05:14 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
It will work with V1. It's only video out that requires the V2 hardware.
Bill Glover is online now Find More Posts by Bill Glover
Old Jan 20, 2013, 07:29 AM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Originally Posted by therau2000 View Post
I have done some research...
Although establishing BlueTooth communication is no problem in Android, one would have to piggy-back USB communication over BlueTooth serial communication.
I have not found any indication that it is even technically feasible.
Maybe Elijah can include a BlueTooth chip in next generation camera...
I was thinking something like this, would need a hack to provide 5v.
http://item.mobileweb.ebay.com/viewi...626&cmd=VIDESC
victapilot is online now Find More Posts by victapilot
Old Jan 20, 2013, 09:07 AM
VideoKing is online now
Find More Posts by VideoKing
VideoKing's Avatar
United Kingdom, England, Kent
Joined Dec 2010
If you are planning on plugging in a USB dongle to the camera to enable serial data transfer (SSP protocol) you would need a Bluetooth USB host adapter.
Unfortunately the one you show is not, it's a slave adapter for plugging into laptops, net books etc.
VideoKing is online now Find More Posts by VideoKing
Old Jan 20, 2013, 09:30 AM
Magic k2 is offline
Find More Posts by Magic k2
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
Originally Posted by Race Miata View Post
Just want to share my latest onboard footage. I'm pleasantly surprised how stable image and satisfactory low-light condition this came out (I now settle with highest saturation and auto white balance). For those who think of best way to mount the keychain cam, I say the key is a vibe-free aircraft (especially hard for a small helicopter but I'm pleasantly surprised my 130X is pretty good at this). Don't worry too much about a rigid or shock-absorbing mount. All I did was using 2 foam donuts from DVD cake-box and one of the foam pieces that came with the #16v2 packing and just sandwich them with the #16 to the 130X lower frame rails and then use a twist tie to hold them together. I didn't even use any piece of tape. Oh, and make sure the lens module is mounted rigid with the rest of the cam. Initially I used hot-glue to secure the lens module but I found that there's still some jello effect. I then put a drop of CA between lens module and battery plug and as you see there's absolutely no jello effect any more. I know it'll take more effort to remove lens module from the PCB but I don't foresee that to come any time soon [knock on wood].
http://www.youtube.com/watch?v=lcb_Hfn8b50
I would try mounting the cam at a slight downward angle to stop the picture from going dark all the time,,shouldnt need too much angle and wont loose too much sky from the pic,,have any of you guys tried this ? whats the magic angle ?
Magic k2 is offline Find More Posts by Magic k2
Old Jan 20, 2013, 10:20 AM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
The angle will vary with the lens AOV, but I use about 12-15 deg. with my lens A camera. It will take some trial and error, and will still be a bit of a problem with the slight pitching that occurs in flight.
But it also depends on what is the more important portion of the frame you are trying to capture, obviously. In this case, the sunset would be the prime area of interest for me, so I wasn't that concerned about ground detail. Aiming the camera down in this case to brighten the ground detail would wash out the sunset detail in the clouds even more than it already is.
YMMV.
Tom Frank is online now Find More Posts by Tom Frank
Old Jan 20, 2013, 10:44 AM
hakank is offline
Find More Posts by hakank
Sweden (┼kersberga)
Joined Nov 2004
I believe I found a slight defect in the latest firmware, 0.67. it looks like it also exists in 0.49.
If Auto-shutoff is set to off it's not possible to turn off video recording. What happens is when trying to do so is a short flash but the recording continues and it's not possible to turn it off unless the power button is pressed until it shut off. However when trying to start the camera after this exircise it will only flash 3 times and shutoff. It will do so until it's reset by formatting for example.
hakank is offline Find More Posts by hakank
Old Jan 20, 2013, 11:44 AM
therau2000 is offline
Find More Posts by therau2000
Joined Mar 2012
deleted
therau2000 is offline Find More Posts by therau2000
Old Jan 20, 2013, 11:50 AM
Joined Mar 2012
deleted
Old Jan 20, 2013, 12:23 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Anyone interested to participate in upcoming discussions regarding Android Configuration Assistant, please send me an email with subject: Android
For all those who have already done so, there is no need to send another email.
You didn't mention how the discussions will be done, but hopefully it will be in a separate forum location or via group PM/email since it's a bit off the beaten path for general #16 reading here. Thanks.
Old Jan 20, 2013, 12:35 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by hakank View Post
I believe I found a slight defect in the latest firmware, 0.67. it looks like it also exists in 0.49. If Auto-shutoff is set to off it's not possible to turn off video recording. What happens is when trying to do so is a short flash but the recording continues and it's not possible to turn it off unless the power button is pressed until it shut off. However when trying to start the camera after this exircise it will only flash 3 times and shutoff. It will do so until it's reset by formatting for example.
Can you be more specific about how you are turning off the camera in the above section of your post that I underlined. I cannot duplicate this. A short press of the power button when the camera is recording will cause it to simultaneously capture a still frame image and save it to the flash card. A couple of fast blinks of the yellow LED accompanies this if you have the recording indicator function turned on, and then the camera continues normal video capture. This is how it is supposed to work.
If you stop the recording by a long press of the Power button rather than a short press of the shutter button, the camera should shut down, and restart normally again without the need for a reset, formatting, or anything else. This is how mine functions, so you may have some issue with your memory card causing this. But I'm still not sure exactly what you are doing, and also I need to know all the other config settings you have to try to duplicate this.
Old Jan 20, 2013, 01:05 PM
Joined Mar 2012
deleted
Old Jan 20, 2013, 07:27 PM
l.aluffi is offline
Find More Posts by l.aluffi
Italy, Piedmont, Asti
Joined Jun 2012
On Ubuntu 12.04, connect camera first in webcam mode then start Cheese;
it works fine.
Nice to see that there are brothers in linux...
I run ubuntu 10.04 and here below my dmesg. Everything is working fine.
[21165.286424] Linux video capture interface: v2.00
[21165.307097] uvcvideo: Found UVC 1.00 device USB PC Camera (0603:8612)
[21165.308018] usbcore: registered new interface driver uvcvideo
[21165.308021] USB Video Class driver (v0.1.0)
I will give a go to Ubuntu 12.04 to check if it's ok, but I did it some weeks ago and it was good.
Mine it's a V1 camera with 0.58 firmware.
l.aluffi is offline Find More Posts by l.aluffi
Old Jan 20, 2013, 08:50 PM
metalbender4by is offline
Find More Posts by metalbender4by
hey whats burning?
metalbender4by's Avatar
United States, FL, Vero Beach
Joined Oct 2007
I have to say I really like this camera. I've been using it for about a month now and have mostly replaced my GoPro with it. Even though the GoPro can do better video (not to say this does'nt do great) this camera out preforms it in most other areas, and produces's an excellent video. Its lighter and cheaper(a lot cheaper) and you can get replacement parts for it. I payed a fortune for my GoPro and if it gets damaged it's done.
Thank you for making this camera what it is.
I only have one for now but will be getting some more.
I pulled these from one of my flight videos from today.
metalbender4by is offline Find More Posts by metalbender4by
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
