Joined Nov 2010
Open the case, carefully remove the 3 screws holding the board in position, remove the board and disconnect the battery. Now you should remove the ribbon cable from the socket and insert it again making sure it is absolutely aligned at 90° to the socket. Rubis posted an excellent video here. Be very careful not to bend the cable or you may crack one of the wires. If the lens assembly got the full blow of the crash it is likely damaged. A new lens would solve the problem. You didn't mention which lens you have. If it is the D lens, it is especially fragile because it has no protection casing surrounding it. |
Joined Oct 2006
There are over 7 parts to the lenses interior housing. should not allow bare hands to touch the lenses. this makes up how the fish eye works. they are so small, for some to even bother, and so cheap today to repurchase.. So give it a shot, take some photo's, video and post up. so future user's who come across this issue can go about the repairs.
If you decide to go about. May be worth to contact seller if it was a separate purchase? |
It's possible one of the traces in the ribbon cable was cracked, which would make the camera inoperative. An alternative would be to just try a new lens module first... maybe the rest of the camera is OK. If that doesn't work either, you can still use the other lens module with a new camera. You have three different lenses to choose from...
Joined Nov 2010
[EDIT] Oops, sorry, my post coincided with Tom's, but it shows the general consensus is that the problem lies with the lens. [/EDIT] |
Bug...not sure?
Using Iso's GUI (latest version). Starting with Photo Frame size set to 1280x720 and Time Lapse Photos set to off Video Frame Size set to 848x480. There are several profiles that have been saved for different lighting conditions. If i select a saved profile (changing from profile in use) the Photo Frame Size is automatically switched to 1280x960 and the Time Lapse Photo is automatically set to 1s. This only happens when selecting a saved profile. If the Advanced Image Settings are changed one by one,sliding each setting,then automatic changing of the Photo Frame Size and Time Lapse Photos does not occur. |
Joined Oct 2006
Hey crash74
Here is a shot you can putto the audio file right off the 808 cam. I changed all my file names, nd need not a gps to know where I was at. where was I? ![]() Just in the distance you see a Peddler with two baskets. that is the distance, of him calling, nope. |
Joined Nov 2010
). Could you PM me the Nr16Setup.cfg file, which also contains the profiles, and indicate the profile name(s) causing the possible problems? Like I said, it will be a couple of days until I can check. I know a lot of people use the profiles, but a problem like you outline has never been reported. But who knows, no software is 100% bug free
Joined Oct 2006
This is a video of the end of the keycam 808 this is a video that you pass up you will never k ow what you are missing. So for those who cannot make a news resolution. .....
Happy New Years http://www.youtube.com/watch?v=-uaxkctYzud |
| Thread Tools | |
| Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) | Tom Frank | Aerial Photography | 9835 | Apr 21, 2013 05:37 PM |
| Discussion Looking to buy #11 HD Key Cam within US | Abolfazl | Aerial Photography | 1 | Feb 14, 2012 01:59 AM |
| Poll Poll For Current and Future #11 HD Key Cam Users | Tom Frank | Aerial Photography | 0 | Sep 25, 2011 11:55 PM |
| Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! | Jaybee | Aerial Photography | 4 | Jun 02, 2011 11:39 AM |
