The sound fidelity and sensitivity is pretty good for my use, amazing really for a 17g machine. Maybe someone could install a microphone jack and test with a shotgun mike?? |
So I took people's advice and didn't open mine to figure out mounting. I just CA'd some carbon fiber spars from some damaged foam blades to the camera. It mounts perfect to the skids and struts and the vibration is pretty minimal even from my little 120 heli.
OK, I misunderstood your first post since it didn't have this specific information. I think you are saying the video stops after about 12-1/2 min. of recording? If so, that could be a problem with the memory card or the battery, not the config. setting. Is this happening with more than one memory card? How long do you re-charge your battery. Have you tested this using a stronger power source, e.g. the car charger to rule in/out the battery as a possible root cause?
I played them all back simultaneously, and muted them all, then turned each sound track on separately. And as we've all pretty much agreed, High and Middle volume for all practical purposes sound identical to my ear (and most other users, I think). The Low volume was slightly less, but very little. The screen grab of the native video waveforms I posted in a recent post was from this test to show there is a difference in the sound amplitude with these settings, but until we can see the sound displayed with a logarithmic decibel (dB) level for each at the same point in time in the audio, we don't have any definitive information on how they should sound. We can only tell how they do sound. A 3dB change in sound pressure is barely audible. A 5dB change is clearly noticeable, a 10db change should sound about twice as loud. A 20 dB change should sound about 4 times louder. Based on this, I'd guess the Low setting is about 5dB below the middle and maybe 7-8dB below the highest. I want to test this theory just for the sake of knowing what is happening in the videos. |
Joined Nov 2010
foggy images
Somebody asked in the last few pages of switching lens or just taking the lens off completely. The response was you would get an overly white exposed image. I was wondering if light leaks around the lens itself would cause that milky image I get with my camera. I have not taken the lens apart nor adjusted the focusing range. But somebody suggested to use some de-gluing CA agent and the lens screws out easily. maybe a little fine dust has worked its way inside. If that's the case then a little air blast might make my camera work like new.
| Thread Tools | |
| Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) | Tom Frank | Aerial Photography | 9861 | Yesterday 04:14 PM |
| Discussion Looking to buy #11 HD Key Cam within US | Abolfazl | Aerial Photography | 1 | Feb 14, 2012 01:59 AM |
| Poll Poll For Current and Future #11 HD Key Cam Users | Tom Frank | Aerial Photography | 0 | Sep 25, 2011 11:55 PM |
| Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! | Jaybee | Aerial Photography | 4 | Jun 02, 2011 11:39 AM |
