Old Dec 21, 2012, 06:35 PM
Flyor is offline
Find More Posts by Flyor
The Netherlands, ZH, Rotterdam
Joined Aug 2012
Originally Posted by metalbender4by View Post
Wow it was still working under water. Was it in a case? Hope yo didn't loose to much.
Yep still filming under water, the orange led was still blinking when I finally found the heli again, I had to jump in there also, not my favorite sport in the winter
At home I rinsed the cam with clean water, opened the case blew the water away with an airgun/compressor sprayed some WD40 on the electronics used the airgun again to remove the excessive WD40 and cleaned the lens, seems to work as usual again, but I can tell for sure when its light again.
There might be some water damp between the lens elements, the CCD was still dry.
The heli also got the WD40 airgun treatment and seems to be ok also
Regards
Flyor is offline Find More Posts by Flyor
Old Dec 21, 2012, 06:44 PM
massimopaolo28 is offline
Find More Posts by massimopaolo28
Joined Dec 2012
Originally Posted by Tony32 View Post
As many others post their videos, I might as well post one aswell. Timeleapse filming outside my apartment using a external battery. #16camera
http://www.youtube.com/watch?v=JTvfI-tAifo
1 pic/sec 0.58 firmware
Does this camera work with external battery? how? what external battery are you using?
massimopaolo28 is offline Find More Posts by massimopaolo28
Old Dec 21, 2012, 07:37 PM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
If you do a Thread Search on External Battery you will get 400 odd hits,
If you look in the FAQ (post #1,#2,#3) there is a section on External Battery.
If your particular requirement is not covered, I'm sure the assembled mob can help you out then.
empeabee is offline Find More Posts by empeabee
Old Dec 21, 2012, 08:48 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
You can power it from a 5V source through the USB cable that typically comes with them. I have powered mine from both the MultiWii copter board and directly from an extra 5V port from my Rx.
Qrome is offline Find More Posts by Qrome
Old Dec 21, 2012, 09:13 PM
Neko is offline
Find More Posts by Neko
United States, IL, Chicago
Joined Nov 2007
Just got me one for Christmas. A bit early. Long story. It works fine for about half the test videos I've taken (10-15 seconds). But on the other half, the image breaks up and gets pixelated and cartoon colors every second for 1/2 second.
I'm using a Sandisk Class 4 4-GB memory card. Web-cam function works fine.
Any suggestions?
David
Neko is offline Find More Posts by Neko
Old Dec 22, 2012, 01:22 AM
Ajithkumarc is offline
Find More Posts by Ajithkumarc
Joined Oct 2011
Did anybody tried powering the keyring camera using AA batteries using external battery holders.
An external battery holder which can hold around 4 AA batteries can be used as external power for the camera to keep it on for more than a day (depends upon mAh of the battery). Very useful while enabling motion detection feature.
Ajithkumarc is offline Find More Posts by Ajithkumarc
Old Dec 22, 2012, 01:23 AM
Joined Oct 2011
Old Dec 22, 2012, 02:10 AM
Mtz is offline
Mtz
Find More Posts by Mtz
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
This is my power pack, something like this.
enjoy,
Mtz
Mtz is offline Find More Posts by Mtz
Old Dec 22, 2012, 03:17 AM
Grantham Kid is online now
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
I have a 4.8 volt NiMh flight pack from a Optic 6 that I have never used but it is still OK. I guess I could use that. It has the right plug on it.
Grantham Kid is online now Find More Posts by Grantham Kid
Latest blog entry: A bit about me
Old Dec 22, 2012, 06:26 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
I have the Vaas 5000mah. not the best, nor the worst. 2 port charger.
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Dec 22, 2012, 06:40 AM
mallettron is offline
Find More Posts by mallettron
Ronnie - Sheffield UK (G0NJD)
mallettron's Avatar
Sheffield, S. Yorks, UK
Joined May 2007
FPV while taking stills?
Hello, just having a play while the weather is rubbish
Thought I would try taking still (1 every 10secs) while video out
Would you FPV when the screen goes blank for about 1/4 sec while it takes a still?
I dunno
I suppose with the weight of the #16 I could use another at the same time for video as well
mallettron is offline Find More Posts by mallettron
Old Dec 22, 2012, 07:04 AM
Flyor is offline
Joined Aug 2012
file names
Hi guys
Wouldn't it be nice if the 808 #16 would remember its last file name[number] like most cameras do, even when the files are deleted from the microSD card. this would give consecutive file names like mini0000.mov upto mini9999.mov
Just a thought
Regards
Old Dec 22, 2012, 07:21 AM
Joined Oct 2006
Originally Posted by Flyor View Post
Hi guys
Just a thought
Regards
asked time and time again. this can manually be done. and that should be a continued thing. Some camera's just toss random sub folders, which is great, because you can rename the sub folder, and have that number continued in the sub folder count, as a file that you should try
1.iDCIM/100MIN change to 101MIN and you will not delete existing SUbfolders
Old Dec 22, 2012, 09:19 AM
VideoKing is online now
Find More Posts by VideoKing
VideoKing's Avatar
United Kingdom, England, Kent
Joined Dec 2010
Hi guys
Just a thought
Regards
When you finish copying the files over to your PC, and have deleted them from the camera card. Right click on your PC and create a new text file on the camera card.
Click on the file you just created and rename it to "MINI0045.MOV" (ALL IN CAPITALS), or whatever number you want it to start from.
You will then find the camera will carry on recording from the number of the file you created.
Just remember that next time you download the files the first one will be nothing or blank.
Simples.........
VideoKing is online now Find More Posts by VideoKing
Old Dec 22, 2012, 10:06 AM
Joined Oct 2006
Simples.........
Yes that is the manual way, but what we , some of like would be an automatic way? This is a way some of the costs, or work was best to be kept simple.
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
