Old Dec 18, 2012, 07:04 AM
pardus is offline
Find More Posts by pardus
Graham Dyer
pardus's Avatar
Johannesburg, South Africa
Joined Jul 2003
Originally Posted by Ajithkumarc View Post
Tom frank,
It will be of great help if u can inform the manufacturer of these cameras to include an external power adapter (a/c from wall socket) connection option in their next version. It will be of great use to while using at home as a surveillance equipment at home with motion detection turned on.
...Or just to have it function as a camera while powered by USB so you can use any phone charger?
pardus is offline Find More Posts by pardus
Old Dec 18, 2012, 07:18 AM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Tom frank,
When you post here, the manufacturer will be aware of it, so no need for me to do it again. But quite honestly, if you don't already have a USB "wall wart" power supply that came with a cell phone or other electronic device, just go buy a simple USB wall plug power adaptor from a local variety stored that sells electronics.
There are several different A/C voltage and plug designs used around the world, so that overly complicates the situation for the camera manufacturer.
Tom Frank is online now Find More Posts by Tom Frank
Old Dec 18, 2012, 07:26 AM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
But can the camera be used when plugged in to a USB charger, I can't get mine to actually take video or stills?
Old Dec 18, 2012, 07:33 AM
Ajithkumarc is offline
Find More Posts by Ajithkumarc
Joined Oct 2011
I have a charger which can intake a/c power from wall output. When i connect the same to camera, both red led and orange led glows together. When i press the power button once (press for 1 second) both lights turn off.
Can u give more idea of what is actually happening?
The adapter name is MP3 MP4 power supply which came along with my #11 jumbo 808 camera.
Input: AC110-220V 50/60Hz
AC10mA
Output: DC 5.00 0.20V
DC300mA 30mA
Ajithkumarc is offline Find More Posts by Ajithkumarc
Old Dec 18, 2012, 07:38 AM
Joined Oct 2011
The same problem for me.
Old Dec 18, 2012, 07:49 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Tom frank,
I agree with Tom, any 'wall wart' AC to USB 5 volts at 1 Amp supply will supply the camera.
For Your.Iinformation, eletoponline365, along with the #16, do a 12v DC to USB 5V 1 A adapter
Here
and also a US (240-110v AC to 12v DC power supply Here
They also do one with and EU plug.
empeabee is offline Find More Posts by empeabee
Old Dec 18, 2012, 08:42 AM
Joined Oct 2011
AC10mA
DC300mA 30mA
This is the specifications of the charger i have used.
http://pzy.be/v/2/charger.jpg
and below is the video link
My Movie 3 (0 min 36 sec)
Old Dec 18, 2012, 09:03 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
I'm not surprised
You should NEVER EVER use a charger sold for the #11. The #11 uses a non-standard cable for recording with external power. You are most likely inputting 5V onto the #16 video-out signal
Any standard USB power supply that can supply 300mA will work, as long as it wasn't designed for the #11 (non-standard).
The charger on your picture appears to be standard, but I'm sure the cable isn't....
The good news is that your camera appears to still be working and hasn't gone up in a whiff of smoke!
Isoprop is offline Find More Posts by Isoprop
Old Dec 18, 2012, 09:11 AM
Sam234 is offline
Find More Posts by Sam234
United Kingdom, England, Royal Tunbridge Wells
Joined Dec 2012
Originally Posted by blueprint View Post
I was able to mount my #16 Keychain camera onto my Pan/Tilt system.
Is that Velcro you used to fix it on with? I though of trying that but wondered if the wind would just pull it straight off.
Sam234 is offline Find More Posts by Sam234
Old Dec 18, 2012, 09:19 AM
Sam234 is offline
Joined Dec 2012
Don't know if its the same for the #16 (not got one) but with the #15 and the #20 if you turn on before connecting the usb and there is no data on the port (i.e. not a computer) you can use it as normal.
Old Dec 18, 2012, 09:37 AM
Joined Oct 2011
Originally Posted by Isoprop View Post
I'm not surprised
Good answer. The cable is a thinner one. You can see it on techmoan review - Go to 04:40 time of the video clip. Lucky that i didnt damaged the #16 camera by using the wrong charger
http://www.youtube.com/watch?feature...&v=cBnbuzCINV0
Old Dec 18, 2012, 09:53 AM
Isoprop is offline
Joined Nov 2010
Exactly as I suspected! VERY DANGEROUS!
Use the data (thicker) cable plugged into the charger and your #16 will work! The #16 doesn't distinguish between data and charging cables, they are the same. A standard charger will not use the data lines.
If you no longer have a #11, throw away that awful thin cable. If you still have your #11, mark the thin cable as such.
Old Dec 18, 2012, 10:04 AM
Joined Oct 2011
I have changed the thin cable with the thicker one (the one which i use to charge the #16 through my laptop USB) but while connecting to wall socket nothing happens to the camera. Neither green light, red light or orange light.
Do i have to use a different wall socket plug
Old Dec 18, 2012, 10:59 AM
Isoprop is offline
Joined Nov 2010
The wall socket plug should be OK.
Question. Does the camera work without a cable connected? I hope so.
Assuming the camera works, record a minute or two of video.
Now attach the camera to your PC using the thicker cable.
Does the PC recognize the camera drive?
If yes, the cable is OK.
Turn off the camera and unplug it from the PC. Now connect it to the wall plug and watch the LEDs for about a minute. During this time the green LED should turn on. If not, does the green LED turn on when connected to the PC (camera turned off)?
If it does, then the wall plug/cable connection need more investigation... or is not compatible, which is doubtful.
Old Dec 18, 2012, 11:38 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I never fly without that little added protection... The velcro patch underneath the camera and a strap over the camera that is attached to structure.
Sparky Paul is offline Find More Posts by Sparky Paul
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
