Old Dec 14, 2012, 02:47 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I've done to most of my 808s... makes seeing the LEDs in daylight a lot easier.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 14, 2012, 05:30 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
hi guys. something is up with my new keychain cam.
i changed my sdhc card to a sandisk 8gb class 4. i was using a Samsung 16g Class 6 but the cam would turn off after about 15 minutes... sometimes it would shut off by itself in 5-10 minutes.
with the new sandisk im still getting shut downs after 5-10 minutes... whats up? is this a setting issue? battery is fully charged.
blueprint is offline Find More Posts by blueprint
Old Dec 14, 2012, 05:47 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Settings have no impact on this, other than you should have video-out function toggled OFF if you don't use it. It will eat up about 10 min. of recording time when it is ON.
It sounds like a battery/charging issue. Make SURE your USB cable is not faulty (many are). Try another charging cable, or two if necessary. Charge for at least 2-1/2 hours after a shut down (ignore the green LED).
Does it still do it? If so power the camera from an external USB power supply with a KNOWN good cable. Does the camera now keep recording? If so, your battery is likely weak, or needs more cycles on it to come up to full capacity. Try another battery.
A less likely cause could be a faulty charging circuit in the camera. After a full charge cycle, measure the voltage on the camera battery. It should be a nominal 4.2V if fully charged.
And do all testing indoors where it's warm... cold will drastically reduce the battery's ability to deliver current without dropping voltage too low to power the camera.
Tom Frank is online now Find More Posts by Tom Frank
Last edited by Tom Frank; Dec 14, 2012 at 08:04 PM. Reason: bolded and underlined sentence for emphasis
Old Dec 14, 2012, 05:51 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
Which firmware? I had problems with the 0.58 beta firmware randomly stopping recording. I switched to the stable 0.49 and haven't seen the problem so far.
LittleMo is offline Find More Posts by LittleMo
Old Dec 14, 2012, 05:56 PM
Mtz is offline
Mtz
Find More Posts by Mtz
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
Just a simple and great idea!
Mtz is offline Find More Posts by Mtz
Old Dec 14, 2012, 05:59 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
i updated to the 0.58 and it's shutting off.... perhaps i'm just not letting it charge long enough. I'll update to the 0.49 and give it a shot.
Old Dec 14, 2012, 06:01 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Thanks!!
Im using my iPhone charger connected to a wall outlet. Using a different standard USB cable to charge the camera. While charging it is green but I assume it's fully charged once the light goes off. Perhaps i'll leave it plugged for 2 hours or so regardless of the light.
It was very cold today so that may have something to do with it. I'll test it indoors and see if it goes off after 25-30 minutes.
I will update the firmware to the 0.49 and give it a shot.
Old Dec 14, 2012, 06:03 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
How long are you charging it after a shut down? FW has not had any effect on recording time during my testing.
Old Dec 14, 2012, 06:10 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
It did for me. The 0.58 firmware would randomly power off the camera after about 6 minutes or so.
Old Dec 14, 2012, 06:18 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Yes, I read your post several posts ago. If it were a FW problem, everyone would have it if they toggled the exact same settings that you had. Unless it can be repeated, I don't think it's FW related. If you can repeat it and give me all your settings, I'll see if I can duplicate it.
Old Dec 14, 2012, 06:21 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
It might depend on the specific SD card though.
Old Dec 14, 2012, 06:29 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Yes, it sure could, but then would be a memory card problem more than FW. There was a wide spread problem with many memory cards of higher speed class a month or two ago, most all would shut down very soon after recording started (about a minute or so). None would record for 10-15 minutes before shutting down. And that problem was fixed with new card communication code several FW revs. ago. This fixed those problems based on user feedback.
Did you try a different memory card before coming to the conclusion it was the camera FW?
Old Dec 14, 2012, 06:40 PM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Sheesh, sorry to ruffle the feathers.
0.49 works, 0.58 does not with same SD card. What difference does it make if it's the FW or the SD card? I'm happy with 0.49.
Old Dec 14, 2012, 06:58 PM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
The voltage mismatch between external battery and internal battery at instant of connection can try to force too much current into the tiny camera battery. While it has an excess current protection circuit, I don't know if it's bi-directional... it's mainly for short circuit protection of the battery. Why risk it?
The best way is to feed +5V USB level power in through the camera USB port, but it seems so many want to bypass it with a single external lipo cell.
Tom, has anyone mentioned this device for boosting a single LiPo cell to 5 volts ?
Might be simpler than all these battery hacks...
It says it's for receivers but it has more than enough current for a micro camera.
http://www.hobbyking.com/hobbyking/s...to_5v_1A_.html
Martin
PLMS is offline Find More Posts by PLMS
Old Dec 14, 2012, 07:00 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
My feathers are smooth. Knowing the root cause of problems makes all the difference in the world when trying to help someone else who may have the same symptoms, which is what this thread is all about.
If your problem could have been solved with a different memory card, that would be a better solution if you wanted to take advantage of the enhancements in v0.58 FW. And if it was a specific card compatibility issue, we have kept track of those in the past to alert others.
But as long as your happy, don't worry about it.
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
