United States, NY
Joined Sep 2005
I downloaded the GUI. Followed the instructions everything went well.
I tried the camera and it was working great. I wanted to put it on the bottom of a quadcopter so I opened the GUI flipped the image 180* and lowered the sound to low. Was having trouble getting the camera on then it seemed to work. Flew 1 flight and wanted to view the footage. Plugged the camera into my PC and the PC could not find it. I tried the GUI again and it could not find the camera. I tried to pull the card and put that into the card slot on the PC and it was not found. I went through the GUI instructions again: disconnection it turning it off and holding the shutter then the power until the light goes off then releasing the shutter & connecting it again. Neither the GUI or PC can find the camera. Does anyone have any suggestions as to what I can do to get it to work again? |
Joined Nov 2010
If you have mistakenly prepared the camera you should delete the configuration file, or, much easier, format the card from within the GUI. Obviously this doesn't help if your PC doesn't recognize the camera or the card. The card slot on your PC most likely also runs off the USB bus, so I suspect the problem lies within your PC. Have you tried turning off the PC and then turning it back on? When you connect the camera, connect it directly to the PC and don't use a USB bus. If your PC still can't recognize the camera, use a different USB cable or try using another PC. Does at least the green charging LED come on when the camera is off and connected to the PC? If the battery is discharged, you'll have to charge it first. |
United States, NY
Joined Sep 2005
I plug in the camera via usb cable. Green light is on & charging. Press the on-off button and the yellow led then it goes red. The computer goes bong bong(as it always did). BUT no "K" drive in "my computers" & the GUI does not find the camera either. If I plug my thumb drive in the same USB port "K" drive appears after the bong bong. |
Try a different memory card in the camera, too. Turn your camera on with no card in it... the yellow LED should start a slow flash every second indicating no card detected. Then insert a card. The camera should then boot to the normal yellow LED. Those test should help rule out a problem with the card or the camera's card slot. If you can confirm that the card is not being detected, your card slot in the camera could have a dirty, bent, or broken pin preventing the card from being read. But it's virtually impossible to see if that's the case without opening the card slot cover (NOT recommended). But you could try to clean the pins with a little alcohol on the card pads, then repeatedly insert and eject the card several times. I sometimes use a very thin piece of card board wetted with alcohol inserted in the card slot to wipe the pins. This may all be for naught, but it will help isolated the problem. |
United States, NY
Joined Sep 2005
I turned it on without the card in it did as Tom said. I replaced the card and the went steady.
In "Properties" it says it is working properly. When I try to open K drive it just freezes my PC. I hooked it up to my laptop, it found the hardware, but I couldn't open "e" drive. I finally tried to format E drive and it states "no drive found? Can I format it in the camera? |
"jurepu" mention his way of switching between external and internal batteries. My way is this:
I am using here little connector which can be found on some old computer parts or can be bought in electronical store and tiny switch I bought from DX as PSP spare part. Wiring is easy. I only cut in half the positive internal battery wire to solder it on switch and add there only two extra wires for external battery. On the photos there is not the magnets on camera yet, but I am going to add them there on the camera. Magnets are also on external battery and there I ad connector to fit one I aded on camera, so I can not connect the external battery wrong way if I made wiring correctly. Switch in position one means that the internal battery is working, in position two means that external battery can be connected. And yes it also resets internal clock every time the switch position is changed. Connector and switch on camera I aded are hot glued. What do you people think about my way? |
Joined Nov 2009
@Tom the focus was so bad that with the cam placed at eye level , i could not see the letters on the keyboard. Now it's Clear. |
Joined Aug 2012
A four pin connector with one pin not connected would be a safer solution. |
Joined Nov 2009
Video Bit Rate
The Bitrate for the videos i've taken in both dim and bright condition with constant motion have similar bitrate(around 6500kbps) and the videos aren't as sharp (noise evident). I'm wondering whether the class4 microSD is impacting the bitrate. btw I'm using a Kingston class4 8GB micro SD card.
Noise is caused by the light level. If there is a lot of motion in a lower light situation and the camera is using a shorter shutter speed to tame the motion, it MUST boost the gain to get proper exposure, and that results in video noise artifacts. And the H.264 video codec uses a variable bit rate, which it will boost or diminish depending on what it determines to be adequate to maintain an equivalent video quality for the scene motion and detail (the settings in the GUI are average bitrates, not constant bit rates). Have you tested your card for speed (D/L the Diskmark.exe speed test utility to make sure your card is performing up to specs)? |
USA, OH, Marysville
Joined May 2010
The best way is to feed +5V USB level power in through the camera USB port, but it seems so many want to bypass it with a single external lipo cell. |
| Thread Tools | |
| Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) | Tom Frank | Aerial Photography | 9835 | Apr 21, 2013 05:37 PM |
| Discussion Looking to buy #11 HD Key Cam within US | Abolfazl | Aerial Photography | 1 | Feb 14, 2012 01:59 AM |
| Poll Poll For Current and Future #11 HD Key Cam Users | Tom Frank | Aerial Photography | 0 | Sep 25, 2011 11:55 PM |
| Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! | Jaybee | Aerial Photography | 4 | Jun 02, 2011 11:39 AM |
