Old Dec 05, 2012, 05:11 PM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Weird colors may be due to the cmos cable being badly seated.
victapilot is online now Find More Posts by victapilot
Old Dec 05, 2012, 05:33 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
That was my first inkling, but on two cameras which have reportedly normal colors in web cam mode (with signal from the same imagers) seems to rule out a bad ribbon cable connection. Maybe something strange going on it the DSP chips? The web cam video is MJPEG compression, not the normal h.264 encoding in the normal video. Or was the same flash memory card used in both cameras... maybe a card issue? But first I'd be interested in the camera color settings and firmware being used (I'd flash in v0.58 firmware and re-test.
Tom Frank is offline Find More Posts by Tom Frank
Old Dec 05, 2012, 06:00 PM
jwt873 is online now
Find More Posts by jwt873
jwt873's Avatar
Canada, MB, Woodlands
Joined Oct 2012
Originally Posted by l.aluffi View Post
  1. I switched on the camera and started to record some footage while driving to my office;
  2. As I arrived I tried to stop recording but pressing the shutter button did nothing. Status led never turned yellow;
  3. I had to switch off the camera with the power button;
  4. Movie was recorded and I've found a 1.5GB file.
This happened to me a couple of days ago with one of my #16 cameras that had been recently loaded with mov v0.58 firmware.. I had only been recording for about a minute and I couldn't get it out of record mode. The shutter button did nothing. I had to use the power button to shut it down.
I 'cured' it by turning it on and then using a toothpick to press the reset button on the side. After that I reloaded the camera configuration using the Nr16SEtup utility. It has never happened since then.
jwt873 is online now Find More Posts by jwt873
Old Dec 05, 2012, 06:32 PM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
I did some more testing. took a couple pics with both cams and the colors were fine. tried a video of the same thing (rolls of colored vinyl for my sign biz ) and the video was the same off colors as before. When I uploaded the video to youtube it played correctly. looks like its a problem with my video players. I use quicktime 7.7.3 and media player classic on a windows XP machine. I'll try on another pc. thanks for the info.
signguy is offline Find More Posts by signguy
Old Dec 05, 2012, 07:10 PM
zrobbie is offline
Find More Posts by zrobbie
Colorado Mountains
Joined Aug 2010
Maybe a missing codec on your computer. Also try VLC player, it plays almost anything.
zrobbie is offline Find More Posts by zrobbie
Old Dec 05, 2012, 07:16 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
getting vlc now...
Old Dec 05, 2012, 10:27 PM
jmdlcar is offline
Find More Posts by jmdlcar
USA, OH, Marysville
Joined May 2010
Can someone tell me which is the same plug as the battery plug?
1. http://www.ebay.com/itm/Mini-Micro-J...item27cd2556f1
2. http://www.ebay.com/itm/Mini-Micro-J...item2a25933cb6
3. http://www.ebay.com/itm/Mini-Micro-J...item2a25933cb3
Which link if none can you point me to it.
Jack
jmdlcar is offline Find More Posts by jmdlcar
Old Dec 06, 2012, 02:04 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
Jack
I expect them all to fit the plug. The picture in the first link looks as if it almost matches the right-angled #16 socket. The mounting tags at the edges look a bit strange though. The original plug doesn't have these. Rubis posted a picture of how the plug should look here. The other sockets are vertically mounted, so I don't know if there is enough clearance at the top to insert the plug and cable when the top casing shell is screwed into position.
I measured my socket as 4.25mm wide, 4.62mm high and 3.4mm narrow.
Maybe the measurements published are only approx. or the plastic is thicker in one plug than in the other. It is not easy to take an exact measurement, as I found out.
Isoprop is offline Find More Posts by Isoprop
Old Dec 06, 2012, 02:19 AM
sidneylopsides is offline
Find More Posts by sidneylopsides
Leeds, UK
Joined Dec 2003
Jack
I've ordered a set that I think will fit, I'll update you on here if they do!
sidneylopsides is offline Find More Posts by sidneylopsides
Old Dec 06, 2012, 02:45 AM
Mtz is offline
Mtz
Find More Posts by Mtz
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
This is my collection of JST-XH 2 pin cables and is like this. ( SKU: MINIJST-EXT5 )
Mtz is offline Find More Posts by Mtz
Old Dec 06, 2012, 03:41 AM
l.aluffi is offline
Find More Posts by l.aluffi
Italy, Piedmont, Asti
Joined Jun 2012
What are the other settings? Some functions will begin recording as soon as the power is turned on, and won't stop until the cameras is powered off. Post your camera's config file here... I'd rather not guess.
Here are there are the settings. Now it's starting to let the yellow light off even in the case of short recordings.
Reset button seems to do nothing: am I supposed to let the sd card in while I press it or do I have to pull it off?
Code:
Date time=[2012/12/06-07:03:49];date time setting,format yyyy/mm/dd hh:mm:ss,
Movie resolution=[0];Movie resolution setting,0:720p,1:wvga,2:vga,
Movie cycle time=[3];movie cycle time,0:5 minutes,1:20 minutes,2:40 minutes,3: 70 minutes,
movie Loop Recording=[0];set loop recording on or off,0:off,1:on,
Movie stamp=[1];set date / time stamp on or off,0:off,1:on,
Movie sound=[2];set movie sound,0:mute,1:level 1,2:level 2,3:level 3,
LED=[0];set LED flicker when recording,0:off,1:on,
Movie quality=[1];set movie quality,set movie data rate,0:10 Mbps,1:7 Mbps,
Power off=[1];set system auto power off time when system pending,0:off,1:30 seconds,2:1 minutes,3:2 minutes,
Movie Flip=[0];set movie rotate,0:off,1:on,
TV out=[0];set Tv out,0:off,1:NTSC,2:PAL,
Capture Size=[1];set photo size,0:1280x960,1:1280x720,
Auto Record=[0];set movie auto record,0:off,1:on,
Exposure Value=[2];Exposure compensation,0:-2EV,1:-1EV,2:0EV,3:+1EV,4:+2EV
White Balance=[0];Set White Balance,0:Auto,1:Daylight,2:Cloudy,3:Tungsten,4:Fluorescent,
Contrast=[2];Set Contrast,0:-2,1:-1,2:Normal,3:+1,4:+2,
Color Effect=[0];Set Color Effect,0:Standard,1:Mono,2:Sepia,3:Cooler,4:Cool,5:Warm,6:Warmer,
Saturation=[2];Set Image Staturation,0:-2,1:-1,2:Normal,3:+1,4:+2,
Set Time Lapse Shooting[0],0:off,1:0.25s,2:0.5s,3:1s,4:2s,5:5s,6:10s,7:30s,8:60s,
Motion Detect=[0];set motion detect,0:off,1:on
Motion Detect Timeout=[2];set motion detect timeout,0:5s,1:15s,2:30s,3:60s
Motion Detect Sensitivity=[1];set motion detect Sensitivity,0:high,1:low
Movie Frame Rate=[0];Movie frame rate setting,0:30fps,1:25fps,2:20fps,3:15fps,4:10fps,5:5fps,
Power on=[0];set system  power on time,0:delay,1:fast
TV Display Ratio=[0];set display ratio,0:16:9,1:4:3
{MicroDVR mov 2012/11/27 v0.58}
{LDMICDVR,v1.1S,01/06/2012}
l.aluffi is offline Find More Posts by l.aluffi
Old Dec 06, 2012, 04:00 AM
ziggy95 is offline
Find More Posts by ziggy95
Joined Jul 2012
Hello, i have not read the entire thread.
I have a big problem.
I can't anymore start camera.
I explain:
yesterday night, i was trying to flash firmware but i think i did'nt respect all the steps.
Camera was blinking orange many times when trying to start.
Now, i removed the microsd card and i cant't start anymore.
no orange blinking, no red, nothing.
Any idéas ? I tried reset but nothing better
ziggy95 is offline Find More Posts by ziggy95
Old Dec 06, 2012, 04:04 AM
ziggy95 is offline
Joined Jul 2012
in fact , i have quick orange blinking with class 2 and nothing with class 10.
This class 10 was working with camera lens B. This one is lens D.
Old Dec 06, 2012, 04:08 AM
Fugitive_Bill is offline
Find More Posts by Fugitive_Bill
CURIOSITY Has Landed!
Fugitive_Bill's Avatar
Sydney, Australia
Joined Jul 2005
Ziggy,
I'd go back to firmware V.049. I tried upgrading to V0.58 'beta' and was getting a similar "Camera was blinking orange many times when trying to start..
It scared the heck outa me, as I thought I might have bricked a camera by screwing up the v0.58 install.
However once I went back to V0.49 all was fine. So I'll leave the cams like that until V0.58 is out of the beta stage or the next version is released.
-B!LL!
Fugitive_Bill is offline Find More Posts by Fugitive_Bill
Old Dec 06, 2012, 04:38 AM
Isoprop is offline
Joined Nov 2010
I explain:
A fast blinking yellow LED means the camera is updating the firmware. Sometimes the blinking stops almost immediately, sometimes it continues to blink, and sometimes it becomes solid yellow.
Whatever the case, if you ever see a fast blinking yellow LED, then WAIT 10 seconds, even if all the LEDs turn off.
If, after 10-15 seconds the camera is off, i.e. no LEDs are lit, then do the following:
1. Remove the card.
2. Turn on the camera and wait for the yellow LED to blink slowly.
3. Insert the card and wait about 2 seconds until the yellow LED turns on.
4. Connect the camera to the PC.
5. Delete the firmware file, format the card , or start Nr16Setup. Nr16Setup will automatically delete the firmware file as soon as you select the drive, so this is the easiest method.
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
