![]() I have no other information if this will ever be fixed, other than by user selection of an alternate white balance setting that is not automatic. Many users do this already with the fluorescent setting, sometimes coupled with saturation/hue offsets. I don't have direct communication with the #18 developer, nor have any clue about who shares info with whom. I doubt that happens when they are competing for the same market share. |
Cold weather will also drastically reduce the power delivery ability of a lipo cell. |
Leeds, UK
Joined Dec 2003
I never got chance to use that tiny Lipo, I was using the stock walkera Ladybird one for power, and thats still fine.
The vtx spec says it won't operate below 3.5v, so I'm going to try that and see how true it is, might work as a basic cut off. |
[/QUOTE]Ok, no prob. Any chance you could share the file? I don't care about bugs. ![]() I'm trying to set up my MicroQuad and at the moment the camera is no good as the video out is only in NTSC (I use PAL gear) and all I get is a distorted image and B&W. ![]() Last thing, is it possible to grab the video out from a point inside the camera? Because of the size of the Quad it would be great to have an alternative to the USB connector. It was already hard to avoid the props touching it. PS: If it wasn't asked before, having some battery indicator in the VideoOut out be great. |
http://www.rcgroups.com/forums/attac...mentid=5349495 |
Yes, video out signal is available on the back side of the USB connector where the pins are soldered to the circuit board. You will need pin #4 for the video out signal and pin #5 for the ground (unless you can pick up the ground plane nearby). These two pins are very small and very close together, so the soldering job will be intricate. Look here for the pin positions. You could also whittle away most of the rubber strain relief on the cable that protrudes out to angle the wires away from the props easier, or buy one of the 90 deg. right angle USB plugs with pin 4 wired (search for the post by Isoprop for the source) and make a new cable that way. And as a bonus, the latest FW already has a low battery indicator in the video out signal. An alert pops up when battery power is getting low. In my tests indoors at room temperature, I got about another 1-1/2 min of power before the battery crapped out with the camera's internal battery powering the camera and recording at the same time. A weak battery or lower temperatures will reduce this alert time. There is also an alert when the memory card is... gives a pretty accurate 30 sec. advance warning. |
The USB video out cable that connects to the camera branches out into two connectors. One is for VIDEO and the other is for POWER. It is possible to connect the VIDEO cable (the one with the yellow female RCA jack) to the POWER connector. (Both connectors are the same).. If you do that, you won't see any video out.. (I did manage to do this once by mistake and spent a bit of time trying to figure out why there was no video on my monitor ).
United States, CA, Marin
Joined Jul 2011
| Thread Tools | |
| Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) | Tom Frank | Aerial Photography | 9838 | Today 08:20 AM |
| Discussion Looking to buy #11 HD Key Cam within US | Abolfazl | Aerial Photography | 1 | Feb 14, 2012 01:59 AM |
| Poll Poll For Current and Future #11 HD Key Cam Users | Tom Frank | Aerial Photography | 0 | Sep 25, 2011 11:55 PM |
| Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! | Jaybee | Aerial Photography | 4 | Jun 02, 2011 11:39 AM |
