Old Nov 19, 2012, 10:15 PM
Otto Dieffenbach is offline
Find More Posts by Otto Dieffenbach
United States, CA, San Diego
Joined Aug 2011
FPV flying with my #16 D lens
I really love this camera for FPV.
FPV Mega Minor Capricorn flying with the Lake Poway Skimmers by Otto Dieffenbach (1 min 58 sec)
Otto Dieffenbach is offline Find More Posts by Otto Dieffenbach
Old Nov 20, 2012, 12:51 AM
savage 40 is offline
Find More Posts by savage 40
United States, CA, Oroville
Joined Sep 2007
So I got my three 808 #16's today.. I also asked and recieved some "special" cables (short) for my #11.. I grabbed the long cables and promptly started charging the #16's.. Much to my surprise after 3hrs charging the red light was still on and the cameras were warm.
I questioned myself and I'm assuming the long USB cables they gave me are also "special" cables as they have the two wire configuration.. I disconnected them and plugged in a reg USB cable I had and the LED lit green.
So my question is .. Did I damage the cameras by charging them with the "special" cables?
I then labeled all the cables accordingly
savage 40 is offline Find More Posts by savage 40
Old Nov 20, 2012, 01:42 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Originally Posted by crash74 View Post
The only "de-shake" filtering. is the filtering youtube does when they "fix" you videos. here is the raw unedited video.. remember it the raw footage so no complaining!! LOL.. I also used roxio media creator. ( a pain in the but) easy to create..very hard to make a quality format.. I had to save as an image file the convert to a video file both my computer and youtube would except...while trying to maintain a video that wasn't all blurry... Ohh... on this video I tole youtube "not" to correct the video in anyway...( ie raw) http://www.youtube.com/watch?v=MWLqS...ature=youtu.be
Personally, I think the 'raw' video (no deshaker) is much easier to watch.
thwaitm is offline Find More Posts by thwaitm
Old Nov 20, 2012, 02:01 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
I assume you are talking about the old, 5-pin, mini-USB #11 cables because the new, 8-pin, mini USB #11/#18 will not fit the #16.
If the cables are two-wire, long or short, they are most likely "special" cables if you ordered them for the #11
If you used the old #11 "special" cable you have most likely permanently damaged your camera. It is very clearly marked in the instruction manual that you must never, ever, use these cables
I have also posted many times that #11 "special" cables should be clearly marked as such. I have also criticized the special charging cables used by the #11/#18, new and old, a number of times. I don't know why the #18 developer kept this bad design in the new models.
The problem is the old #11 special cable uses pin #4 to charge the camera, whereas the #16 uses pin #4 for video-out. On the #16, pin #16 is directly connected to the processor so you have been pumping the processor with 5V, for 3 hours . Unless you have been very, very lucky, chances are you have destroyed the processor. The processor is the most expensive item on the board and cannot be replaced without specialized equipment and tools.
As a WARNING to others - never, ever, even think of interchanging #11 and #16 cables unless you are 100% sure the cable in questions is a standard cable.
Isoprop is offline Find More Posts by Isoprop
Old Nov 20, 2012, 02:46 AM
Crazy1 is offline
Find More Posts by Crazy1
Crazy1's Avatar
Joined Sep 2011
I'm about to order myself a 808 #16 HD and have a few quick questions.
If I order with D lens, can I buy A or B lens aswell and interchange lenses?
How can I mod the cam to run off external power? The supplier of the Receiver power cable will not ship to my country.
Does the 120deg lens have a little or a lot of fisheye? I am not fond of the gopro because of the amount of fisheye effect. Will I be better off rather purchasing the a or b lens?
Any suggestions welcomed. Thanks.
Crazy1 is offline Find More Posts by Crazy1
Old Nov 20, 2012, 03:09 AM
Isoprop is offline
Joined Nov 2010
See my answers in red below:
Yes, but the lens hole is much bigger for the D lens. Also, the hole for the B lens is a little larger than the hole for the A lens. It would most probably be better to order separate cases for each lens. Email the seller and ask him for the prices.
If you use 5V there is no mod necessary. Just connect 5V to the USB. It's standard.
There have been lots of comparison videos posted, but I'm afraid you'll have to search this thread. I like the A lens the best, but it is not so wide-angle as the others. The D lens has far too much fisheye for my likings, but it depends on what you want to use it for.
Tom posted a comparison of Lens A, B and D here, for example.
Old Nov 20, 2012, 04:11 AM
Joined Sep 2007
[QUOTE=Isoprop;23314806]I assume you are talking about the old, 5-pin, mini-USB #11 cables because the new, 8-pin, mini USB #11/#18 will not fit the #16.
I put an sd card in one.. And it still recorded..so I guess I better check the others? Dammit! .. Why in the world would eptoline (eBay seller check spelling) send all the cables mixed and not marked? I had ordered a couple special cables for my #11..
Old Nov 20, 2012, 04:34 AM
Isoprop is offline
Joined Nov 2010
[QUOTE=savage 40;23315162]
The cables are never marked, it's up to the user to mark them! I've only very, vary rarely seen a cable from any manufacturer marked. The same goes for power supplies. I've grown into a habit of marking any accessory that is non-standard - it will save you many headaches and maybe burnt devices in the future. Also mark your 808's if you have a few, #3, #16 etc.
If the camera still recorded, that may be a good sign. Keep us informed, also if video-out works or not
Old Nov 20, 2012, 04:42 AM
Joined Sep 2007
I do know the red charging light stayed on the whole time it was plugged in. After 3hrs I disconnected them as the light never went green.. Then I plugged in the regular USB cord and the light went green
Old Nov 20, 2012, 04:52 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
Removed helpful info
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Nov 20, 2012, 05:09 AM
VideoKing is offline
Find More Posts by VideoKing
VideoKing's Avatar
United Kingdom, England, Kent
Joined Dec 2010
The #16 does NOT have a red charging light, its green when charging and off when charged.
VideoKing is offline Find More Posts by VideoKing
Old Nov 20, 2012, 05:11 AM
VideoKing's Avatar
Joined Dec 2010
[QUOTE=fishycomics;23315297]
Isoprop
This is one of them . telling you not to directly plug into the wrong ports and camera, that is one company called Kodak for two camera's a zi8, and zi10.
So how does this gem of information help any #16 user ...........
Old Nov 20, 2012, 05:29 AM
Joined Oct 2006
Old Nov 20, 2012, 06:00 AM
crash74 is offline
Find More Posts by crash74
Addicted to Twins
crash74's Avatar
United States, AZ, Maricopa
Joined Jul 2011
I agree thx. It looks like youtubes deshaker shakes worse then the raw footage. I will reupload my video and choose youtube to not fix anything again!! Lol
crash74 is offline Find More Posts by crash74
Old Nov 20, 2012, 06:48 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
[QUOTE=fishycomics;23315426]
Originally Posted by VideoKing View Post
Details are simple. Do not assume all cables work. Keyword was ANY manufacturer. Do not plug just any manufacturer's cable in to just any camera
For I only shown that there are companies that care in ways to inform you what to and not plug in. Since we are dealing with hong kong company I am sure there are FCC rules and regulations to follow. I again kept to a very simple post
Thanks for making it more than it is we are entitled to opinions
FCC is a AMERICAN organisation to do with radio & telephone.
Hong kong is in CHINA, and has its own - different set of rules.
mike
empeabee is offline Find More Posts by empeabee
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
