Finally got Victapilot's suggested settings loaded. I much happier with the results.
Difficult lighting conditions I realize but is the greenish streak due to the simple fact I'm flying into the sun or should it not be there at all?
Yabba |
Does it have to boot up first, before it can start detecting motion? Stewart |
Joined Apr 2012
BUT Auto-record MUST BE TURNED OFF for motion detection to even work! These two functions cannot both be on at the same time since their actions will conflict with each other. So the GUI tool does this for you automatically, and I think so does the FW, but I can't recall for sure. This is also explained in the GUI tool tips. |
Any ideas? I hate that I'm out $50 and all I have to show for it is two blurry videos.
p.s. I hope you also disconnected the battery and/or put tape over the bare circuit board components while handling with your bare hands. |
I had an imager assembly go wonky, and replaced it with a new one.
Easy to do. Just be sure to mark the old one -before- you remove it from the camera! And mark the battery connector while the camera is open! It can be plugged in wrong, and then all the smoke comes of the camera! |
Des Moines IA
Joined Dec 2005
trivial is needing to do tweaks and and modify the cam to be on par. We fly an average of 3 times a week and with a total of 8 cams on board. We want to be able to record flights an average of about 10 min x 4 or 5 and edit our flights into a 5 min show. I'm not saying the hk has better video and I'm sure the #16 will do better in quality with tweaks but for producing an edited video and posting on youtube that most will not see any dif. For ease of use and knowing that its recording and the ability to record for more than 20 min is a no brainer for us. If we really want quality video shots we send up our GoPros or Bloggies. Also concerning a ubec or esc we fly multiple planes with cams on board so that would be another problem and diffrent locations on the plane. For instance take the Radian we mount 2 to 3 cams on the wing and another usually the #16 on the tail mainly for weight as we did the Paul Natons mod and used the #16 for balance plus being able to have another cam for recording. Would be hard to run wires. plus we use our cams on many other planes so it wouldn't work for us. |
I think this would apply to all these small cams.
Mine had a rattle that I thought was the electric motor in the plane. Then I decided to shake the cam and listen. Yep, it was the camera. I opened it up and whoever fitted the battery forgot to remove the covering on the double sided tape that secures the battery and it was sliding around. Also found that the on/off and record buttons could rattle. That was fixed by putting a small patch of Johnson and Johnsons leukotape over the buttons on the inside of the case. Cam feels and sounds completely different now. |
| Thread Tools | |
| Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) | Tom Frank | Aerial Photography | 9835 | Apr 21, 2013 05:37 PM |
| Discussion Looking to buy #11 HD Key Cam within US | Abolfazl | Aerial Photography | 1 | Feb 14, 2012 01:59 AM |
| Poll Poll For Current and Future #11 HD Key Cam Users | Tom Frank | Aerial Photography | 0 | Sep 25, 2011 11:55 PM |
| Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! | Jaybee | Aerial Photography | 4 | Jun 02, 2011 11:39 AM |
