Joined Mar 2012
[edit] You can try to remove microSD card from camera then power it on. When the yellow led flashes rapidly, quickly insert microSD card. Connect it to computer as removable drive and delete firmware file (FWMICDVR.BIN). [/edit] |
Joined Oct 2012
I was trying to install the configuration helper guide thing located here ->http://www.rcgroups.com/forums/showp...postcount=7038
To begin with, I'm not even sure i clicked the correct version, I chose v0.49 MOV (I have a MAC) and I got the thing in the mail today. I might have wanted to choose v3 Bootloader? Anyway, somewhere during the process, I think when I took the TF card out and it asked me to put it back in very fast at a certain point, I think I messed that part up. I clicked "next" and it said "no camera was found." now all I get is the yellow flashes and it turns off |
Joined Mar 2012
1-Remove microSD card from camera then power it on. 2-When the yellow led flashes rapidly, quickly insert microSD card. 3-Connect camera to computer as removable drive and delete firmware file (FWMICDVR.BIN). And you should be in business. You should also load the v3 bootloader as it eliminates the need for this manual step. |
Joined Oct 2012
Thanks, I think I'm back in business. Did a quick video and it worked ok (I think I just opened the package 20 minutes ago). I'll try the bootloader now, and also, the red light is on continuously, even while
i'm charging right now... that okay? Edit, It's not in camera mode either, I tried to switch between the camera and video and the red light stays. |
Joined Mar 2012
Take a look at Configuration Assistant, Help, Camera Instructions. That willl likely answer all your questions. You should also read the first 5 posts of this thread for useful information. |
If You feed the USB-connection with 4,8 - 5,2 V there should be no danger of overloading because cam-electronic controlls the charge-procedure of the inner battery. George |
United Kingdom, England, Kent
Joined Dec 2010
Then download the GUI and turn off the date stamp. |
![]() Quote:
![]() ![]() (Greetings from the USA, the Heart of Dixie (Tennessee), where it's sunny and headed for a high of 62F)
About Android (possible) App: - because of USB OTG connection (which is not available on all Android devices and many smartphones doesn't have it) the file can be directly edited on the SD card so is not needed any other new USB communication protocol if the TXT (read only) file is already there. We just need to edit it. - because of the scrolling down Android feature, is possible to add all options in one page - the invalid combinations can be greyed out also on Android Quote:
| Thread Tools | |
| Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) | Tom Frank | Aerial Photography | 9835 | Apr 21, 2013 05:37 PM |
| Discussion Looking to buy #11 HD Key Cam within US | Abolfazl | Aerial Photography | 1 | Feb 14, 2012 01:59 AM |
| Poll Poll For Current and Future #11 HD Key Cam Users | Tom Frank | Aerial Photography | 0 | Sep 25, 2011 11:55 PM |
| Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! | Jaybee | Aerial Photography | 4 | Jun 02, 2011 11:39 AM |
