Old Nov 15, 2012, 11:49 AM
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by kenci View Post
Thanks for you comments.
I also tried several cables on several ports on several computers. The same thing, the green led is off. Yesterday i have "charged" it over 10 hours.
I have the old v1, with the same cable the v1 charges without problems, with green led on. I dont know what to do. I have to wait what eletoponline has to say.
Maybe a defect battery? I have a spare battery for the v1. Should i try this on in v2?
The mass storage is working without problems
It could also be a defective charging circuit in the camera. Things you can do in the interim:
1. Try powering the camera with the external car charger cord to see if the camera will record normally.
2. If that works, open the case (see manufacturer's instructions linked in post #10) for tips when doing this. Unplug the battery and check the voltage on the pins (should be nominally 4.2v if the battery is fully charged, but this does NOT guarantee the battery is holding a charge sufficient to power the camera!). Then re-insert the battery plug to be sure it is fully seated.
3. Visually inspect the circuit board where the battery plug is soldered to look for cracked or missing solder joints with the plug.
If those don't show any problems, then your battery is most likely a dud. You should be able to get a warranty replacement if the camera is new.
Tom Frank is offline Find More Posts by Tom Frank
Old Nov 15, 2012, 12:00 PM
Joined Nov 2012
So, i have replaced the battery with the new one. It doesnt charge at all, no green led, but it recorded above the 20 seconds. I think it is the board that doesnt charge the battery.
kenci is offline Find More Posts by kenci
Old Nov 15, 2012, 12:01 PM
Joined Oct 2006
del
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Nov 15, 2012, 02:01 PM
Joined Aug 2012
Gave up with the battery issue, I now power it from the receiver directly and I used it as the live feed out for FPV
It went better than expected
Parkzone Stryker F27-Q FPV First Person View RC Flight (3 min 15 sec)
Dogdude is offline Find More Posts by Dogdude
Old Nov 15, 2012, 02:31 PM
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
Video will not play for me.
Says your video contains Hospital Records and is banned.????
ridgewalker is offline Find More Posts by ridgewalker
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
Try what said Tom in the previous post:
Your camera should work as Tom said, no matter if the battery is bad or some charging circuit is dead. Just use the same cable and source which is working for your V1.
Also you can try to charge the battery from the V2 version into the V1 version camera which is working for you. If the battery is charging, then the problem is the V2 camera Charger IC which is marked as 08BJ (see attached pictures).
If only the battery have problems, the green light must to work.
But I am almost sure the problem is the charger IC which was damaged by some short circuit when using the USB charging.
If the camera Charger IC is damaged it is possible to replace it using a SGM4054 (or equivalent) or SGM4055 (TP4055). See attached pictures.
Even the new charger IC have just 5 pins not 6, it will work, the only thing to care is the pin order.
If you can find this circuit on some local electronic shop, go with your camera to some phone repairing workshop because they have the tools for replacing small components.
enjoy,
Mtz
Mtz is offline Find More Posts by Mtz
Old Nov 15, 2012, 02:33 PM
Joined Nov 2012
Another question :
Can i power the camera from an 3,7v smartphone battery? It's an 2680 mah. What's about overloading, overheating if it's been charged through the camera's USB connector ?
Old Nov 15, 2012, 02:46 PM
Joined Nov 2012
Thanks mtz,
i haven't made a short circuit. For the first time charging it used the cable that comes with the camera. At first connect the green led was also off.
Tom,
i tried recording with external power (USB). No problems at all. I removed the camera's battery and checked the two pins at the board. With USB powered, i measured 0v. There must be power on that two pins, or not? Thus i think it's the ic as mtz said.
Old Nov 15, 2012, 03:05 PM
I like techy stuff
United States, TX, Flower Mound
Joined Jan 2011
external battery
@kenci
Yes, you can power it with an external battery.. I opened up the case and soldered leads to the battery and extended the cable out the back of the unit using a JST connector.. Works great, with run times approaching 8 hours with the right battery/memory combo.. Now I can charge both the camera and external battery with my regular lipo charger.
Paul
Patchitagain is offline Find More Posts by Patchitagain
Old Nov 15, 2012, 03:27 PM
Joined Nov 2012
MTZ, thanks for your technical input. Do you know of a #16 audio injection point that is fixed level, not affected by movie sound levels 1, 2 and 3? Want to record 1200 baud FSK telemetry flight data.
Pitot tube is offline Find More Posts by Pitot tube
Old Nov 15, 2012, 03:31 PM
Mtz
Mtz's Avatar
Joined Mar 2012
My technical knowledge is limited. I can't answer at your question, sorry.
Maybe Isoprop can give you a better answer or another forum user.
Old Nov 15, 2012, 04:10 PM
fastguy's Avatar
Germany
Joined Apr 2012
USB cable for extern power supply
Can anybody tell where I can get the cable shown on the attached picture? Because of shipping costs an european source would be best. Or is it available on ebay?
George
fastguy is offline Find More Posts by fastguy
Old Nov 15, 2012, 04:11 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Tom,
You might be right, but I'm not convinced your voltage measurement with no battery connected is conclusive evidence.
If you read the data sheet mtz linked, the charging IC has a low voltage lockout. It will not try to charge a battery with low voltage on it (this is typical of most all external dedicated lipo chargers). So with no battery connected and no battery voltage detected on those pins, I don't think the charging IC will turn on. This is outside my knowledge area, so I'm just paraphrasing what I think I've read in the data sheet. In situations like this, I reserve the right to be wrong!
If you can check voltage on those pins with a battery connected and then immediately afterwards with the camera plugged in to a USB power source, it might give better indication of what's going on with the charging circuit. The battery alone should have at least 3V on it (but less than 4.2V) for this test.
Old Nov 15, 2012, 04:55 PM
Joined Aug 2012
@fastguy That appears to just be a USB to miniUSB cable, I'm sure you could find one that short by just searching for "miniUSB cable"
astro_wanabe is offline Find More Posts by astro_wanabe
Old Nov 15, 2012, 05:05 PM
Spain.
Joined Jul 2009
Maiden Flight of my new Easystar II with 808 16# v.2 d lens camera.
Estreno EasyStar II Fpv Nosepo (3 min 43 sec)
Nosepo is offline Find More Posts by Nosepo
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9861 Jun 18, 2013 04:14 PM
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 1 Feb 14, 2012 01:59 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
