Old Nov 13, 2012, 06:08 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
me too (except for the 30 years part. lol!). i started with key cams awhile ago but then blinked and they came out with this record/video-out stuff. and thanks signguy for getting me into multicopters with that gyro tricopter thread.
dave1993 is offline Find More Posts by dave1993
Old Nov 13, 2012, 11:56 PM
escort_77 is offline
Find More Posts by escort_77
Joined May 2011
How do I activate the motion detect function? I have the number 16 with original A lense and 049, FW
escort_77 is offline Find More Posts by escort_77
Old Nov 14, 2012, 05:04 AM
Vanhoucke is offline
Find More Posts by Vanhoucke
Joined Nov 2012
Hello guys!
I've been 'leaching' this topic for quite some time. It's impressive to see this dedication and friendlyness.
I'm using the #16 in a project that might just kick off at our University. Briefly, I'm using it as FPV video and audio recording. So I'm attaching the 808 to glasses.
The project combines this and a sensor unit, that senses body feedback. (Galvanic skin response).
It's open hardware, so I'm keeping the price low, and the 808 is just perfect!
Well, then I come the the question I'm having.
Is it possible to turn the lens 90? I've tried with the standard lens, but the 'wire' is too short. Can a longer one be ordered? I've also ordered a 808 #16 v2 (I'm hoping that that lens can be turned, but probably the build is almost identical to the #16's).
Thanks in advance!
TL;DR: can the lens be turned 90?
EDIT: searchfunction, I should use it more often.. It's not possible
Vanhoucke is offline Find More Posts by Vanhoucke
Old Nov 14, 2012, 05:33 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
We have asked tis question a number of times.
[Device
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Nov 14, 2012, 05:34 AM
Joined Oct 2006
del.
Old Nov 14, 2012, 08:13 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Originally Posted by Vanhoucke View Post
Hello guys!
There is pair of sunglasses with an 808 camera mounted in the frame
The ribbon cable from sensor to videoprocessor is too short and fragile to rotate through 90 degrees
Thanks in advance!
The camera video processor can rotate the picture only by 180 degrees, this is not done by firmware written by the developer.
Rotating by 90 degrees in Firmware is not practicable (too computationally intense for the tiny prosessor, and would use up program space that the camera does not have), apart from the minor detail that the resultant rotated picture would be "9" wide by "16" high (the sensor is 16:9 aspect ratio.).
As Fishy said, you can rotate the picture by post processing in a video editor, resulting in the same tall and thin picture....
empeabee is offline Find More Posts by empeabee
Old Nov 14, 2012, 09:40 AM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Rotation Magic
Rotating by 90 degrees in Firmware is not practicable (too computationally intense for the tiny prosessor...,)
To add to what Mike said (for those who crave details):
The 180 deg. rotation is actually done by the controller embedded in the CMOS imager. It has a "rolling shutter" that normally reads the pixel array one horizontal line at a time, starting at the top LEFT corner and reading to the right going DOWN the array. By altering the starting corner point and the horizontal direction of the scan, the image can be flipped, making a mirror image. I.e., starting at the top RIGHT corner and scanning to the left DOWN the array produces a "flipped" HORIZONTAL mirror image. And starting at the bottom LEFT corner and scanning right UP the array produces a flipped VERTICAL mirror image. So by starting at the bottom RIGHT corner and scanning to the left UP the array produces BOTH a horizontally AND vertically mirrored image, which magically is identical to the original image ROTATED 180 deg., all with no additional time needed for the manipulation.
So, the camera actually does not do any (calculated) rotation at all. The rotated image from the CMOS imager is fed to the graphics processor chip which adds the date stamp in the lower left corner (if toggled on), just as if it were an upright image! So now you also know why the time stamp does not appear inverted in the upper right corner when the camera is toggled to capture rotated images (like it would if you rotated the image with an editor with post processing).
Tom Frank is offline Find More Posts by Tom Frank
Old Nov 14, 2012, 10:47 AM
empeabee is offline
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Originally Posted by Tom Frank View Post
To add to what Mike said (for those who crave details): ------.
Thanx Mike
Old Nov 14, 2012, 01:00 PM
Rubis is offline
Find More Posts by Rubis
Rubis's Avatar
France, Aquitaine, Blaye
Joined Jan 2010
Rolling schutter
Hello
a few images of the cmos during the rolling schutter part work
Rubis is offline Find More Posts by Rubis
Old Nov 14, 2012, 01:38 PM
Gomario is offline
Find More Posts by Gomario
Mr.
Gomario's Avatar
South Africa, EC, Humansdorp
Joined Dec 2011
Does anyone know the Gunnar Tahlin deshaker add-on filter, for VirtualDub? What is the rolling shutter setting I must use in order to reduce the effect as much as possible? I have tried to follow the instructions to find out the correct number but I am at a loss :-(
Gomario is offline Find More Posts by Gomario
Old Nov 14, 2012, 01:47 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
That does make for nice images... sometimes unexpected.
I don't get the same thing from my 808s that do from my old Aiptek, the photo option on the 808 is too much of a guess to try to use.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Nov 14, 2012, 03:54 PM
Azuritko is offline
Find More Posts by Azuritko
Azuritko's Avatar
Slovakia
Joined Nov 2011
Isoprop, I tried the TV out as you described using my viewfinder, and it is working. I am really happy with that
Azuritko is offline Find More Posts by Azuritko
Old Nov 14, 2012, 05:32 PM
Patchitagain is offline
Find More Posts by Patchitagain
NE Texas, USA
Joined Jan 2011
Hello,
My 16 with th D lens has some dust/stuff on it.. Is there an approved method of cleaning the lenses? I tried cleaning the lens on my other A cam and ruined it, and don't want to repeat my mistake..
Much appreciated..
Patchitagain is offline Find More Posts by Patchitagain
Old Nov 14, 2012, 06:02 PM
Stale is offline
Find More Posts by Stale
Joined Nov 2012
I’m thinking of buying my first keycam, I’m from the UK I’ve put this off for a long time, but I’m getting to the point where I just want to bite the bullet, I’ve read too much information (followed this thread on and off for the past few months!) hopefully I can do this hassle free I’m going to buy:
808#16 lens D from eletopline360 off ebay
Tecknet iEp300 3000maH battery (They’re similar to the Vaas 5000mAH I’ve seen suggested here.)
16gb micro sd card
I’ve read about the compatibility problems with higher class cards, but I’m still at a loss at which class is the most reliable, I appreciate there's no 'one works for all' answer.
Stale is offline Find More Posts by Stale
Old Nov 14, 2012, 06:56 PM
Joined Oct 2006
[quote=
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 10:56 AM
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 1 Feb 14, 2012 02:59 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 26, 2011 12:55 AM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 12:39 PM
