Old Nov 01, 2012, 01:50 PM
Jerry42 is offline
Find More Posts by Jerry42
Jerry42's Avatar
United States, NC, New Bern
Joined Feb 2012
Aeroparts, Thanks for the link. It was a good view of the mod but not to instructional. I was hoping for something more along the lines of how he did it so others could DIY it.
Jerry
Jerry42 is offline Find More Posts by Jerry42
Old Nov 01, 2012, 01:58 PM
aeroparts is offline
Find More Posts by aeroparts
Sweden
Joined Nov 2004
Aha, I didnt see the problem I think he just use some plexi and put it over the existing LEDs, and with some matt finish on the plexi it will be possible to see the lights from all angle. Thats the way I will do it. I can upload some pict when Im ready
/Lennart
aeroparts is offline Find More Posts by aeroparts
Old Nov 01, 2012, 02:01 PM
pintail1 is offline
Find More Posts by pintail1
pintail1's Avatar
United Kingdom, England, Norfk
Joined Mar 2012
Jerry
Hi jerry try this link http://www.rcgroups.com/forums/showp...postcount=1263 this sould help you.
Pintail.
pintail1 is offline Find More Posts by pintail1
Old Nov 01, 2012, 02:02 PM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Plexiglass will work, a clear rod if possible. Google this for engineering details=>
light pipe design guide
victapilot is online now Find More Posts by victapilot
Old Nov 01, 2012, 02:24 PM
FlyingPanMan is offline
Find More Posts by FlyingPanMan
Joined Oct 2012
To enable me to see the led's easier, I just put a little piece of Scotch 3M tape (matt finish Sellotape that you can write on) over the led hole. It refracts the light slightly making them more visible and also acts as a further seal against wind noise that can reach the mic.
Just had a thought to try out! Take the same tape and roll it up into a small rod. Insert it in the hole and trim off? Dunno if it will work, 'cos the inspiration (?) hit me while typing this.
Let me know if it works... not near my camera at the mo.
FlyingPanMan is offline Find More Posts by FlyingPanMan
Old Nov 01, 2012, 02:30 PM
Jerry42 is offline
Jerry42's Avatar
Joined Feb 2012
Thanks, guys. What would you use to hold the little button in? some CA or something else? Or is it really necessary to glue it in at all? i can't see any reason to ever remove it once it's there.
Thanks again, aeroparts, Pintail1and Victapilot..
This is a great thread and TF and Iso really deserve all the credit they are receiving, great job.
Jerry
Old Nov 01, 2012, 02:35 PM
Joined Oct 2012
Re. my last post and idea... I can't make it work. Tried to roll up the tape and it's impossible to make it small enough.
Anyway, not such a good idea to poke things through there... might knock off some electric components... sorry just a thought!
Old Nov 01, 2012, 03:17 PM
falconerider is offline
Find More Posts by falconerider
Fly by Guzzi
falconerider's Avatar
Germany, NRW, Münster
Joined Jul 2012
I opened the case, enlarged the hole a little bit (~2 mm), and glued a small piece of clear tape over to seal the hole against water, dirt, wind.
No plastic tube, not as elegant as the others, but veeery easy to do, even for me
Falconerider
falconerider is offline Find More Posts by falconerider
Old Nov 01, 2012, 03:23 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
Yep open the case to a djust cleaned out the hole and no need to squint anymore
Led (0 min 10 sec)
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Nov 01, 2012, 04:01 PM
pimjan is offline
Find More Posts by pimjan
Joined Oct 2012
weird
Originally Posted by Rubis View Post
Hello
808#16 this is perfect
I love this Caméra
http://www.youtube.com/watch?v=G7W-Yq6bx9I
My camera is waaaaaaaaaaay less sensitive than yours, you have to jump in frony of the camera a couple of times before it even thinks to start recording and after 5 sec it does
pimjan is offline Find More Posts by pimjan
Old Nov 01, 2012, 04:32 PM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Usb cables
I think I should Clarify my comments about
3 out of 6 recent cables faulty
only 1 faulty cable came with a #16 camera, the other 2 were from other sources.
and one of them was a total disconnect job that came with small electronic device.
The impression I get is faulty 'computer end' plug connections.
empeabee is offline Find More Posts by empeabee
Old Nov 01, 2012, 04:34 PM
victapilot's Avatar
Joined Feb 2009
B Lens
Here's my B lens, not too bad for focus now. Around 3pm, Fluorescent, Saturation +1, Contrast -1, still not great, but at least stable. No editing adjustments.
It's still quite breezy here!
B lens #16 Ace High (2 min 19 sec)
Old Nov 01, 2012, 04:39 PM
pimjan is offline
Joined Oct 2012
source file
Does anyone have a source code of the firmware???
I want to change some setting which i cant do with the gui
Old Nov 01, 2012, 04:52 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Jerry
I did this one.
http://s134.beta.photobucket.com/use...74224425095185
I put the led in a drill and used a file to cut down to the small post. It works great. The base that's inside the camera needs to be real thin so it doesn't push on the board.
Steve
Floater73 is offline Find More Posts by Floater73
Old Nov 01, 2012, 04:58 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
a tiny dab of silcone (elmers stix all) on the hole makes the led visible from all angles. i did this so i could tell when the 808 cheapie on my hat brim ran out of battery or memory.
dave1993 is offline Find More Posts by dave1993
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
