Joined Oct 2006
Emphabee
You are telling the developer it is not good, so when I say To the developer: Dual video & still/time lapse Record video camera snaps shots per choice 3, 5, 10 or 15 seconds Yes we can grab frames of 1280x720 that was what emphe we was saying No pun intended and ontopic |
Reason: explained
Joined Nov 2010
The public usblib won't help you either. Sorry. You'll have to dig a lot, lot deeper and first understand how the USB protocol works. Weeks of reading I'm afraid.... ![]() I can only imagine that someone with profound USB driver knowledge could reverse-engineer the protocol used by the camera. [EDIT] I will take this to PM to avoid cluttering the thread with technical humbug. [/EDIT] [MORE EDIT] dave1993, please clear your PM message box - it is full, so I can't send you my PM. [/MORE EDIT] |
Rubis, great vid on how the cam is supposed to work. (Sometimes a picture is worth alot to some people)
Question: did you modify the led or did it come that way? It's a great help to see the led so easily. If you did a modification could you please share with us how you did it ?. I know someone already shared their mod of this but am always interested in how someone else would do it. Thanks, Jerry |
Joined Oct 2012
Turn lens through 90 degrees?
I know I'm in a minority on this forum because I use my 808#16 V2 D lens in a motorbike helmet. (But I've had a few RC planes and helis in my time).
Anyway, I opened mine up to see if I could turn the CMOS through 90 degrees. I wanted to stick it on the right-hand side of my helmet (I'm a Brit) with the mic hole on the lower side and the buttons facing out. The flat flexible cable to the CMOS is too short to turn 90 degrees so I looked for other people's ideas but nothing ready-made came up. So, anyone have an easy solution? I know I'm probably asking the impossible, but how about a longer cable as a standard fitting? I think there would be room if folded and it would give us tinkerers an extra option? Cheers, Paul. PS. My Motorbike YouTube Videos are under my username of "FlyingPanMan" |
New York
Joined Oct 2008
any info you can provide would be appreciated. mostly not so much general usb driver stuff as specifics to the camera command set. if you like post in any of my diy threads because i check at least every day or so. although i really dont think its too ot here. this thread gotten into technical issues before. and there are a few others that are curious about it too judging from the pms that just came in. its amazing how many surf but are too shy to post. its like 100 to 1. i did delete some messages and made room though if thats the only way. |
Joined Nov 2010
![]() A longer cable wouldn't help much. These cables are extremely fragile and any bends will crack the tiny wires embedded in the ribbon. Of course it would be possible if you would make a whacking large case, but I don't think that's what you want. It's also not possible to flip the video by 90 degrees in firmware or software. Well, yes, it can be done in software, but you'll end up with a narrow and tall video! The CMOS module does not have enough vertical sensors to capture a 90° flipped scene. Your question has been asked a few times in the past, but I'm afraid there just isn't a solution with the existing case. |
Sweden
Joined Nov 2004
http://www.rcgroups.com/forums/showp...postcount=5035 |
| Thread Tools | |
| Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) | Tom Frank | Aerial Photography | 9835 | Apr 21, 2013 05:37 PM |
| Discussion Looking to buy #11 HD Key Cam within US | Abolfazl | Aerial Photography | 1 | Feb 14, 2012 01:59 AM |
| Poll Poll For Current and Future #11 HD Key Cam Users | Tom Frank | Aerial Photography | 0 | Sep 25, 2011 11:55 PM |
| Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! | Jaybee | Aerial Photography | 4 | Jun 02, 2011 11:39 AM |
