Old Oct 31, 2012, 06:20 PM
ridgewalker is offline
Find More Posts by ridgewalker
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
Originally Posted by Luis_Claudio View Post
I did dear friend, but as this thread has more than a year I thought there were more selleres...
But I found:
http://www.ebay.com/itm/Mini-DVR-808...item2a2102bb65
Correct?
You got it!
Great little camera for the money no doubt about it.
You may want to read back through some posts in this thread to see video from the different lenses that are available for this camera before purchasing,see for yourself which lens you like better.
ridgewalker is offline Find More Posts by ridgewalker
Old Oct 31, 2012, 06:28 PM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Originally Posted by fishycomics View Post
Do you see this camera not improving beyond version 2?
Ah polytixs 101, answer a question with a question.....
Ike - Don't kick the baby
empeabee is offline Find More Posts by empeabee
Old Oct 31, 2012, 06:48 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Originally Posted by Azuritko View Post
Are you kidding? $30? You give up so easilly did you? Or you are lazy to try even little?
http://www.ebay.com/itm/MICRO-SD-SDH...item33665cece5
http://www.ebay.com/itm/USB-SIM-Micr...&forceRpt=true
http://www.ebay.com/itm/Blue-USB2-0-...item564e252418
http://www.ebay.com/itm/USB-2-0-Tran...item3cc61846bf
http://www.ebay.com/itm/Yellow-porta...item564e252402
There are tons of readers of this price. And it is relly clever man to not invest $30 as you said (max $5 in reallity) and throw $40 into trash. Super investment. Unbelievable
Welcome to the ignore list and no, I am not lazy.
Lou is offline Find More Posts by Lou
Old Oct 31, 2012, 06:59 PM
Lou is offline
Lou
Lou
Joined Dec 2005
Originally Posted by clarebanner View Post
I have 808#16 for almost a year. No problem so far. I have updated firmware all along except the very latest (motion etc). I don't have a card reader & follow these instructions...after No 1. Downloading the new Firmware . No 2. Copying the File to the camera...
"In-camera "backdoor" method:
Make sure the camera is turned off.
Remove the card from the camera.
Turn on the camera and wait for the yellow LED to blink, indicating it needs a flash card.
Insert the card back into the camera. DO NOT PUSH ANY BUTTONS.
Connect the camera to the PC using a standard USB cable.
When the camera connects as a removable disk, delete the firmware file (FWMICDVR.BIN) from the disk.
Unplug the camera from the USB cable. It is now ready for use. YOU ARE DONE!"
I am afraid that I have already tried the backdoor method a number of times. I assure all that I read all of the recommended posts, several times, downloaded all files, GUI/Instruction and read those instructions. All that was before the unit arrived in the mail.
Now, sometime Win7 sees the device and sometimes not. Maybe it is a faulty unit, battery charged for 4 hours, even though help files say 2.5 hours should be enough. Only thing left to try is to load the bootloader.
I used the GUI for every action. Nothing worked. For the cost of sending back to China, I will hammer the unit and trash it if installing new bootloader does not work. Sometimes it works out this way.
Old Oct 31, 2012, 07:22 PM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Originally Posted by Obake View Post
Now, sometime Win7 sees the device and sometimes not. .
Sure sounds like a bad USB cable. If you have another, you should try it.
The hammer doesn't help. It was tried way back on the #3 thread, and was posted on YouTube
victapilot is offline Find More Posts by victapilot
Old Oct 31, 2012, 07:36 PM
empeabee is offline
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
I agree - 3 out of 6 usb cables received in new kit over the summer were faulty, one made intermittent connection and confused poor olf vista to the point of needing power off & reboot, & not just on #16s either.
Old Oct 31, 2012, 08:01 PM
dan30677 is offline
Find More Posts by dan30677
Joined Apr 2012
Lens B
jwt873 posted "What I did was enlarge the lens opening in the 808 case by removing the camera's circuit board and then enlarging the hole by drilling it with a 5/32 inch drill bit. (That's 3.9 mm in metric). After that I beveled the opening slightly with a countersink bit.. It made a world of difference."
I just wondered if anyone else has tried this and if it worked as well as jwt873's comparison pics show it did.
dan30677 is offline Find More Posts by dan30677
Old Oct 31, 2012, 08:06 PM
victapilot's Avatar
Joined Feb 2009
My case has a 7mm hole that I drilled out for a D lens. So it is even bigger than what jwt873 did. The B lens still has vignetting as you can see here. Also hotspot in center.
Old Oct 31, 2012, 09:26 PM
Lou is offline
Lou
Lou
Joined Dec 2005
@ victapilot und empeabee ..... you two are correct, the included USB cable is not too good. Intermittent connection ability to #16. I monitored unit for roughly one hour, watch unit drop from Win7 on intermittent basis. I have to wonder if one of the power leads is bleeding onto a signal lead?
Anyway, I use known good USB and now unit communicates properly. Able to get FW loaded at last, I will see if LEDs perform accordingly.
thanks
Old Oct 31, 2012, 09:43 PM
therau2000 is offline
Find More Posts by therau2000
Joined Mar 2012
deleted
therau2000 is offline Find More Posts by therau2000
Old Nov 01, 2012, 03:29 AM
welcome99 is offline
Find More Posts by welcome99
Deutschland, HE
Joined May 2010
I made a short video with the #808 V2 on my glider in France/Vosges:
Le Schweissel, Vogesen, rc soaring (1 min 26 sec)
the settings of colour, saturation etc. are not yet optimized...
welcome
welcome99 is offline Find More Posts by welcome99
Old Nov 01, 2012, 03:32 AM
falconerider is offline
Find More Posts by falconerider
Fly by Guzzi
falconerider's Avatar
Germany, NRW, Münster
Joined Jul 2012
That is my experience too: One of three cables is "bricked" and bothered me ("why do I get no stable connection in webcam mode???") with time-to-time blackouts. The other cables are ok, hope it stays so.
To the developer/dealers: Please, please send better cables with this great camera!
Falconerider
falconerider is offline Find More Posts by falconerider
Old Nov 01, 2012, 04:14 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
But I found:
Correct?
Yes, that is correct. eletoponline365 is one of the sellers listed in post #2. Sorry, ridgewalker has already told you that
There have never been more than two official #16 sellers and these are listed in post #2, as you have noticed. There is also an eBay reseller in the US if you live in the US and want faster delivery times. Obviously his prices are higher than if you buy direct from China, but it's certainly more convenient to buy from the US if you live there. Delivery from China can take from 7 days up to a month or even longer in some parts of the world. Normally you can expect delivery within 2-3 weeks.
The two sellers noted in post #2 work closely with the developer. Most probably this is one of the reasons there are no more sellers and assures excellent support and perfect communication in case of difficulty or technical questions.
The thread may be almost a year old, but the first 5 pages are always kept up-to-date as best as possible. Post #2, where the two sellers are listed, was last updated 4 days ago
Isoprop is offline Find More Posts by Isoprop
Old Nov 01, 2012, 04:35 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
I drilled th hole larger, as well. Like Victapilot did I even went the extra step to scrape a tad off the mic hole. A excellent mod when you purchase the Lens B.
I wonder when you make that purchase already in place, will the shadows be present?r
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Nov 01, 2012, 05:08 AM
Joined Oct 2006
To Developer
thoughts out loud; Video recording stills snapping per 3 second, 5 second or 15 second per shot
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
