Old Oct 23, 2012, 06:46 AM
falconerider is offline
Find More Posts by falconerider
Fly by Guzzi
falconerider's Avatar
Germany, NRW, Münster
Joined Jul 2012
Originally Posted by Ulrik_A View Post
I tried the FAQ
http://www.rcgroups.com/forums/showp...postcount=3867
But it did not help, can a Micro SD card become "bricked" ?
I will try and format in the 808
Could be a problem with some Sandisk cards, which switch into read-only mode, and can't be fixed. See post 1706.
Ciao
Falconerider
falconerider is offline Find More Posts by falconerider
Old Oct 23, 2012, 06:57 AM
Ulrik_A is offline
Find More Posts by Ulrik_A
Ulrik_A's Avatar
Sweden, Malmö
Joined Oct 2012
Ciao
Falconerider
Not that, i tried formating it in my Mac, does not work.
Formating with 5 different programs on Win 7, does not work
Nothing works
I belive the card is bricked
If i delete or add anything to the card, then remove it from computer, and put it back again, its the same it was before....GRRR
I belive its bricked
Iv emailed the ebay seller ,and i guess i have to wait and see if they refund me
Any other ides how to make it work again ?
Ulrik_A is offline Find More Posts by Ulrik_A
Old Oct 23, 2012, 07:20 AM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
Tom you said that developer is watching this thread.
I dream about one feature, that would make 808 camera even better.
It's very simple but it would probably require some hardware switch ?
1. +5V connected -> camera turns itself ON + autorecord ON
2. +5V disconnected -> camera end recording seamlessly and turn it's self OFF.
Two main reasons why i would want such a features:
- KISS when flying FPV, auto record is a great feature but with auto power it would be even better.
- Camera would be then 100% complete as recorder for cars and motorbikes.
There is quite a big hype about 808 #16 D videos quality in forums that dispute about car AV records.
On one of the national forums i already saw hardware mods to achieve +5V power on, i will try to dig again for pics.
It's probably not possible on current hardware, maybe consider such feature in 808 #16 V3 ?
shafter is offline Find More Posts by shafter
Old Oct 23, 2012, 07:54 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
Lets hope tha ad card was just a fluke and as we'll hearing a gopro3 and issues at hand.
What was the time you got. On the 32 gb? With recording
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Oct 23, 2012, 08:01 AM
airmob is offline
Find More Posts by airmob
not running for the exercise
airmob's Avatar
Joined Jan 2011
Nothing works
What brand, capacity, and class, is your card?
Are you saying you've asked for a refund from the ebay seller of the card?
airmob is offline Find More Posts by airmob
Old Oct 23, 2012, 08:33 AM
Mtz is offline
Mtz
Find More Posts by Mtz
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
...Nothing works...
I believe the card is bricked
Try to not record in the future if your external charger will cut the power or until it will become empty. When recording, if enough mAh the camera will use the power from the external source, but when that source is no more available the camera will record from the battery and when the battery will become empty is possible to brick the card.
I bricked few cards when using in the car, the car computer cut the power from the charger (after about 30 minutes), the camera still records until the battery become empty and then the problem appear.
I think when using only the battery with no external power, when the battery will go empty there will be no problems with the card and recordings, but only when using external 5V power.
Try to format your card with some Android phone. If the card will work on that device and no other devices, just use it in the Android device and buy another for the 808 if you can't replace it.
V1 and V2 need some electronic component from the factory to work as you want. Is not possible only with firmware or some wires inside the camera.
On this thread is a mod made by a polish user called wszim which made the hack using some attiny45.
enjoy,
Mtz
Mtz is offline Find More Posts by Mtz
Old Oct 23, 2012, 08:35 AM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by FLAME747 View Post
My #16 cam in 2 weeks ago, still have not had time to test it
How do you set the time on this one?
FCA
Start by reading the first few posts here. They are full of FAQs with links to solutions and a whole lot more. Get the GUI utility to set ALL the many parameters, not just the date/time, all at the click of a mouse button.
Tom Frank is offline Find More Posts by Tom Frank
Old Oct 23, 2012, 10:49 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
Nothing works
Yes, like Mtz has posted, you have a bricked card. Is it by any means a Sandisk? These cards are known to have a problem, also with other devices, and will be replaced free of charge by Sandisk.
I have bricked 5 cards already. I believe it only happens when you use external power supply and the power is "cut" unexpectedly. Is this how you used your camera?
If you search the thread for "write protect" you will find quite a few posts. Someone reportedly had success with the linux tool GParted. I didn't.
Isoprop is offline Find More Posts by Isoprop
Old Oct 23, 2012, 11:56 AM
Ulrik_A is offline
Ulrik_A's Avatar
Sweden, Malmö
Joined Oct 2012
Dont have a Android phone or deivce, only have Iphone and Ipad and such.
Might be able to borrow one and try and format it.
I belive its bricked, everytime i try and remove the items, and remove the card after that, and put in the disk again, they appear again.
Remove partition, and after a few seconds, the memory card have its files back again.
Nothing works at all, and i have tried it all (beside android format)
Its a OEM 16gb class 10 card, from ebay
So to sum it up
The external power i bought, i cannot charge both the external battery and my 808 full.
Then use them together, till they run out of power , then it will brick my card ?
W.T.F, then why did i buy the external power ?
That sucks...wish somone would told me this before
Old Oct 23, 2012, 12:10 PM
Isoprop is offline
Joined Nov 2010
So to sum it up
You must not let the external power run out. I use a Just Mobile GumPro and the camera will record more than 10 hours. So it will fill my 32GB card and then the camera will turn off.
You must always guarantee that USB power is 5V +-5%. That is the specification! I know it's not perfect, but the cards have a problem, not the camera
Old Oct 23, 2012, 12:50 PM
Ulrik_A is offline
Ulrik_A's Avatar
Sweden, Malmö
Joined Oct 2012
You say the cards have a problem, so if i get a another card, can the power on both the 808 and the external power supply run out and wont brick the unit ?
Old Oct 23, 2012, 01:30 PM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
More color comparisons
Compare with those posted here. same conditions, sunny, blue sky, 11am
victapilot is online now Find More Posts by victapilot
Old Oct 23, 2012, 02:06 PM
Fly by Guzzi
Joined Jul 2012
I ran power out on the power pack and the cam, to test how long it records. See my post #9892, point 1. I let it run till batteries were empty. No problem with a bricked card. I used a Samsung class 10, 8 GB card, and a Medion (from Germany) class 4, 8 GB.
I don't know why your card is bricked. Try it with some other "non-OEM" card, maybe you have a hidden Sandisk
Ciao
Falconerider
Old Oct 23, 2012, 02:20 PM
Ulrik_A is offline
Ulrik_A's Avatar
Sweden, Malmö
Joined Oct 2012
Ciao
Falconerider
What power pack do you have ?
You also have this one ?
http://www.ebay.com/itm/External-Pow...item256af1009a
Im going to try with my Samsung 16 gb class6 card now.
Full charged 808 and full charged external battery.
See if it also bricks my samsung card....
Edit:
Do not buy from
pc_galaxy
This is the card that got bricked
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEAFB:IT
And they dont respond to emails
Old Oct 23, 2012, 03:05 PM
wszim is offline
Find More Posts by wszim
Polska, małopolskie, Nowy Sącz
Joined Dec 2011
enjoy,
Mtz
I noticed that version 0.49 has changed the system by turning the camera PowerOn button. In all previous versions of enough 1 second hold PON. In version 0.49 we need the longer hold key. From my testing shows me that more than 2s but less than 4 seconds. Above 4s immediately start photo mode. The reasons for these changes are not properly on version 0.49 running my mod.
auto on/off recording
So I did attiny45 adaptation program that will allow proper operation of version 0.49 and I updated my hack in 808AutoPonRec_DocOut_23102012.zip.
wszim is offline Find More Posts by wszim
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
