Old Oct 15, 2012, 01:39 PM
ezeeetm is offline
Find More Posts by ezeeetm
Joined Oct 2012
what are the practical differences between 7Mbps video data rate and 10Mbps video data rate? I'm guessing 10 is higher quality/bigger file size, and 7 is lower qual/smaller file size?
I'm using a Kingston Class 4 SDHC 32GB card now.
ezeeetm is offline Find More Posts by ezeeetm
Old Oct 15, 2012, 01:51 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Good guess, in theory. It doesn't necessarily produce these results, however. See post #3 FAQ on the data rates for the long explanation.
Tom Frank is offline Find More Posts by Tom Frank
Old Oct 15, 2012, 02:03 PM
ezeeetm is offline
Joined Oct 2012
Originally Posted by Tom Frank View Post
Good guess, in theory. It does necessarily produce these results, however. See post #3 FAQ on the data rates for the long explanation.
does setting sound volume to zero remove the audio track and thereby improve file size?
Old Oct 15, 2012, 02:04 PM
Ulrik_A is offline
Find More Posts by Ulrik_A
Ulrik_A's Avatar
Sweden, Malmö
Joined Oct 2012
Here's another similar possibility for something that can be adapted to protect the D lens (pic attached). This is just a "standard" (here in the U.S.) rubber grommet for holes in sheet metal to keep wire that passes through from being cut by the metal edges. I bought it at the local hardware store (ACE hardware, a large nationwide chain here)
The size PERFECTLY fit my D lens O.D. It slips on with just a tiny bit of friction... not enough to put stress on the lens, but enough to hold it in place. Also when it's seated against the camera case, it provides some lateral support for the lens barrel, which on mine was just loose in the case. I put a couple dabs of silicone adhesive between the CMOS module and case on the inside as well to keep the lens centered on the case hole, and will probably do the same on the outside between the grommet and case (silicone adhesive can easily be sliced with a hobby knife if needed for access).
Also, the thickness of the grommet extends just slightly in front of the front lens element, which proturdes slightly in front of the lens ring, making it possible to scratch the lens easily. I still need to add something to cover the lens front now, and will come up with something that slips easily in the groove in the grommet, so I'll leave the grommet in place all the time, and just slide the cover on/off when I'm shooting.
Will go to my local hardware store tomorrow and see if they have something similar
Thanks for the info
Just ordered my second 808 #16 v2 Lens D
Ulrik_A is offline Find More Posts by Ulrik_A
Old Oct 15, 2012, 02:24 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Not really, you still get an audio track, just no volume. Realistically, the audio track is a fairly small percentage of the recorded file anyway (usually in the 4%-7% range). So for the nominal data rate of this camera's recordings (52MB/min.), about 2.8 MB/min. is the sound track.
Last edited by Tom Frank; Oct 15, 2012 at 04:43 PM. Reason: spelling and clarification
Old Oct 15, 2012, 03:52 PM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
A few more D lens tests, happy with the color (Fluorescent, Saturation+1, Contrast -1). Not so happy with ghosting in corners when objects just outside the frame. I'll probably crop it in edit.
victapilot is offline Find More Posts by victapilot
Old Oct 15, 2012, 04:32 PM
Mtz is offline
Mtz
Find More Posts by Mtz
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
Lens D cap from headphones covers.
Mtz is offline Find More Posts by Mtz
Old Oct 15, 2012, 04:38 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I like it! Are those covers available somewhere WITHOUT the headphones?
Old Oct 15, 2012, 04:42 PM
Mtz is offline
Mtz
Mtz
Mtz's Avatar
Joined Mar 2012
I am sure a search on ebay with "headphone covers" will bring a lot of offers.
But first is better to search in the house maybe you have somewhere a pair unused. So you can see how it fit.
Before you buy you must choose the Earphone Ear Pad Foam Cover with the smallest hole.
Old Oct 15, 2012, 04:45 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
That tree ghost image is strange. Is it possible the tree was casting a shadow on the camera lens causing the ghosting? I could not tell the sun angle from the picture. I can't imagine what else might cause it.
Old Oct 15, 2012, 05:28 PM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
MTZ beats me to it, credits to you MTZ.
Lens D protector, fourth post of today, about what I said I was going to get out, and see what we all can dig up, Mtz was on the money, and I clearly said, video soon to come. Here in my video. Crash74, thank you for seeing the enjoyable side in me? and I thank you.
Video has my response and clearification to the lens protector. Use not adhesives that are liquid base, use rubber cement or an Elmers stick, for the micro cloth mentioned for protection of lens.
Keycam 808 lens D Protecter review (6 min 22 sec)
I will top this video trust me.
Ear buds available online ebay sellers of hong kong click me
Something we have called elestic or plastic electrical tape. makes a great temprary lens cap, till one is found.
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Oct 15, 2012, 06:16 PM
Mtz is offline
Mtz
Mtz
Mtz's Avatar
Joined Mar 2012
Fisy you made me remember my first version of Hat-Cam, until 808:
- the first version was for the vertical camera
- the second version was for the 808.
The main goal is to keep my black cap nice and usable when not using the camera. So for the first version was rotated 90 degrees.
Now I can use my baseball cap as usual when no camera, and the same way when using the 808 camera.
Most people can't see I have a camera there and is best with the A lens.
enjoy,
Mtz
Old Oct 15, 2012, 06:53 PM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Fishy that's the funniest thing I've seen for a long time. Thanks for the joy
Aviefly is offline Find More Posts by Aviefly
Old Oct 15, 2012, 06:58 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
I may have missed it somewhere but is anyone doing any mods for 5.5v BEC's? All of my ESC's put out 5.5v rather than 5v... Will this be a problem? Im guessing 5.2 is max?
chanyote66 is offline Find More Posts by chanyote66
Old Oct 15, 2012, 07:21 PM
skitchen8 is offline
Find More Posts by skitchen8
Addict.
United States, NY, Binghamton
Joined Jul 2010
I don't think it will be a problem but 5v LDO voltage regulators are very easy to find, cheap, and light weight.
http://www.solarbotics.com/product/17130/
Just a quick Google search, can probably find more on digikey or mouser.
skitchen8 is offline Find More Posts by skitchen8
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
