It worked fine for me. Does it have "V0.49 MOV Local" in the white box to the left of the check firmware button? if it does you have already downloaded it and just need to click on it, the check button will change to an install button, click on that and follow the instructions.
Joined Nov 2010
Could it be that your antivirus/firewall is blocking program access to the rc groups? The firmware is downloaded from Tom's thread, the software is downloaded from the #16 site. I don't quite see how one works but not the other, but one never knows... I also think you are using XP. I tested on XP SP3 but don't know about older versions. |
Sweden, Piteå
Joined Jan 2012
Ok, so I bought a #16 v2 D Lens 808 keychain camera and got it.
But when I start it I get a yellow light that stays on, and when I press the shutter button to record nothing happens, and it's a brand new sandisk memorycard in it. I even tried with another older memorycard and I get the same problem. The camera wont even mount as removable disk on the computer either, can I fix it? |
Made the back door delivery of v 49 fw and was successful.
But the value of my settings is different than with the previous fw. These were the settings before installing the v 49 fw...... http://www.rcgroups.com/forums/attac...mentid=5215079 And the current settings after loading the v 49 fw can be seen in the screen shot at the bottom of this post. No big deal just pointing it out/giving feedback ,...it's not like changing the settings is difficult with the GUI
Contrast & vignetting B lens
This is with Fluorescent, Saturation [3] as I had before, then adding low contrast [0].
Seems to me vignetting a little less visible, but a side effect is the fence is bluish. The dynamic range (detail in shadows) is better so I will split the difference and go with contrast [1] |
Joined Nov 2010
The RTC (Real Time Clock) keeps running, so the date and time will remain correct. |
| Thread Tools | |
| Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) | Tom Frank | Aerial Photography | 9835 | Apr 21, 2013 05:37 PM |
| Discussion Looking to buy #11 HD Key Cam within US | Abolfazl | Aerial Photography | 1 | Feb 14, 2012 01:59 AM |
| Poll Poll For Current and Future #11 HD Key Cam Users | Tom Frank | Aerial Photography | 0 | Sep 25, 2011 11:55 PM |
| Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! | Jaybee | Aerial Photography | 4 | Jun 02, 2011 11:39 AM |
