Old Oct 10, 2012, 08:10 AM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Great tests falconerider !
Thanks again Isoprop for the tip on the US lens supplier. I got a "B" lens and that fixed my broken cam. The image is cleaner and better focused than the orginal lens was before I broke it trying to re-focus it.
Bill Bergman is offline Find More Posts by Bill Bergman
Old Oct 10, 2012, 08:32 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Originally Posted by fishycomics View Post
Naka
Welcome aboard to the 808 keycam site. First thing I say to any new forum member.
As reading Post 1-5 you will find your answer to your questions, if not do a search with key words for the issue at hand it may lead you to some of the posts, that have simular issues.
a) battery.
b) micro cards
battery,
you need to determine if its the battery and you can check voltage, disconnect ,run external power ( usb battery pack) sources. if all works well it is the battery losing charge
micro card
clear all off info in card, no firmware files correct format... swap cards. if all works well it is the card
First thing will be to make sure the card is clean,files firmware all off, then work on the battery, if not the card and if the bat, for some currancy you can order a new battery. and that may clear up your issue if, IF the battery has reached its time?
If the cam is left in the card reader, with the red light on, could it possiably be draining the battery itself, and the camera is not charging? so make sure it's charged , green light?
I found myself in a simular situation, and things worked out by trouble shooting the situation at hand card, battery charge.
Remember cold wx affects run time of camera , again welcome aboard and hope you find your answer.
Ah fishy, you have changed your ways.
But you forgot to point him to your own thread where you have full editorial control.
Mijk
empeabee is offline Find More Posts by empeabee
Old Oct 10, 2012, 08:58 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
Originally Posted by falconerider View Post
The last one.. Filename show what's what. Settings not named are default.
This is strange: I see only small differences in contrast, but big differences in colour warmness/coolness.
Like victapilot, Bill Bergman and others have posted, these are excellent examples and exactly what the developer is looking for. I'm sure he's most grateful and I'm sure we'll all profit from your hard work in a future firmware version.
Isoprop is offline Find More Posts by Isoprop
Old Oct 10, 2012, 10:39 AM
Ulrik_A is offline
Find More Posts by Ulrik_A
Ulrik_A's Avatar
Sweden, Malmö
Joined Oct 2012
Hi,
Im new here, from Sweden and i just got my camera 808 #16 v2 Lens D today.
View in Youtube site and choose better Quality
iPhone 4s - 1080p (pick 1080p in quality)
Iphone 4s 1080 Västra Hamnen Malmö (1 min 22 sec)
808 #16 v2 Lens D - Clip 01 - 720p (pick 720p in quality)
808 #16 v2 Lens D - Västra Hamnen Malmö (1 min 21 sec)
808 #16 v2 Lens D - Clip 02 - 720p (pick 720p in quality)
808 #16 v2 Lens D - Malmö Västra Hamnen - 02 (0 min 43 sec)
Does my 808 #16 v2 Lens D quality look ok ?
Im running these settings
Anything i should change to get some better quality ?
Date time=[2012/10/10-17:09:51];date time setting,format yyyy/mm/dd hh:mm:ss,
Movie resolution=[0];Movie resolution setting,0:720p 30fps,1:wvga 30fps,2:vga 30fps,
Movie cycle time=[2];movie cycle time,0:5 minutes,1:20 minutes,2:40 minutes,3: 70 minutes,
movie Loop Recording=[0];set loop recording on or off,0ff,1n,
Movie stamp=[1];set date / time stamp on or off,0ff,1n,
Movie sound=[3];set movie sound,0:mute,1:level 1,2:level 2,3:level 3,
LED=[0];set LED flicker when recording,0ff,1n,
Movie quality=[0];set movie quality,set movie data rate,0:10 Mbps,1:7 Mbps,
Power off=[1];set system auto power off time when system pending,0ff,1:30 seconds,2:1 minutes,3:2 minutes,
Movie Flip=[0];set movie rotate,0ff,1n,
TV out=[0];set Tv out,0ff,1n,
Capture Size=[1];set photo size,0:1280x960,1:1280x720,
Auto Record=[0];set movie auto record,0ff,1n,
Exposure Value=[2];Exposure compensation,0:-2EV,1:-1EV,2:0EV,3:+1EV,4:+2EV
White Balance=[0];Set White Balance,0:Auto,1aylight,2:Cloudy,3:Tungsten,4:Fl uorescent,
Contrast=[2];Set Contrast,0:-2,1:-1,2:Normal,3:+1,4:+2,
Color Effect=[6];Set Color Effect,0:Standard,1:Mono,2:Sepia,3:Cooler,4:Cool,5 :Warm,6:Warmer,
Saturation=[2];Set Image Staturation,0:-2,1:-1,2:Normal,3:+1,4:+2,
{MicroDVR mov 2012/09/11 v0.41}
Im using a Class 10 - 16gb - Micro SDHC
Thanks alot guys, great site
Ulrik_A is offline Find More Posts by Ulrik_A
Old Oct 10, 2012, 12:03 PM
Mtz is offline
Mtz
Find More Posts by Mtz
Mtz
Mtz's Avatar
Romania, PH, Ploiesti
Joined Mar 2012
Battery connector plug name
Can somebody tell me the name of the battery connector plug ?
I want to buy few pairs of connectors like that.
Some links will be appreciated. Thanks!
Mtz is offline Find More Posts by Mtz
Old Oct 10, 2012, 12:07 PM
hakank is offline
Find More Posts by hakank
Sweden (Åkersberga)
Joined Nov 2004
Looks very much like: http://www.ebay.com/itm/JR-Spektrum-...item256a0bb304
/Håkan
hakank is offline Find More Posts by hakank
Old Oct 10, 2012, 12:08 PM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
Originally Posted by Ulrik_A View Post
Hi,
Try this:
White Balance=[4];Set White Balance,0:Auto,1aylight,2:Cloudy,3:Tungsten,4:Fl uorescent,
Saturation=[3];Set Image Staturation,0:-2,1:-1,2:Normal,3:+1,4:+2,
shafter is offline Find More Posts by shafter
Old Oct 10, 2012, 12:17 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
links in the FAQs... post#3
Tom Frank is online now Find More Posts by Tom Frank
Old Oct 10, 2012, 12:23 PM
Isoprop is offline
Joined Nov 2010
Originally Posted by hakank View Post
Most probably, but much, much too expensive.
Do an eBay search for "Micro 1.25 2-Pin Connector" and you should get a few hits.
But remember - YOU MUST INVERT THE WIRES! Very easy to do with a tiny jeweler's screwdriver.
I'll repeat - the wires must be inverted or you'll destroy your camera - remember this - switch them all as soon as you receive them!
Old Oct 10, 2012, 01:08 PM
Mtz is offline
Mtz
Mtz
Mtz's Avatar
Joined Mar 2012
OK, thanks, I got it.
Another name is ”Mini Plug Extention for Micro Battery”. With this name I found the connector plugs in my country. At about $1/cable., but this is another story.
Old Oct 10, 2012, 01:17 PM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Thanks to you and Tom also Isoprop!
Had some clear sky at last, and I can confirm no fading to gray with the Fluorescent setting. That was already posted by Tom, but I want to check with the sun in my back, which is how I like to fly RC I can show video of auto 0.36 and this, but believe me it's now much more stable for white balance.
This is a frame grab, B lens, Fluorescent [4] and saturation [3], all others at default.
The lens B does have vignetting and center hotspot - burns the center highlights, see the fence. I like the lens D better, but this will do for now. Thanks!
I'll fly, maybe tomorrow, to check the green stability.
victapilot is online now Find More Posts by victapilot
Last edited by victapilot; Oct 10, 2012 at 03:36 PM. Reason: Added Bloggie for comparison
Old Oct 10, 2012, 01:21 PM
shafter is offline
Joined Jan 2012
It's not fully true.
I'm using cable similar to this one from ebay and it's wired correctly for our cameras ->
Negative on the left
Positive + on the right.
http://www.ebay.com/itm/Micro-Mini-J...item232320478c
Anyhow -> double check your setup before connecting power !
Old Oct 10, 2012, 04:16 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Your last sentence is the main point... test the polarity on any new plug wires... don't rely on wire colors or anything else!
Old Oct 10, 2012, 04:19 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I much prefer the Lens A over the lens B for the reason you gave... hot spot and vignetting exposure and color shift. There is really only about 7-8 deg. FOV difference between the two, not nearly enough difference to put up with the downside to me. But that's just me! YMMV.
Old Oct 11, 2012, 03:31 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
Hi,
Better quality also come with editing, and touching up colors. setting up certain settings will defeat, and take away definition. Ther are some excellent vids out there that demostrate about making a better video?
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
