Old Sep 03, 2012, 08:08 PM
Wid is offline
Wid
Find More Posts by Wid
Wid
Live Your Dreams
Wid's Avatar
United States, CA, Redwood Valley
Joined May 2001
Red tail hawk
Originally Posted by Tom Frank View Post
I"]http://www.youtube.com/watch?v=ZTnY97Gi7qI&feature=channel&list=UL
I[/URL] agree... nice clips, especially withg the bird warning screeches also picked up in the recording (I think?)[/QUOTE]
Thanks. I thought the whistling was wind noise as I was going fast and making hard maneuvers to avoid confrontation, but several others mentioned they thought they were bird cries. It was an exciting few moments as we flew fast and furious. Glad he decided I was no threat, no good to eat or mate! After checking me out he went back to his ridge, leaving me to fly in peace.
Wid is offline Find More Posts by Wid
Old Sep 03, 2012, 10:51 PM
nerys is offline
Find More Posts by nerys
Grrr :-)
nerys's Avatar
Levittown PA 19057
Joined Aug 2006
goto the dollar store. get a cheap picture frame with glass in it.
when you get home set some newspaper on the table remove the glass and "drop" it on the newspaper on the hard table. when it shatters fine the right sized piece and hot glue into place.
done.
nerys is offline Find More Posts by nerys
Old Sep 03, 2012, 10:52 PM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
I am so LOVING this D lens.
Piseco Lake Arietta NY "The Chase" and Piseco Sandbar (5 min 32 sec)
I dunked the camera totally, dried it out, and other than I have to reset the date and LED, after drying it out, works GREAT.
Piseco Lake NY, North Shore Run. Irondequoit (5 min 22 sec)
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Sep 04, 2012, 01:41 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
Originally Posted by Merten View Post
Hi, my #16 records fine using a SanDisk 8 GB Class-2-Card. Using a 16GB Samsung Class-6-Card, the recording stopps after 20 seconds. I tried formating the 16GB with the recommended SDFormater, with the #16 itself and with the Windows. No success with any of these. I'd be very lucky about a solution...
You should use the in-camera formatter (see the manual), but it won't help.
Your Sandisk class 2 card is the very best for this camera!
If you want to be on the safe side steer well clear of class 6 cards and above. Some work, some don't, some work sometimes but not always.
Sandisk class 2 or other brands Class 4 (except Sandisk, which may "flip" to write protected) are your best bet. I don't advise Sandisk above class 2.
I have had 5 of these cards fail on me already - class 4 and the latest HC I. All the recent Sandisk, including the 64GB versions, have the "Write-protect" design bug.
Your Samsung class 6 is listed in the list of problematic cards here.
Isoprop is offline Find More Posts by Isoprop
Old Sep 04, 2012, 01:53 AM
Isoprop is offline
Joined Nov 2010
Originally Posted by ApexAero View Post
How important is it to use the perscribed charg cord? can I use a phone charger on a #16?
Most standard 2-wire generic USB chargers are fine. However, beware of special chargers that use 4 wires, and don't under any circumstances use 5-wire chargers. I use Motorola V6 phone chargers all the time. Small, convenient and work. They can be picked up very cheaply on eBay. Don't buy chargers for newer phone models which have the micro-usb plug. You need the mini-USB plug.
Old Sep 04, 2012, 05:12 AM
Dogdude is offline
Find More Posts by Dogdude
Joined Aug 2012
Very impressed with it's low light performance compared to my HoryzonHD and GoPro
It was very dull as I was almost standing in the clouds
Bananahobby Super Skysurfer with #16 v2 and Horyzon HD cameras (3 min 20 sec)
Dogdude is offline Find More Posts by Dogdude
Old Sep 04, 2012, 06:11 AM
micros is offline
Find More Posts by micros
Joined Mar 2012
Better yet just go to a medical supplies store and get a pack of microscope slides. Optically perfect glass, very thin and cheap
micros is offline Find More Posts by micros
Old Sep 04, 2012, 06:20 AM
micros is offline
Joined Mar 2012
It occurs to me that if your camera gets wet the best way to dry it out would probably be the same as people do with mobile phones that get drenched - put it in a bag of (uncooked) rice. The rice draws all the water out of the electronics quite thoroughly, and quickly too.
Old Sep 04, 2012, 07:31 AM
nerys is offline
Grrr :-)
nerys's Avatar
Levittown PA 19057
Joined Aug 2006
The problem with slides is they are very tiny and extremely delicate.
they might not be large enough to convert the fov of the d lens
Old Sep 04, 2012, 07:38 AM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
You can get microscope cover slips on eBay, or use a cheap uv filter (helps reduce haze)
Instead of rice, might use silica gel, get from craft stores, used for drying flowers.
Best to protect the cam (and the plane electronics) to begin with. I tried Tom's Saran wrap on my cellphone, seems good if you can figure a way to mount on the plane.
victapilot is offline Find More Posts by victapilot
Old Sep 04, 2012, 08:29 AM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
I usually just use a wrap of tape around the camera and model, with camera cradled in and wrapped tightly to a thin bed of spongy foam. Or this commercially sold mount with optional rain/splash protection cover is an option (though a bit pricey compared to the cost of the camera.)
Tom Frank is offline Find More Posts by Tom Frank
Old Sep 04, 2012, 10:08 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Even the replacement battery I just installed depletes and shuts down after 22 minutes of recording. Oh well. Time to order another battery.
Prof100 is offline Find More Posts by Prof100
Old Sep 04, 2012, 10:09 AM
Bigmic is offline
Find More Posts by Bigmic
Bigmic's Avatar
Norway, Sogn og Fjordane, Askvoll
Joined Aug 2012
http://www.youtube.com/watch?v=1zWPqJdQ5Eo
http://www.youtube.com/watch?v=R_Enqnct1iU
What kind Plane have you flown - looks very stable - a big one? Nice Vid!
Bigmic is offline Find More Posts by Bigmic
Old Sep 04, 2012, 10:19 AM
mybad is offline
Find More Posts by mybad
Sure, I can fly after sunset!?
United States, MI, Novi
Joined Jan 2011
If you have a D lens, you could do like me.
http://www.rcgroups.com/forums/showp...postcount=7903
No need for glass, no fogging, floats high in the water and easy to see.
I tried this with a zip-lock bag (not sure of the brand), but it blurred the picture. What kind of bag did you use.
mybad is offline Find More Posts by mybad
Old Sep 04, 2012, 10:23 AM
victapilot's Avatar
Joined Feb 2009
I cut the corner of the bag and passed the lens through. The bag is a servo horn bag. Then wrapped it tight with a rubber band.
That's for D lens, which I sealed into the housing with silicone sealant.
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
