Old Aug 24, 2012, 11:33 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
then you need to see if a 1/2, or 1/3 cmos , is the better/worse......
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Aug 24, 2012, 12:14 PM
alculo is offline
Find More Posts by alculo
Joined Aug 2012
Originally Posted by jackerbes View Post
My experience is that what you call "jello" is caused by vibration. It will come and go as various harmonic vibrations are encountered. Generally, having a layer of softer material between the camera and the airframe will dampen the vibrations out.
But somtimes anything that works well for dampening out vibration at one airspeed/motor RPM combo can find another combination of RPM and airspeed that might not work as well. It is the harmonics thing of course.
Jac
It is vibration between each "wipe" of the shutter which causes an image to distort. The slowest shutter speed produces the most distortion because the image changes so much from one wipe to the next one.
alculo is offline Find More Posts by alculo
Old Aug 24, 2012, 12:38 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
It is the shutter speed that creates the jello as the imager moves due to vibration.
For these 808 cameras, the shutter speed is quite high, so the jello is different in each frame.
For the first of these tiny cameras, the Aiptek PenCam, the shutter speed was slow enough for the jello to create the waves in each image.
Made for some amusing/interesting photos.
As the image is scanned from top to bottom in separate lines, motion can be depicted somewhat bizarrely.
I haven't gotten anything this extreme from an 808, except when shooting through a propellor.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Aug 24, 2012, 12:59 PM
nerys is offline
Find More Posts by nerys
Grrr :-)
nerys's Avatar
Levittown PA 19057
Joined Aug 2006
2 kinds of distortion we are seeing.
you have BLUR from low shutter speed under low light. this has little or nothing to do with jello and scan rate. although at lower shutter speeds IF scan rate relative motion problems exist they will be made worse.
Second you have what is called a "rolling shutter" effect.
go find a flat bed SCANNER
place your hand on it and hit SCAN.
now MOVE your hand WHILE its scanning.
THAT is rolling shutter in giant slowed down form essentially.
CCD "pops" a picture of each sensor point all at once.
CMOS literally downloads sensor data in lines top to bottom (or whatever) in near "real time" so its possible for the last line to be at a different "time" than the first line.
so its less a SNAP and more of a SCAN
so get rid of jello you must either speed up the scan or slow down the motion that is occurring faster than the scan.
even really expensive CMOS sensors exhibit this problem. you should see how stretched some fins on rockets I shoot get when I use my F1 (casio 1200fps high speed camera) to shoot them if I don't "sync" my motion relative to model motion close enough :-)
but thats because the models I am shooting move crazy fast (0-200mph in .5 seconds etc..)
nerys is offline Find More Posts by nerys
Old Aug 24, 2012, 01:34 PM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
After a crash with the 808 #16 wide angle lens, I have a broken MOV file.
How can I fix it ?
Sharon
sharonx is offline Find More Posts by sharonx
Old Aug 24, 2012, 01:46 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
How can I fix it ?
Sharon
This is answered in the FAQs in post #3.
Tom Frank is online now Find More Posts by Tom Frank
Old Aug 24, 2012, 03:55 PM
notro is offline
Find More Posts by notro
Joined Aug 2012
won't turn on
I have charged my battery (green light on while plugged into USB), but it will not turn on no matter what button configuration I do.
If I press the power button with no card in, nothing happens (no LED light).
I thought it might have been a firmware issue so I formatted the flash card.
I am at a complete loss as to what to try to do now.
I have used it before and it worked fine. Now all of a sudden it won't turn on at all.
Any help?
EDIT (FOUND THESE INSTRUCTIONS):
Firmware
- Put your card in an external card reader and format your card.
- Now copy the firmware file to your empty card.
- Disconnect the card reader from the PC.
- Remove the card from the card reader.
- Put the card in your camera.
- Very briefly (max 500 ms / half a second) press the power button. The yellow LED should start flashing.
- WAIT AT LEAST 10 seconds until you see the red LED blink very quickly.
- Remove the card from your camera.
- Your camera should now work correctly
I press the power button and no lights flash...........
notro is offline Find More Posts by notro
Old Aug 24, 2012, 03:56 PM
nerys is offline
Grrr :-)
nerys's Avatar
Levittown PA 19057
Joined Aug 2006
try hitting the reset button ?
Old Aug 24, 2012, 06:47 PM
boozedog is offline
Find More Posts by boozedog
Joined Aug 2012
Geez, I hope I haven't nudged you into doing anything you'll regret. But it is only a matter of time before my two gumpack and three keychain (#3, #4, #11) cameras get upgraded to a newer variant. And I look forward to you guys having all the details being worked out by then!
Jack
Well ... I tried to do the external battery mod, connected up the 900mAh battery, plugged it in to the USB, and ... got a bad smell and a dead cam :-/
Well, not quite dead ... it comes alive briefly, but when I plug in the USB, I no longer get the green charging light. And it doesn't smell very good ... LOL!
At least I did get one decent video out of it before I killed it. Not R/C but at least it's flying, as they say ... :-)
20120818 tail cam test wide angle (7 min 32 sec)
boozedog is offline Find More Posts by boozedog
Old Aug 24, 2012, 06:50 PM
nerys is offline
Grrr :-)
nerys's Avatar
Levittown PA 19057
Joined Aug 2006
define "plugged a 900mah battery" into it ? did you plug a 900mah lipo into the USB port ? its designed for 5v not 3.7 or 7.4 (2 cells ??) ???
DUDE the full scale FPV tail cam ROCKS !! nice job on the flying too sweet landings.
Old Aug 24, 2012, 06:51 PM
boozedog is offline
Joined Aug 2012
Sorry to be clear I removed the little 240mAh 3.7 battery, and put a similar connector on a 900mAh battery, mounted externally, plugged it in. Didn't seem to want to power up so I plugged the camera in and attempted to charge the 900mAh battery by way of the camera. I have a feeling this might have been a poor choice on my part!
Old Aug 24, 2012, 07:02 PM
boozedog is offline
Joined Aug 2012
By the way I can see the part that got smoked is right behind the lens, there a little paper over it and the paper is blackened and it's clear that it got way too hot.
Anyone know what I did? Too much current for some reason, I'd say ... I'd search this forum but I mean sheesh it's one thread with 8080 replies! LOL
Old Aug 24, 2012, 07:12 PM
nerys is offline
Grrr :-)
nerys's Avatar
Levittown PA 19057
Joined Aug 2006
my guess would be you put the battery in backwards :-(
Old Aug 24, 2012, 07:20 PM
boozedog is offline
Joined Aug 2012
Uhm. You're right. The wires on the connectors I bought are reversed from the wires on the connector on the original battery. Duh ... it didn't even occur to me that the connectors might be wired different ...
Old Aug 24, 2012, 09:02 PM
akaloith is offline
Find More Posts by akaloith
Joined Aug 2012
boozedog top quality video
silky smooth motion!
lens D i suppose? I guess all you flyers need the lens D its supreme
everything so symetrical, perfect placement
show us the cam on the plane, photo
akaloith is offline Find More Posts by akaloith
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
