Espritmodel.com Heli Air
Old Apr 13, 2012, 03:31 PM
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by Mtz View Post
Of course testing in different conditions for lower bitrates before final release. The developer can give you some firmwares with different fixed bitrates from 7000kbps down (6000 5000 4000 3000), and after some tests, you or other beta testers can decide which bitrate to be set for the lower value.
When I wrote 5000-4000 was for 5000 or 4000 fixed values, not VBR to 4000 to 5000.
enjoy,
Mtz
The 7000 Mbps setting is not worth bothering trying to optomize. The codec will vary the bit rate according to the scene complexity anyway, and it's better to have it a little high than a little low. There's a lot more important things being worked on.
Tom Frank is offline Find More Posts by Tom Frank
Old Apr 13, 2012, 03:54 PM
Joined Jan 2012
I always keep the camera in a small box. I mount the W-67 only on the box.
The #16 with W-67 is a nice toy
255-16.avi (0 min 53 sec)
257-16.avi (0 min 21 sec)
only #11 for better center
259-11.avi (0 min 7 sec)
regards heribert
heribert808 is offline Find More Posts by heribert808
Old Apr 13, 2012, 04:23 PM
Joined Apr 2012
Hi guys,
Im new to the site and i just got one of these camera to film some track fotage from my motorbike.
Just wondered if any of you have any suggestions for mounts and vibration dampening?
There isnt really anywhere to mount the camera flat so i need to come up with something that can hold the camera flat but attaches at a 90 degree angle and also reduces vibration and stays on at 150mph
Please offer any ideas you have
Thanks Karl
monkeh is offline Find More Posts by monkeh
Old Apr 13, 2012, 04:30 PM
Regina, Sask. Canada
Joined Jan 2007
cool temperature cut-off
Originally Posted by brianvc View Post
regarding the problem of the cam switching off in cooler temps because of the drop in voltage, is it not possible to adjust the firmware to a lower cut off or maybe supply a higher rated mah battery as standard. would this cure the problem that seems to be emerging.
Could your problem be related to a weaker than normal battery? Do you have a replacement battery you could try? Some have reported receiving these cams with weaker batteries than others have. Just a thought as I've not had a problem using my #3's in cold weather.
kully99 is offline Find More Posts by kully99
Old Apr 13, 2012, 04:45 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by monkeh View Post
Hi guys,
Thanks Karl
There are handlebar mounts available (see #11 Frankencam [post #5, I think] and less expensive one here, but the vibration on a track will be a killer. You'd be better off if you can make an attachment for your helmet, I'd think.
Old Apr 13, 2012, 05:03 PM
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Hi guys,
Thanks Karl
velcro to your helmet?
empeabee is offline Find More Posts by empeabee
Old Apr 13, 2012, 06:39 PM
Joined Oct 2006
Due to member subjecting me to video
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Apr 13, 2012, 07:04 PM
Happy when flying!
kjrell's Avatar
France, Aquitaine
Joined Sep 2011
Last video using 0.25, rear view stil is a #11, and i begin to hate it
Pursuit of a red kite (FPV 808#16) (6 min 32 sec)
kjrell is offline Find More Posts by kjrell
Old Apr 13, 2012, 08:23 PM
Philippines, Central Visayas, Dumaguete City
Joined Nov 2011
Hi guys,
Thanks Karl
Speaking only from personal experience, nothing dampens the shock and vibration as much as your spine does, so I have to agree on a helmet mount.
I have tried many things myself (including moongel, velcro, hard mounts, you name it...) but the camera is too light to benefit from any of those. It has almost no inertia, so it moves with the slightest vibration. Some people suggested an unsprung position helps, but didn't work for me (although it was a bit better).
I assume you'd like a bike mount, especially if you don't want to record your swift head movements, but I haven't come across any magic bullets myself.
I know I haven't been of any help, except maybe saving some trial and error time, but the only good tip I can give is always have a safety tie, from camera to the frame, helmet strap etc. You never know when these little things cannot handle the speed any more and decide to come off...
CemAygun is offline Find More Posts by CemAygun
Old Apr 13, 2012, 08:59 PM
Joined Mar 2012
you didn't say where on the bike you wanted the mount. But once you have something stick the camera to that with velcro and then wrap it down to the mount with electrical tape, leaving the buttons exposed. Three turns should be enough for 150 mph though I admit I don't ride my bike that fast. Then go on the track and test and see if vibration is a problem or not. If you live come back and show us the video.
Originally Posted by empeabee View Post
someone sugested microscope slides - quite cheap, thin, light and optically ok.
I remember microscope slides as a kid in school. Some slides had a depression and then weren't there little peices of a thinner material that could go on top of the depression? Those would probably be optically clean too and may be a hobby store sells them (are there still hobby stores?).
flying circus is offline Find More Posts by flying circus
Old Apr 13, 2012, 09:47 PM
Germany, BW, Freiburg
Joined Apr 2012
Originally Posted by Tom Frank View Post
(HerrMueller: I think it's a good idea to create a separate thread (inside 'diy-electronics-199') for the extensions and modifications of all mini cameras)
It's a good idea... I just don't want to be the "owner" of more threads. There's already four threads I started here just for the #11, #16, #18, and 1080 keychain cameras, and they take more time than I wanted to dedicate to keeping then focused and maintained.
But anyone can start a thread in the other forum I can still link to it from here.
Hello Tom,
So, I started the thread in DIY Electronics
Collection and discussion of hacks, mods, improvements for KEYCAMS & other MiniCams
and linked the projects that i know.
I would be very happy, if you would put the link in your Post #5.
I think, it is a great thing, to find all projects for the cams at one location.
have a nice day
christian
HerrMueller is offline Find More Posts by HerrMueller
Old Apr 13, 2012, 10:29 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by HerrMueller View Post
Hello Tom,
have a nice day
christian
Sure, it's done!... thanks for authoring the thread. If you haven't already looked, there some of these in the #11 thread as well in the "Frankencams" post (#5, I think).
Old Apr 14, 2012, 03:27 AM
brianvc's Avatar
United Kingdom, England, Dorset
Joined Sep 2011
no i only have the supplied battery but mine is a #16 and yours is a #3, entirely different circuit board if you look at the internals.
brianvc is offline Find More Posts by brianvc
Old Apr 14, 2012, 03:32 AM
brianvc's Avatar
Joined Sep 2011
soft focus then fog
just had a weird problem, focus started to look soft, cleaned lens no better. looked inside couldn't see a focus ring on the lens. tested and soft focus had worsened to severe foggy image. tried re-set, no good. in desperation i re-installed mov25 firmware and bingo back to normal. seems that somehow the firmware became corrupted, strange.
Old Apr 14, 2012, 05:03 AM
Joined Nov 2010
Originally Posted by HenrySt View Post
Hello,
I bought the #16 cam a few days before.
I charged it as discribed. At the usage I'm fully frustrated!! (
The cam records around 1 minute and then turns off!!
The problem didn't change even on several other configurations.
I did an update from v 0.18 to version 0.25 but nothing changed.
At the config with blinking y-led during recording, sometimes the led blinking stumbles.
And before the cam turns off the y-led turns on for approximately 2 seconds. Then the red comes up in addition and both turn off after a second = cam is off.
What happen there ??
Can anybody please help here?
I'm really very disappointed!!
regards Heinz
Are you using a card with a class rating of 6 or 10? If yes, then the card is most probably your problem .
Click here to view the list of problematic cards.
If your card is not on the list, try another card (preferably class 4), and tell us the brand name, capacity and class rating of your current card.
If the card is not the problem, then your battery may not be charging properly because your USB cable is not working. I doubt this if you managed to update the firmware using the camera as an external device.
Do you have the same issues when recording using an external USB power supply (not your computer)?
Does the green LED go out after max. 2.5 hours - it may blink occasionaly?
Sorry for all the questions, but we need more information to localize the cause.
Isoprop is offline Find More Posts by Isoprop
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9838 Yesterday 08:20 AM
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 1 Feb 14, 2012 01:59 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
