Old Dec 23, 2011, 08:44 AM
thekubiaks is online now
Find More Posts by thekubiaks
Joined Aug 2010
Originally Posted by OnGuard View Post
Redid the video in Windows Live Movie Maker the other video editor I was using was coming out choppy.
http://www.youtube.com/watch?v=h6TSaJ5nbZs
Looks good, we have to remember that this is a keychain camera, not a GoPro.
thekubiaks is online now Find More Posts by thekubiaks
Old Dec 23, 2011, 08:47 AM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
This free editor from Pinnacle maybe worth a try
http://videospin.com/redesign/tutori..._tutorials.asp
victapilot is online now Find More Posts by victapilot
Old Dec 23, 2011, 08:52 AM
Giorg is offline
Find More Posts by Giorg
Giorg's Avatar
Italia, Lombardia, Milano
Joined May 2011
Originally Posted by kasuno View Post
hey guys I found that on Dealextreme. I think this is waht we're looking for. It's a set of fisheye lens with a lot of sizes, and it's cheapr for what it is.
http://www.dealextreme.com/p/2-8mm-1...ens-pack-15774
found the same some days ago but I think the M12 thread is way bigger than our cmos module
Giorg is offline Find More Posts by Giorg
Old Dec 23, 2011, 09:19 AM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Looks pretty awful IMHO, color shifting, and the bright pink circle when shooting above horizon is what? Not a big improvement over #11 (maybe worse) for the casual user like 99% of us.
Prof"s vid is better with less color shifting under the overcast skies, but still has the bright circle in the middle. You do rolling stops in Michigan too?
capt is offline Find More Posts by capt
Old Dec 23, 2011, 09:30 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I edited the video to make it look like a rolling stop .
The sun is out today in southeastern Michigan (one of three times during winter). I will capture some video with sunshine.
Bill
Prof100 is offline Find More Posts by Prof100
Old Dec 23, 2011, 09:36 AM
victapilot's Avatar
Joined Feb 2009
There seem to be more issues with hotspot and color/exposure searching on aerial video. I get most when the plane rocks above and below the horizon. On a car, the % sky is usually less, and is more stable, so the video is better.
Old Dec 23, 2011, 09:54 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Less choppy for sure. Color is less saturated with this iteration of camera, and, therefore, more realistic.
FYI, I use Videpad editor for these videos. It does do things I like.
1. It crops and zooms in on a scene so long distance shots of planes can at least be cropped so the plane is not a dot in the sky. Yes, it pixelates, but that's a small tradeoff to me.
2. Final transcoding for upload uses a compression scheme that saves space on your hard drive and time when you upload to Youtube.
Old Dec 23, 2011, 11:42 AM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by Type8 View Post
Horizontal Angle of view
#3 various reports of 30 to 44 degrees
#8 24.8 degrees (http://www.chucklohr.com/808/C8/)
#11 51 degrees (http://www.rcgroups.com/forums/showp...postcount=7837)
#16 42.6 degrees (http://www.rcgroups.com/forums/showp...0&postcount=86)
Glad to see wider options will be available, excellent news!
HTH
Thanks for the horizontal AOV angles. The "approx 58 deg" angle I mentioned is measured diagonally, corner-to-corner, which is how I think of AOV... i.e. AOV needed to fill the whole frame.
Tom Frank is offline Find More Posts by Tom Frank
Old Dec 23, 2011, 12:59 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
WE are still testing firmware revision, since I noticed a lot of color shifting here in S. Florida in the very bright sun that I did not see at home in Seattle (where the sun never shines). I have right now new firware that looks MUCH better... I'll post a sample clip shortly.
Old Dec 23, 2011, 01:56 PM
bobflyman is offline
Find More Posts by bobflyman
bobflyman's Avatar
Southwest England
Joined Nov 2010
I ordered the #16 a few days back after hearing that the green/brown colour hunting problem has been fixed, and the other fixes/improvements, but...
Although I didn't notice any colour hunting, (it was a dull day?) I'm not impressed with the hot spot in the middle of the video. (It's even obvious on embedded still shot.) My 11# is far superior in an even luminance across the frame. Hope I haven't wasted 25
If I recall correctly there is a way of masking the hotspot with Virtual Dub, which I guess may be the way to go. If it is a real problem with the new camera it's rather a shame. I doubt that's something that can be easily fixed with a firmware up date? Maybe I should have waited a while longer before ordering!
bobflyman is offline Find More Posts by bobflyman
Old Dec 23, 2011, 02:08 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Firmware test
Maybe this short clip will convince you all of what the #16 will become once the firmware is mature. It's still beinging refined for all lighting conditions. This is about as good as anyone can expect, I think, for $40.
#16 Test Video-click image to play
My netbook doesn't play the full HD image smoothly... hopefully you have a more capable PC. The colors on the native clip are a tiny bit more vivid and dead on for color and stability. About as good as it gets with a $40 HD key cam, folks!
Old Dec 23, 2011, 03:18 PM
bobflyman's Avatar
Southwest England
Joined Nov 2010
Impressive Tom. Maybe I haven't wasted my 25 after all!
The hot spot is nowhere near as obvious in your clip and the colours (or colors?) and sharpness are great.
P.S. I like your new boat and the boat dock at the back of your house.
Old Dec 23, 2011, 03:21 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Looks good Tom. Just to check...there is no audio in your clip correct?
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Dec 23, 2011, 03:47 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Cheers,
Jim
Yes... audio was muted to reduce file size and because there was noting to hear! The #16 audio is a very high bit rate and just inflates the file size.
Old Dec 23, 2011, 03:49 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I wish! (if I were a boater, which I'm not)
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
