Old Dec 22, 2011, 09:51 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by flitelab View Post
Where/what is the free battery repalcement offer? Can't seem to find a link.
The offer is talked about earlier in the thread. All you do is send a comment or note when you pay via Paypal that states you are a member of RCgroups, insert your screen name so they can see you are active on the thread about their camera. Once they verify you are RCgroups member and contributor to the thread they'll send back a note saying to you get a free battery with purchase of the new #16.
Prof100 is offline Find More Posts by Prof100
Old Dec 22, 2011, 10:43 AM
Gunawan204 is offline
Find More Posts by Gunawan204
Joined Dec 2011
Sorry for noob questions,
1. Can I use MicroSD "HC" for this #16 ? and what capacity should I get ? Because I want to choose between 16GB or 32GB? Better if use class 6 or class 10 ?
2. How long the battery lasts? How many hours we can use it with a single charge ?
I hope can get answer about this..Appreciated it...
Gunawan204 is offline Find More Posts by Gunawan204
Old Dec 22, 2011, 11:10 AM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by Wid View Post
That is great news Tom. The wider the AOV, the fewer cameras I'll need on the purpose built plane I'm building. I'm told there is even editing software that can do a decent job of removing fisheye. I was a little disappointed to learn the #16 has a narrower AOV than the #11, though the improvements in the #16 convinced me to give it a try.
I posted a side by side comparison video showing AOV difference in the #11 thread.
Tom Frank is offline Find More Posts by Tom Frank
Old Dec 22, 2011, 11:32 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
Yes, Micro SDHC are the cards you are looking for. You want quality, brand names, such as Sandisk, Transcend or Kingston. Class 6 is enough, but there's no harm in getting class 10 if you don't mind paying a bit more. I have tested Class 2 (Sandisk) and it also works!
16GB will give you up to max. 5 hours of video, 32GB will give you up to max. 10 hours.
A single charge will give you about 45 minutes continuous recording when the battery is new. If you want longer recordings then you need an external USB battery.
I posted an article about power supplies on the #11 thread here. A lot of the information is also valid for the #16 except ignore all reference to the "special" cable. Charging and recording while charging is also different. The article should at least give you an idea of recording times.
Isoprop is offline Find More Posts by Isoprop
Old Dec 22, 2011, 11:55 AM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Flight on old E-starter with #11 and HK Wing lens. Still needs focus tweak, also had moisture condensation on the lens. Sunny tomorrow Pitiful landing, rudder servo was out
#11 HK lens on E-starter (3 min 29 sec)
victapilot is online now Find More Posts by victapilot
Old Dec 22, 2011, 12:10 PM
Joined Dec 2011
Thank you...definetly will buy external USB battery.
I found this on eBay, Can I use this ?
http://www.ebay.com/itm/USB-AA-Batte...#ht_1438wt_905
Old Dec 22, 2011, 12:21 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Eletoponline sells the 1200 mah external power supply. Price is $16. Picture below has the key cam displayed for size. Camera not included.
Old Dec 22, 2011, 01:05 PM
wayback is offline
Find More Posts by wayback
Joined Feb 2010
I've been away, but would appreciate it if someone could summarize the AOV differences between the #3, the #11, and the #16.
wayback is offline Find More Posts by wayback
Old Dec 22, 2011, 01:11 PM
Joined Dec 2011
External battery pack
Old Dec 22, 2011, 01:20 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
You only need to post your question once.
Old Dec 22, 2011, 01:36 PM
flashbang is offline
Find More Posts by flashbang
flashbang's Avatar
Joined Dec 2011
Why not use the receiver for power?
flashbang is offline Find More Posts by flashbang
Old Dec 22, 2011, 02:06 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
Here I go again...
This is a fast moving thread. In order to keep track of stuff I am interested in I cut and paste the relevant bits into a text editor.
I have done this with other very large threads... and I get the feeling this will become a very large thread !
sparklet is offline Find More Posts by sparklet
Old Dec 22, 2011, 02:15 PM
OnGuard is offline
Find More Posts by OnGuard
Indiana
Joined Nov 2004
I redid the video because the video editor I was using was making it come out choppy. I ended up using Windows Live Movie Maker and it comes out smooth.
30 Inch Fanfold 3D Foamy with #16 HD Keycam Onboard (4 min 11 sec)
OnGuard is offline Find More Posts by OnGuard
Old Dec 22, 2011, 02:24 PM
Isoprop is offline
Joined Nov 2010
I don't know this item, but it boosts the voltage up from ~2.8V to 5V so there will be quite a bit of power lost. Personally, I have had bad experience with these sort of chargers for long recording. I think you will be dissapointed, unless you only need it for emergencies.
My advice, FWIW, is get a LIPO-based USB battery pack like Prof100 advises or pictured on my power supply post. Not cheap, but they work much better than 2-cell AA packs.
Old Dec 22, 2011, 03:33 PM
victapilot's Avatar
Joined Feb 2009
Originally Posted by OnGuard View Post
The original file from the camera is smother, but I think this looks pretty good for a cloudy day.
Looks good - thanks for sharing, possibly the first AV with this cam on this thread.
I look for vignetting and it's quite good. Only negative is the sample frame selected by YouTube which has the big pink hotspot, not at all typical of the video itself. YouTube has done that to some of mine too, other frames can be selected, but you probably know this
Thanks again!
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
