Joined Oct 2002
Blaze,
This is a great thread! I just got my mini TELEMASTER in the mail last week as a result from a buddy Gerry (a.k.a., SIMANO) who was kind enough to purchase it for me so, he can get his sky brother in the sky with him and fly alone with his SIG (Electric) RASCAL! Wow, I will be following this thread carefully and will keep notes of those recommendations as you go along! Thanks! Carlos |
Joined Oct 2002
Re: Telemaster
You are so correct.....take for example the GWS E-STARTER, a nice foamie model that comes in around 15 -16oz and does have ailerons with dihedral ! Depending on what kind of power you put her, she usually is going too slow for any effective response from the ailerons especially to roll he about the FUSE axis. What I usually need to do is kick some rudder along with the ailerons to get any effective roll. However, many start flying this model just with elevator and rudder and it does very well. Ailerons need air speed in order to be worth while. I studied the mini-TELEMASTER blue-line drawing that came with the kit and it just isn't worth the trouble nor the extra weight for this model to obtain ailerons IMO. Carlos
Joined Oct 2002
Most of the classic models that my fellow GAS (I.C.) flyers fly have the same kind of construction and they are considered classic since these models are very old. I fly in a club that mostly have a large retirement community near the Space Center and these guys have classics! Surprisingly, they don't have a problem with me flying just electrics and it seems that I have given them the bug to fly electrics as a result of less gear they have to deal with. I personally will drill out some holes in the solid sheets of balsa up front on the FUSE to lighten her up a bit and use CARBON REEL product that is available here in WINTER SPRINGS, FLORIDA...from a supplier known as BOB VIOLETT MODELS. These Carbon Fiber Reel can be easily cut with a standard shears or knife and you can re-enforce almost any structure including the foam ailerons that are shown in the attached picture from a GWS FORMOSA ARF. Carlos
Midland, Tx / W. Lafayette, Ind.
Joined Dec 2002
Well, ive got ya all beat! All i have left to do is build a wing panel, everything else is covered already. I love building with sticks, i actually prefer it to the nice laser cut plank sides. The wood in my kit was good, except for the control surfaces. I built a larger rudder (about 2x, is that too big?) out of scrap sticks, but im going to replace the elevator wood, as it could pass for liteply almost. I weighed my tail surfaces (Horiz. & vert. stabs. and rudder) and the elevator halves weighed more than everything else combined! I also added a hatch in the bottom for battery access, inbetween the LG block and next spar. So far its been a really easy, well designed kit to build. My fuse and tail surfaces, covered weigh in a less than 2.25 ounces, im pretty happy with that so far.
Jonathan |
I tried posting earlier but something was "down" somewhere and I couldn't connect. Kansacloud (Mike) has it right. I have other airplanes that I can do rolls with.... why else would you want ailerons? Besides, a high winged airplane doesn't do very pretty rolls anyway. Mine will be R/E.
I have the fuselage completely done. Construction of the stab will begin this morning. More pictures later today. I may even get to the wing today. Stick constuction IS very time consuming, I admit. But it's well worth the effort when you show up at the field, and people praise your workmanship . I have a double size Comet Sparky covered in trans. yellow that gets all sorts of compliments everytime I show up at the field with it. I'm a builder, but admit to luv'in some of these ARFs that are out there. Fred G. |
A bottom hatch >would< be a great modification.
I only skim directions, as a I sheeted the sides after putting in the cross pieces. No problem, everything is straight and true, perfect. Do these pictures look clear? When I view them online, they are grainy. I think it's because of Earthlinks' "accelerator" in their new software,.. faster download but poorer quality. Fred G http://www.home.earthlink.net/~guilfo/fms.htm |
| Thread Tools | |
| My Hobby Lobby Mini Telemaster Build | coyn | Parkflyers | 17 | Dec 31, 2007 10:19 PM |
| Help! Mini Telemaster Build Question??? | Mark P | Beginner Training Area (Aircraft-Electric) | 16 | Jan 21, 2007 09:50 PM |
| Mini ifo build tips | soundman | Parkflyers | 10 | Dec 02, 2002 07:49 PM |
| Mini Tornado Build Questions | HavingFun2002 | Foamies (Kits) | 4 | Apr 08, 2002 11:16 PM |
| Mini Tornado build question | Crashmaster | Foamies (Kits) | 1 | Mar 26, 2002 07:38 PM |
