Old Dec 15, 2011, 12:22 PM
hamerson is offline
Find More Posts by hamerson
United States, GA, Dahlonega
Joined Nov 2011
Question
FW flashing of Turnigy 9x with smartie parts board
The flashing was incomplete. Trans now shows ER9x when UBS is attached, but when disconnected and then turned on screen says loading model 1. Nothing ever happens. Can it be re-flashed? or fixed?
Amos
hamerson is offline Find More Posts by hamerson
Old Dec 15, 2011, 02:56 PM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Amos
Sure it can be fixed.
Best place for helpful advice is on one of these threads.
http://www.rcgroups.com/forums/showthread.php?t=1266162
http://www.rcgroups.com/forums/showthread.php?t=1338412
If you look at the second one in particular you may find just what you need. If not there are very helpful people. But be sure to provide full details of what you did.
The first thing is always to make sure you have good connections, so I'd remove the board and clean the pads really with isopropyl alcohol. Make sure the board is solidly seated.
Daedalus66 is online now Find More Posts by Daedalus66
Old Dec 16, 2011, 09:22 AM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
Sounds like a problem with eprom file containing the model memory. Did you format the eprom at the end of the firmware flash or did you just pull the plug on it?. It is now searching the model 1 but it is not there. Try loading just the eprom file with eepe.
B12 is offline Find More Posts by B12
Old Dec 17, 2011, 11:14 AM
hamerson is offline
Joined Nov 2011
Daedalus66. Thanks. It took three more tries, but FW finally loaded. I should have backed eprom prior to flashing.
Amos
Discussion Flashing Turnigy 9x - Using ARDUINO Toffe87 Radios 13 Nov 30, 2015 06:57 AM
For Sale Turnigy 9x with Smartieparts board and LCD, Frsky DJT/DHT-U Spare Smartieparts board daign Aircraft - General - Radio Equipment (FS/W) 4 Nov 27, 2011 08:20 PM
Sold Turnigy 9X w/Smartie Parts Boarrd MrDusanmandic Aircraft - Electric - Multirotor (FS/W) 12 Oct 16, 2011 04:44 PM
Sold Turnigy 9x Transmitter with the Smartie Parts board and a blue LED backlight + RXs major.monogram Aircraft - General - Radio Equipment (FS/W) 7 Sep 29, 2011 03:28 PM
Sold Turnigy 9x with Smartie Parts Board ryancsmith Aircraft - General - Radio Equipment (FS/W) 3 Jul 11, 2011 01:10 AM
