Old Dec 15, 2011, 09:39 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Skyangel Mini 50mm EDF jets
Thought people would like to see following figures recorded on my vertical thrust rig and Wattmeter readings :
Model : T45 50mm EDF Skyangel ARF from Hobby King
Motor : Stock as supplied fitted 4200Kv
DF : 50mm 5 plain blade fan as fitted stock
ESC : 20A as stock
The model is stated to use a 850mAh 3S 20C LiPo and nearest and others have been used in tests ...
Batt ID.... mAh.... ... ..C rating.... Amps.... Watts.... Thrust grams
001 ....... 800.... 3S .. 20C....... 16A ..... 170W .... 255 gr
002 ....... 800.... 3S .. 20C....... 15A ..... 160W .... 245 gr
003 .......1300... 3S .. 25C....... 18A ..... 220W .... 330 gr
004 .......1300... 3S .. 25C....... 16A ..... 170W .... 275 gr
--D .......1800... 3S .. 25C....... 18A ..... 210W .... 340 gr
--G .......1800... 3S .. 25C....... 18A ..... 220W .... 345 gr
Battery D was used for flight tests and Doppler speed checks on video gives 85km/hr straight level and over 90km/hr in shallow dive.
I did connect a 2100mAh 3S 35C pack out of interest to see if C rating could improve performance ... as the Wattmeter went over 21A, 240W - I cut the power before ESC or Motor suffered. There was obviously more power available from the stock set-up.
Tests will be made later with 4S 20C pack as I believe keeping amps in the sub 20A band is advised. But having extra V on tap ... we should see an increase in thrust and consequently more speed. The intention is to push the model to break the 100km/hr mark but with stock as far as possible, apart from LiPo and possibly changing fan to 6 blade .. but shroud, model, motor, ESC will remain.
Anybody else experimented similarly ? Any results to pass on ?
I'm interested in grouping up with other 50mm EDF owners to maximise the adrenaline on these machines !
solentlife is online now Find More Posts by solentlife
Old Dec 15, 2011, 03:47 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Lots of info on these great little jets ( I have three) in the Micro EDF Jets and Power Systems forum.
mw
Mark Wood is offline Find More Posts by Mark Wood
Data CG specs for 50mm jets by JPower, Skyangel, BlitzRC. ESC program instructions and FAQ Joe 1320 Foamy EDFs 194 Jun 01, 2015 07:29 PM
For Sale JPower Skyangel mini F-18 50mm EDF For Sale!!! TotallyJets Aircraft - Electric - Jets (FS/W) 3 Apr 30, 2012 12:56 AM
Sold SkyAngel T45 50mm EDF BNF with 2 Batteries dawjr Aircraft - Electric - Jets (FS/W) 7 Sep 28, 2011 08:42 AM
Sold SkyAngel F35 50mm EDF BNF with 2 Batteries dawjr Aircraft - Electric - Jets (FS/W) 3 Sep 27, 2011 08:27 PM
Discussion J-Power/Skyangel/X-FLIGHT 50mm edf failures gdimonte Foamy EDFs 7 Dec 28, 2010 09:49 PM
