Hi
I have launched from both flat and slope. Unfortunately I no longer know how much power I have there - it's lost in the mists of time (well, that's my excuse and etc. etc. ). I know it isn't a huge amount, probably under 1kw. I can climb at about 45 - 55 degrees max., nothing spectacular.Chris |
Latest blog entry: Last great slope session of the summer?
Cool
Leeds/Bradford Leeds, Great Britain (UK)
Joined Jun 2003
Hi, Personally i think by considering either of your options you could easily make a mess of your fus unless you know what you are doing with these options. As i stated i nearly went for the scorpion motor but for this reason i went with the Hyperion GS3032-08 with the tapered nose nose which then goes past the motor and i allso used a back plate you can get with these motors that takes the weight of the motor but allso has a hole where the motor wires pass through helping with keeping the motors secure and away from the spinning case. Regarding power the hyperion chart states around 1300 watts but i get a little less but believe me this is plenty of power as on full throttle you can not hold it back but i launch on just over 1/2 throttle which is more than enough. The hyperion motor and esc does not come cheap but well worth it. Looking forward to some warmer days to see how well the Volcano thermals. Saying that with a 4s 5000mah pack through the winter months with no thermals about i was getting 2x 15min flights so it shows you how well the energy retention his. Hope this helps in your decision with the Volcano.
Joined Jun 2003
Just i thought, If you go with the power pod i think this will create a lot of drag and reduce energy retention but if you decide to bring the motor wires out through the fus then back in could you not get some of these plastic table spoons cut the end of and this gives you like a blister so you could cyano to the fus over the wires if you keep them as small as possible .
Have you thought about taking advantage of this oblong and making scoops to bring air in for cooling?
Joined Mar 2006
I did some careful measurement, made a few jigs and have found that I can fit the 50mm motor in the nose with a 42mm spinner, as long as I make the motor mount thick enough. As glenbees pointed out, the fuse is much more round at 42mm, but I can make it even more round, I'm hoping, by clamping a round motor mount into the nose.
Now I have to decide on the thrust angle before I cut the nose. What is everyone else using for thrust angle? Incidentally, does anyone know of a good article on how to decide the optimal thrust angle? A bit down, a bit to the right is the usual recommendation. Also, how do you like your thrust angle? Does it pitch up or down under thrust? |
Joined Mar 2006
I'm sure other on rcgroups have done more rigorous calculations and measurements than I, and I'd like to read them one day. Something I would like to measure, however, is the temperature inside the fuse when flying at higher altitude in the winter, something I do occasionally do. At these times I suspect you want to make sure there's no ventilation to make sure your electronics don't get dangerously cold. |
| Thread Tools | |
| Rave Fantastic Valenta Volcano | Woodstock 1 | Slope | 107 | Dec 14, 2011 12:31 PM |
| Mini-Review Valenta Volcano | Woodstock 1 | Thermal | 9 | Jun 17, 2011 04:43 PM |
| Discussion Valenta Volcano | Woodstock 1 | Scale Sailplanes | 2 | Jun 21, 2009 04:20 PM |
| Discussion VIDEO - Valenta VOLCANO 3,7 m soaring in Austria | midgae | Electric Sailplanes | 2 | Sep 30, 2008 09:13 PM |
| Sold Valenta Volcano Sailplane | Phil Davy | Aircraft - Sailplanes (FS/W) | 2 | Jul 22, 2008 04:59 PM |
