This thread is privately moderated by lpaus967, who may elect to delete unwanted replies.
Old Dec 14, 2011, 09:33 PM
lpaus967 is offline
Find More Posts by lpaus967
Joined Nov 2011
Esc Blow up?
I feel really stupid guys, I am new at ths hobby and i have a 3000mah 40c 11.1 volt battery and i plugged it into my 18am plush speed controller. There was a spark and smokes blew out of my esc. Can you guys tell me what happened? Is my battery ok, can i still use it or did it completely short? I opened my esc after and there was no obvious or even noticible marks of fire or heat, but smoke came out of it. Thanks guys
lpaus967 is offline Find More Posts by lpaus967
Old Dec 14, 2011, 09:40 PM
lpaus967 is offline
Joined Nov 2011
something you should know
I made a converter for my battery so i would not have to cut the wiring. I do not think this was the problem though.
Old Dec 14, 2011, 09:54 PM
Whiskers is offline
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
I have no idea what you mean by this.
Exactly what did you do?
It sounds like the + and - were reversed.
Whiskers is offline Find More Posts by Whiskers
Old Dec 14, 2011, 09:56 PM
lpaus967 is offline
Joined Nov 2011
I do not think so, what i did was it had a fifferent male connector that would not connect to the female so i used a female from another esc that would fit the battery and attachedthat to a male that would plug into the female connector for the esc. I think it is because i have such a geat c rating. 40c for a 18amp battery, probly just overloaded it. Thats what i am guessing, tell me if i am wrong.
Old Dec 14, 2011, 10:45 PM
Whiskers is offline
Whiskers's Avatar
Joined Feb 2010
You are wrong
If the polarity was correct then most likely there was a short.
Just plugging things in normally would not result in any real load on the ESC or any other part of the power train.
Old Dec 15, 2011, 06:54 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Originally Posted by Whiskers View Post
You are wrong
Agreed, you could plug a 100C 10000ma battery in to your ESC and the ESC should be fine. Its the load (ie: motor or a short) on the ESC that will kill it.
Re-check your wiring..
baddb1 is online now Find More Posts by baddb1
Old Dec 15, 2011, 04:21 PM
lpaus967 is offline
Joined Nov 2011
Ok also i did not have my motor plugged into my esc just my reciever and battery
Old Dec 15, 2011, 04:40 PM
Whiskers is offline
Whiskers's Avatar
Joined Feb 2010
Any chance those motor wires were touching?
Old Dec 15, 2011, 05:11 PM
lpaus967 is offline
Joined Nov 2011
No, I do not recall them touching at all. When i made that connector i aligned the black with black and red with red, are they the same through out all the batteries in the world?
Old Dec 15, 2011, 08:35 PM
Whiskers is offline
Whiskers's Avatar
Joined Feb 2010
Red + and black - are reasonably universal.
OK. If there was no short circuit for any reason and the polarity is correct, then perhaps the ESC was faulty.
Other than that... I give up.
Old Dec 15, 2011, 08:37 PM
lpaus967 is offline
Joined Nov 2011
Ha ok it was wierd the other day when i tried to add power to the motor it would just start twitching and then eventually start spinning. If i took off the power again it would do the same thing, also would get very hot.
Old Dec 15, 2011, 08:51 PM
Whiskers is offline
Whiskers's Avatar
Joined Feb 2010
Yes. Some motor / ESC combinations will do that. Altering the timing may fix it, but sometimes another type of ESC is the best option.
Old Dec 15, 2011, 09:09 PM
lpaus967 is offline
Joined Nov 2011
Yes i tried all the timings and noine worked i think i will have to go with another type of esc i guess...
Discussion Just so I don't blow anything up.... kickythekick Batteries and Chargers 7 Dec 14, 2011 05:01 PM
Discussion Man arrested for planning to blow up Pentagon and US Capitol with R/C Plane. tommyt Life, The Universe, and Politics 74 Oct 18, 2011 11:50 AM
Discussion Man arrested for planning to blow up pentagon and US Capitol with R/C Plane tommyt Fuel Jet Talk 5 Oct 12, 2011 07:02 AM
Discussion Massachusetts Man Plotted to Blow Up Pentagon rpstar Atlanta Area RC 10 Sep 30, 2011 08:02 AM
Discussion Plot to blow up pentagon with an RC jet kramer Life, The Universe, and Politics 4 Sep 28, 2011 07:45 PM
