Old Dec 13, 2011, 11:17 PM
BlackTitanium is offline
Find More Posts by BlackTitanium
3D and Scale RC Heli Pilot
BlackTitanium's Avatar
Monroe, WA
Joined Jan 2007
Mini-HowTo
DIY Cascade Tail Rotor for AH-64 Apache (450 size)
The 4 blade tail rotor from cncheli works OK, but has some build quality and design issues.
I fabricated a Cascade tail rotor for a more scale look for my Apache, using stock
TREX 450 parts, and a HPI Racing Shock Shaft.
Remove the metal gear from a stock tail rotor shaft assembly.
Thoroughly clean the new 3mm shaft.
Use red Loctite 271, to glue the gear onto the 3mm shaft and let it set for 24 hours.
Cut the 3mm shaft to a length of 60mm.
Thanks to SuperHornet for his Multi Blade Tail Do-It-Yourself guide.
BlackTitanium is offline Find More Posts by BlackTitanium
Old Dec 14, 2011, 01:10 AM
josereyes is offline
Find More Posts by josereyes
josereyes's Avatar
United States, WA, Steilacoom
Joined Nov 2011
To bad they don't make those swept tip scale blades for the 500 size, or at least I have not been able to find them. Nice build BT
josereyes is offline Find More Posts by josereyes
Old Dec 14, 2011, 11:33 AM
Druss is offline
Find More Posts by Druss
Canada, AB, Edmonton
Joined May 2008
Not really swept tip but would these work?
http://www.ehirobo.com/shop/product_...ducts_id=10148
Druss is offline Find More Posts by Druss
Old Dec 14, 2011, 02:25 PM
josereyes's Avatar
Joined Nov 2011
Thanks for the link, I have seen them before, the only thing is that according to the weight on their site, a pair of blades weighting 220 grams a pair... that's 110 grams per blade...
the scale blades I have now are 65 to 70 grams a blade, so they're way heavier... I do like the look but what's keeping me back is that extra weight....
Old Sep 28, 2014, 04:47 PM
Monroe, WA
Joined Jan 2007
To complete this assembly I also used:
2 - M2x12 mm socket collar screws (H25125)
2 - Linkage rod(A) x 2(Φ1.3x9mm) (HS1119)
2 - Stainless Steel Linkage Balls (HS1155)
Assemble two ball links with a 1.3x9mm rod
Install a linkage ball into one of the ball links
Insert the M2x12mm collar screw as shown.
Attach the linkage assembly as shown
Build Log Apache AH-64 600 size (TF/Smartmodel kit) Horseman Scale Helicopters 489 Aug 05, 2016 07:28 AM
Build Log Assembly of the 450 Size AH-64 Apache BlackTitanium Scale Helicopters 54 Dec 31, 2012 03:24 PM
Cool AH-64 450 size apache vid darthdrk Scale Helicopters 11 Aug 17, 2010 11:16 PM
Cool AH-64 450 size apache video darthdrk Scale Helicopters 5 Jun 20, 2010 08:45 PM
Video AH-64 Apache 450 size darthdrk Electric Heli Talk 3 Aug 07, 2008 12:37 AM
